Wisconsin Tacomas and bad financial advice
Discussion in 'Mid West' started by Thatbassguy, Dec 19, 2008.
  1. Nov 17, 2024 at 7:57 PM
    Supr4Lo
    Supr4Lo Well-Known Member
    Surprise, AZ
    2020 DCSB Offroad MT, Supercharged, NWF Eco-Crawler, 4.88's Locked F&R on 37's
    There is still more work to be done. Just Like @BEAR_KNIFE_FIGHT was mentioning I'm limiting up travel because I have more to cut. I'll have to tub the inner fender in the battery and washer reservoir aera for tire clearance to get all the up travel. The outer fenders were just the start. Going to 37s is not a simple hammer here and there job.
    Worth all the hassle? Absolutely!!
  2. Nov 17, 2024 at 7:57 PM
    McSpazatron
    McSpazatron Well-Known Member
    You suppose that stuff could be used on the bottom of sliders to keep rock gravel chips away? It should stick over the rustoleum paint I have on the sliders now, at least I would imagine.
    It would get scratched off sliding over rocks I’m sure, but if I could touch it up with the same stuff, it might be an easy way to keep gravel chipping to a minimum.
  3. Nov 17, 2024 at 8:10 PM
    McSpazatron
    All ya’ll are crazy! With all that tubbing and hammering, and welding new lower pivots.
    @pearing, I’ll chip in 20 bucks into your portal fund. The time and head scratching you’ll save will be worth it. Probably. Ok, maybe not, but still… it will be cool!
  4. Nov 17, 2024 at 8:23 PM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    :anonymous:
    Race car parts.
    Also, the JD fab lower pivot kit is really cool.
    Thatbassguy[OP] and bkhlrTaco's like this.
  5. Nov 18, 2024 at 1:06 AM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Can't hurt.
    If you ever need someone to estimate a painting job, don't call on me.
    I plan on doing the sliders and I'm going to continue with that textured finish because they get a little slick to step on when wet, if painted smooth.
    I'll have enough left to finish the back frame and rear axle.
    It should stick fine to the Rust-Oleum.
    It's a "one and done" top coat and it says it works better if a little rust is left on so I don't think intense prep is required for it.
    I do think temp/humidity and cure time are important so I followed it closely. Keeping my garage around 70°F and 50% humidity all weekend.
    sparkystaco, Aztec120 and CygnusX191 like this.
  6. Nov 18, 2024 at 1:09 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    All I heard was.
    :spending::spending::spending::spending:
    sparkystaco and CygnusX191 like this.
  7. Nov 18, 2024 at 4:12 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    All you big tire guys. A guy I know with 32's was wondering would it have been easier to buy a Tundra and try to make it smaller vs. making a Tacoma bigger?
    :D:notsure:
  8. Nov 18, 2024 at 4:15 AM
    pearing
    pearing Well-Known Member
    Wisconsin
    2015 SR5 quadcab
    Thanks for this-what I was looking for. I am under no illusions that the jump to 37's is going to be easy. I have done a pretty good job getting clearance for the 35's... there is a bit at full stuff and turn that still rubs, but nothing serious. I don't see how a 2nd Gen can run 37's without chopping the cab and inner fender wells. The cab mount has to go too, so there is that to reengineer. Longterm I am thinking SAS so not sure I want the investment into the JDF parts. More thinking to make the LCA/LBJ stronger than what factory is, gain a bit of forward distance to help clearance.
  9. Nov 18, 2024 at 4:16 AM
    pearing
    Wisconsin
    2015 SR5 quadcab
    That guy? he'll be there soon enough...
  10. Nov 18, 2024 at 4:47 AM
    Supr4Lo
    Surprise, AZ
    I would say if you plan on a SAS don't invest time cutting and fitting plus dollars into suspension parts now to fit 37s. Just run what you have untill your ready to SAS.
  11. Nov 18, 2024 at 5:07 AM
    Thatbassguy
    Thatbassguy [OP] Sweet or sour?
    James
    '19 T4R, TRDORP, KDSS
    RSG sliders, SOS skids, SOS bumper, wheels, tires, etc
    :anonymous:
    My original plan was to do hub bearings and CV's at around 100K. I'm at 125K now, so I should probably start thinking about it. :D
  12. Nov 18, 2024 at 7:59 AM
    pearing
    Wisconsin
    2015 SR5 quadcab
    Know anyone running these? Look beefy and they push things forward. (@Snowy , @CygnusX191 , @Supr4Lo ) Priced competitively. Have a Moog versus a uni ball, but at least easily replaceable.
  13. Nov 18, 2024 at 8:12 AM
    Shellshock
    Iowa
    good thing 2025 models will be hitting lots any day now!
  14. Nov 18, 2024 at 8:17 AM
    Shellshock
    Iowa
    ooooooooor
    https://motorsports.74weld.com/product/4-gear-tacoma-4runner-portal/
  15. Nov 18, 2024 at 8:18 AM
    Shellshock
    Iowa
    putting 37s on a tundra is easy
  16. Nov 18, 2024 at 8:40 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    :duh:
    CygnusX191 likes this.
  17. Nov 18, 2024 at 9:04 AM
    LarryDangerfield
    LarryDangerfield One Larry a day keeps the money away ™ Moderator
    Tyler
    Northern Wisconsin
    Black 2020 Nightshade Edition 4Runner
    Oh there will be some mods all right
    I was just having a weak moment that day I'm good now!
  18. Nov 18, 2024 at 10:16 AM
    Shellshock
    Iowa
  19. Nov 18, 2024 at 10:39 AM
    BEAR_KNIFE_FIGHT
    BEAR_KNIFE_FIGHT bearly famous
    Alex
    Minnesota
    2016 TRD OR 4X4 DCSB Slowsand, 2017 WRX WRB
    I'm tempted but also nervous about the unsprung weight increase.
    I mean also the 20k hole in my account but thats neither here nor there. If I was going to spend 20k on the truck it would be on a cage and links, honestly. Better travel and more efficient
  20. Nov 18, 2024 at 10:55 AM
    Supr4Lo
    Surprise, AZ
    How about links and portals?? I was infront of this guy and look back to see he's rolling over 3ft tall rocks like it's nothing. https://www.instagram.com/reel/C_GcpcMP95b/?igsh=MWhiamhqdm5sMWZoZw==
