Wisconsin Tacomas and bad financial advice
Discussion in 'Mid West' started by Thatbassguy, Dec 19, 2008.
  1. May 27, 2025 at 5:56 AM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Ya. That too.
    This was referring to the 285 on a 7" wheel.
  2. May 27, 2025 at 6:23 AM
    Thatbassguy
    Thatbassguy [OP] Sweet or sour?
    James
    '19 T4R, TRDORP, KDSS
    RSG sliders, SOS skids, SOS bumper, wheels, tires, etc
    Ahh, I forgot about that part. :D
    I'm not sure how chain stores are about that sort of thing. I'm sure people have gotten oversized tires installed. But, not sure if they would be weird about putting a tire on a wheel that's too narrow or wide.
    rockindoc75 likes this.
  3. May 27, 2025 at 7:02 AM
    Pixeltim
    Pixeltim Misunderstood member
    77 square miles surrounded by reality.
    '15 Black DCLB SR5
    Tires, Softopper, fully armored, winch, many pinstripes.
    We were, but things kinda wander in here. :annoyed:
  4. May 27, 2025 at 7:11 AM
    Thatbassguy
    James
    I see what you did there. ;)
  5. May 27, 2025 at 7:18 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    If you miss something in a conversation be patient.
    It will probably cycle back around in a few days..
  6. May 27, 2025 at 7:19 AM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    No. The tabs are for holding the alignment once it's set. Otherwise, a pothole or a Tigerton could easily push your alignment. The cams need to turn.
  7. May 27, 2025 at 7:20 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    :welder:
    rockindoc75 and Thatbassguy[OP] like this.
  8. May 27, 2025 at 7:25 AM
    Shellshock
    Iowa
  9. May 27, 2025 at 8:45 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    I need visuals
    Cipher94 and OldSchlPunk like this.
  10. May 27, 2025 at 8:57 AM
    Shellshock
    Iowa
    Aztec120 and bkhlrTaco's[QUOTED] like this.
  11. May 27, 2025 at 2:38 PM
    OldSchlPunk
    Rich
    East Central Wisco
    Yes.
  12. May 27, 2025 at 5:24 PM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    I think I figured it out.
    rear pointed in. front pointed out. Where the shop struggled is left front cam and tie rod jam nut were seized.
    *Emphasis on were.
    Right front also had limited movement.
    I was toed out real bad and couldn't get anymore adjustment until I could get the front cams pointed outward.
    Then with the freed jamnut I was able to straighten the wheel.
  13. May 27, 2025 at 5:49 PM
    OldSchlPunk
    Rich
    East Central Wisco
    With 32s, it doesn't make as much difference, as long as you get it aligned. With my 33s, I'll be looking for the rear cam to be pushing longer and the front pulling shorter. This is to push the ball joint (and in effect the tire) forward for clearance to the cab mount. It also gives you more caster.
    At least, that's how I'm understanding it.
  14. May 27, 2025 at 5:56 PM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    That's what I needed to do. There's still room in the front to move a little more. (if they could). With the 32's it's enough. I have the back maxxed out the other way.
    I used a string running from the back of the truck to line it up.
  15. May 28, 2025 at 5:09 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    I have seen these before but never looked into them because I didn't need to........now I might need to. :D
    I bought myself some time with rigorous applications of PB blaster, over the course of a couple weeks, and a little persistence.
    Had to split the tie rod jam nut to get that to move, so I have some new tie rods coming. (for backup/spare) mine are beat up.
    Aztec120 and OldSchlPunk like this.
  16. May 28, 2025 at 8:20 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
  17. May 28, 2025 at 8:45 AM
    pearing
    pearing Well-Known Member
    Wisconsin
    2015 SR5 quadcab
    I have added a 6000' abandoned tunnel to my Montana itinerary. Wilkes tunnel. Look it up. Water gets about 30+ inches deep. Claustrophobic fun!
  18. May 28, 2025 at 9:07 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    You're determined to fry that starter, aye?
    If you need a spare......my 3rd gen won't fit. :D
  19. May 28, 2025 at 9:12 AM
    Thatbassguy
    James
    Sounds like something the wife will definitely enjoy.
  20. May 28, 2025 at 9:29 AM
    OldSchlPunk
    Rich
    East Central Wisco
    I believe others will relate:
