Wisconsin Tacomas and bad financial advice
Discussion in 'Mid West' started by Thatbassguy, Dec 19, 2008.
  1. May 7, 2025 at 5:19 PM
    Taco-Grinder
    Dan
    Fond du Lac, WI
    All I did was grind the sides down a bit. It was too wide to fit in the slots.
    Now I need a hot pad and a oven mit.
  2. May 7, 2025 at 5:28 PM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    Unused shop rag...just sayin'.
  3. May 7, 2025 at 5:42 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    I saw about four brand new oven mitts & about a dozen hot pads in the dumpster last week.
  4. May 7, 2025 at 5:44 PM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Opened the starter motor completely.
    Yummay!
  5. May 7, 2025 at 5:48 PM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Used shop rag. Has more seasoning.
    rockindoc75 and bkhlrTaco's like this.
  6. May 8, 2025 at 4:06 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    A used shop rag in my dept is likely to have an extremely low flash point.
    Just sayin'......
    :nuclear:
  7. May 8, 2025 at 7:43 AM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    :devil:
    bkhlrTaco's[QUOTED] likes this.
  8. May 8, 2025 at 7:51 AM
    Pixeltim
    Pixeltim Misunderstood member
    77 square miles surrounded by reality.
    '15 Black DCLB SR5
    Tires, Softopper, fully armored, winch, many pinstripes.
    Rogersolite is a thing...
  9. May 8, 2025 at 8:46 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Does it leave an oily residue? I've tried some low voc washes and they all leave an oily residue. I very much dislike an oily residue left behind.
    CygnusX191 likes this.
  10. May 8, 2025 at 8:56 AM
    Pixeltim
    '15 Black DCLB SR5
    Nooo, it strips off anything and everything. Right down to bare metal. It works great for cleaning blankets, but you have to remember it eats through paint like a hot knife goes through butter!
  11. May 8, 2025 at 9:30 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    I'm on more maintenance today.
    We rarely use the 6th unit but I had a wrap up awhile back. Left the 6th unit about 4" out of phase with the other units. That's a lot....my phase adjustment on the console only has 6mm of movement total. 3mm forward and 3mm back.
    Driveshaft > < 5th/6th slipped. It's actually designed to slip (the 2 aluminum collar on the right) to prevent gears in the units from busting.
  12. May 8, 2025 at 11:34 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    More maintenance at home.
    All clean.
    The copper parts were black. Needed to use some emery cloth to get it off.
    There's a couple small things that can be done to better waterproof it.
    *some assembly required​
  13. May 8, 2025 at 12:28 PM
    OldSchlPunk
    Rich
    East Central Wisco
    Mine's working like a champ now!
  14. May 8, 2025 at 12:29 PM
    OldSchlPunk
    Rich
    East Central Wisco
    And it does wonders for your skin!
  15. May 8, 2025 at 12:49 PM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    :luvya:
  16. May 8, 2025 at 12:50 PM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Now we have a trail spare.
  17. May 8, 2025 at 1:33 PM
    Pixeltim
    '15 Black DCLB SR5
    How many parts were left over after reassembly? :boink:
  18. May 8, 2025 at 1:39 PM
    OldSchlPunk
    Rich
    East Central Wisco
    The ones that really weren't needed! o_O:duh:
  19. May 8, 2025 at 3:14 PM
    sparkystaco
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    You know that the copper windings on the stator have a coating on them rite?
  20. May 8, 2025 at 3:22 PM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    I didn't know until I opened it up.
    It's been awhile since I've opened one.
    I swabbed the tight areas and cleaned everything with this.....
