Wisconsin Tacomas and bad financial advice
Discussion in 'Mid West' started by Thatbassguy, Dec 19, 2008.
  1. Mar 20, 2025 at 11:12 AM
    Pixeltim
    Pixeltim Misunderstood member
    77 square miles surrounded by reality.
    '15 Black DCLB SR5
    Tires, Softopper, fully armored, winch, many pinstripes.
    I'll have to check that out to see if I need to mount mine the same way.
  2. Mar 20, 2025 at 12:24 PM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Here's what the mentioned handhelds offer.
    Dual Watch is monitoring 2 channels..
    There's also all the private channels, direct call and group call.
    I'm not ready to read that far ahead.
    I did read a little. It's confusing until I read it several more times.
    Something about setting privacy codes and matching another radios code, to send direct calls. Different call sounds for different codes.
    CygnusX191 and sparkystaco like this.
  3. Mar 20, 2025 at 12:38 PM
    Pixeltim
    '15 Black DCLB SR5
    Yeah, we should set up a group and use privacy codes, that way we won't be able to communicate cause most of us (including me) will set them up wrong ;)
  4. Mar 20, 2025 at 1:19 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    That is definitely one big reason nobody really uses privacy codes (nor are they necessary most of the time). Just to add more confusion for everyone, in the GMRS world "privacy codes" do not actually have anything to do with privacy. It's more about filtering out interference of other people's communications in crowded areas. Zero actual privacy, very confusing terminology.
    Luckily GMRS is about as easy as it gets if you don't get bogged down by the minutiae. Select the channel, press the button, talk to your friends. Simple. For 99% of people that's all you really need.
  5. Mar 20, 2025 at 1:22 PM
    Pixeltim
    '15 Black DCLB SR5
    Yeah, I just need the Captain Dummy version for my simple needs.
  6. Mar 20, 2025 at 2:15 PM
    Taco-Grinder
    Dan
    Fond du Lac, WI
    When in Utah we had to change channels one day.
    Some kids at a campground were playing
    Marko- Polo.
  7. Mar 20, 2025 at 5:36 PM
    pearing
    pearing Well-Known Member
    Wisconsin
    2015 SR5 quadcab
    The wiper discussion earlier got me thinking about my wiper blades. I bought a Silblade silicone set back in 2018. They are still working great, until I looked at them. This winter seems to have been rough on them, so... just ordered another set. Over six years. Thats a pretty good return.
  8. Mar 20, 2025 at 6:25 PM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    How's that skid plate coming along?
    I ran through a fluid check today. (Filled the washer fluid, to stay on topic).
    The new/used transfer case took a little more gear oil.
    Other than that, all good.
    I'm done working on anything major until after the trip. Anything that could hold up my truck, that is.
    When I fix something at work, I look at my 2nd pressman and say,
    "It's either going to get better, or it's going to get worse." :rofl:
  9. Mar 20, 2025 at 6:41 PM
    pearing
    Wisconsin
    2015 SR5 quadcab
    Fixed it today. No rattle. Lost 3/8 inch of clearance. Time for 37's
  10. Mar 20, 2025 at 7:53 PM
    WiscoPat
    WiscoPat One does not simply purchase a Ridgeline
    Pat
    Wisconsin
    2019 TRDOR Tacoma 1995 JDM 80 Series
    Mall Rated
  11. Mar 21, 2025 at 4:14 AM
    pearing
    Wisconsin
    2015 SR5 quadcab
  12. Mar 21, 2025 at 4:21 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Pixeltim and WiscoPat[QUOTED] like this.
  13. Mar 21, 2025 at 6:04 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    My air intake box was quite dusty.
    Cleaned that and the MAF/intake. Checked breather valves.
    Check. Check. Check.
    Managed to break the base for my phone mount, :facepalm: so I've got another one of those on the way.
    sparkystaco, CygnusX191 and Pixeltim like this.
  14. Mar 21, 2025 at 6:09 AM
    Thatbassguy
    Thatbassguy [OP] Sweet or sour?
    James
    '19 T4R, TRDORP, KDSS
    RSG sliders, SOS skids, SOS bumper, wheels, tires, etc
    It almost seems like it would be worth learning how to use the privacy codes. We've picked up others' conversations on several occasions. It's not as bad as CB was, but, it's been a little annoying at times.
  15. Mar 21, 2025 at 7:14 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    I was about to order a different antenna. Then I figured I better make sure if the one I have is male or female connection..........
    I don't think the antenna on the Midland GXT1000 is meant to come off.
    CygnusX191 and OldSchlPunk like this.
  16. Mar 21, 2025 at 7:35 AM
    Shellshock
    Iowa
    Just order the mxt275 and install it in the truck. Keep the hand helds in the door to use when out of the truck spotting.
  17. Mar 21, 2025 at 7:35 AM
    Pixeltim
    '15 Black DCLB SR5
    I'm sure you can find a way to make it happen.
    :crapstorm:
  18. Mar 21, 2025 at 7:37 AM
    Pixeltim
    '15 Black DCLB SR5
    That's what I'm doing. It should be here in a week.
    Possibly less.
    Probably more.
  19. Mar 21, 2025 at 7:46 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Ya. Ya. Ya.
    It's already in my cart......along with the rear anytime mod, front camera, battery operated chainsaw, a welder, DJI Osmo camera and a Noco booster......
    My ambitions exceed my free cash flow. :D
  20. Mar 21, 2025 at 7:56 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Believe me...........
    I glanced at the screws that hold the radio together. lol
    I started twisting the antenna and it felt glued in...Like if I twisted harder it would break.
    CygnusX191 likes this.
