Wisconsin Tacomas and bad financial advice
Discussion in 'Mid West' started by Thatbassguy, Dec 19, 2008.
  1. Apr 28, 2025 at 12:45 PM
    Pixeltim
    Pixeltim Misunderstood member
    77 square miles surrounded by reality.
    '15 Black DCLB SR5
    Tires, Softopper, fully armored, winch, many pinstripes.
    Guys don't read manuals.
    Aztec120, CygnusX191 and sparkystaco like this.
  2. Apr 28, 2025 at 12:46 PM
    Pixeltim
    '15 Black DCLB SR5
    Not working. I'm guessing he gets shocked by them whenever he hits a bump :annoyed:
  3. Apr 28, 2025 at 12:47 PM
    BEAR_KNIFE_FIGHT
    BEAR_KNIFE_FIGHT bearly famous
    Alex
    Minnesota
    2016 TRD OR 4X4 DCSB Slowsand, 2017 WRX WRB
    shocking
  4. Apr 28, 2025 at 12:47 PM
    Pixeltim
    '15 Black DCLB SR5
    Absolutely! I just figured with all the electrical issues them dudes are having after the Kentucky submarine trip...
  5. Apr 28, 2025 at 12:48 PM
    LarryDangerfield
    LarryDangerfield One Larry a day keeps the money away ™ Moderator
    Tyler
    Northern Wisconsin
    Black 2020 Nightshade Edition 4Runner
    Oh there will be some mods all right
    Wait the new ones you just installed?!
  6. Apr 28, 2025 at 12:49 PM
    Pixeltim
    '15 Black DCLB SR5
    He probably didn't realize they are not IPX7 waterproof rated. They rusted solid.
  7. Apr 28, 2025 at 1:16 PM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    Not issues...features.
  8. Apr 28, 2025 at 1:17 PM
    OldSchlPunk
    Rich
    East Central Wisco
    Seriously?! Must be cheap shocks...:crapstorm:
  9. Apr 28, 2025 at 1:18 PM
    Thatbassguy
    Thatbassguy [OP] Sweet or sour?
    James
    '19 T4R, TRDORP, KDSS
    RSG sliders, SOS skids, SOS bumper, wheels, tires, etc
    I understand that how stiffer suspension on one axle will cause the other axle to flex more under load.
    But, none of this explains how having a sway bar in the rear would allow greater overall articulation then not having one. If you remove the rear sway bar from the equation, the rear will just flex more before forcing the front to flex more.
    I also know what the purpose of a sway bar is.
  10. Apr 28, 2025 at 2:47 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    You've got to think less about suspension, more about body roll.
    Go back & look at the race trucks, front tire off ground, lots of body roll, no rear sway.
  11. Apr 28, 2025 at 4:04 PM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Short of taking the starter completely off, there isn't much more to do.
    Got up in there to clean/dry the pos. and neg. with a q-tip.
    It would've been easier with the skid plate off but I didn't want to.
    Instead, I rolled under the front diff. and gave the LCA a half-nelson.
    I'm waiting until morning to start it.
    Aztec120 and CygnusX191 like this.
  12. Apr 28, 2025 at 4:17 PM
    Thatbassguy
    James
    You should probably just go trade it in for a 4th gen. :notsure:
  13. Apr 28, 2025 at 4:31 PM
    McSpazatron
    McSpazatron Well-Known Member
    Yup, seen Tinkerer’s video. The rear sway plays a part in pushing the opposite corner into terrain and maximizing articulation.
    Also without the rear, you’d probably instantly flip if you sneeze. That’s for crazy people!
    You guys with your Tacomas don’t have to worry about any of this…your whole frame is one big flexy torsion bar.
  14. Apr 28, 2025 at 4:33 PM
    Thatbassguy
    James
    It's literally impossible to have better articulation with a sway bar than without. I'm trying to figure out where this whole mindset is coming from.
  15. Apr 28, 2025 at 4:37 PM
    Pixeltim
    '15 Black DCLB SR5
    Mind altering substances can be the cause.
  16. Apr 28, 2025 at 4:37 PM
    McSpazatron
    I was actually surprised on my first turn with how much it leaned. I feel better about it now that I got a chance to honk on the thing on the Wyalusing trip. It still remains a vehicle you should not attempt to manuever while braking hard in interstate situations…but honestly you can say that about a lot of normal vehicles anyways.
    Both swaybars removed may be a little too spicy…and since it will actually reduce articulation in most cases, it’s not worth removing.
  17. Apr 28, 2025 at 4:42 PM
    ssd2k2
    ssd2k2 Well-Known Member
    Keith
    Minnesota
    2019 Tacoma TRD Sport M/T
  18. Apr 28, 2025 at 4:43 PM
    McSpazatron
    Tinkerer went through the numbers under different configurations. The theory being based on the reality that the rear can fully flex more easily when directly compared to the front IFS. By making the rear more difficult to flex (either by having higher rate springs in the back, or by a swaybar), you are transfering more load to the diagonal corner…essentially, a rear sway bar forces the opposite front corner down.
    That said, I recall him mentioning that the numbers can easily be affected by weight distribution. If the front end is much lighter than the front, the front tires just wont have the weight to stuff the tire.
    edit to add: the articulation numbers he presented were total articulation numbers…not on any individual axle. In other words, even though total articulation is increases with a rear sway…the rear axle will articulate somewhat less. I say somewhat because the 4runner rear axle articulates very well to begin with.
  19. Apr 28, 2025 at 4:51 PM
    Thatbassguy
    James
    Does this prove that overall articulation, front plus rear, is greater with the rear sway bar installed versus removed? Somehow I doubt it.
    With the rear sway bar removed, the rear will just Flex more easily. Eventually the rear will limit out and force the front to flex. So, there is no possible way that there is better overall articulation with the rear sway bar installed versus removed, imo.
  20. Apr 28, 2025 at 5:03 PM
    Thatbassguy
    James
    Sorry, still waiting for a good answer. Please, someone explain to me, how a same suspension with a rear sway bar is going to flex more than the same suspension without a rear sway bar. It might make the front Flex better at first. But, eventually the rear is going to limit out and force the front Flex also. Please discuss!
