Wisconsin Tacomas and bad financial advice
Discussion in 'Mid West' started by Thatbassguy, Dec 19, 2008.
  1. Aug 1, 2025 at 9:18 AM
    Supr4Lo
    Supr4Lo Well-Known Member
    Surprise, AZ
    2020 DCSB Offroad MT, Supercharged, NWF Eco-Crawler, 4.88's Locked F&R on 37's
    Did you have any of the front axle nuts off recently? If so the nut might not be tight enough. I had this happen. It allows the disk to wander in and out which opens up the caliper. Then when you step on the brakes one caliper is closed more than the other so it grabs first and pulls the truck.
  2. Aug 1, 2025 at 9:30 AM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Oh good, I'm not the only jackass.
    :rofl:
    See post #49775
  3. Aug 1, 2025 at 9:33 AM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    But if your bearings are good, there shouldn't be any runout, at least not enough to spread the pads. The axle nut doesn't stop that. And, the rotor is held in place by the wheel.
    sparkystaco, Pixeltim and CygnusX191 like this.
  4. Aug 1, 2025 at 9:34 AM
    Supr4Lo
    Surprise, AZ
    Because we've both been there, done that. Lol
  5. Aug 1, 2025 at 9:37 AM
    Supr4Lo
    Surprise, AZ
    Yes, the axle nut holds the hub race and bearing together. So if its not tight the whole hub assembly with the disk can move in and out. Ask me how @bkhlrTaco's and I know this.lol
  6. Aug 1, 2025 at 10:10 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
  7. Aug 1, 2025 at 10:38 AM
    OldSchlPunk
    Rich
    East Central Wisco
    I would've assumed that if the hub is pressed into the bearing that it would be more secure than that. Learn something new every day...
  8. Aug 1, 2025 at 10:42 AM
    Pixeltim
    Pixeltim Misunderstood member
    77 square miles surrounded by reality.
    '15 Black DCLB SR5
    Tires, Softopper, fully armored, winch, many pinstripes.
    I'll have to remember that on Sunday.
  9. Aug 1, 2025 at 10:54 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    I had the nut tightened past the hole in the axle shaft, where the cotter pin goes.
    Fugger was tight. Couldn't tighten it anymore.
    Not sure if the axle was bound or not lined up right....when I went back in to check it I got several more threads worth of tightening out of it.
    Aztec120, sparkystaco and CygnusX191 like this.
  10. Aug 1, 2025 at 12:29 PM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Moving parts on a 5000lb truck.... Sometimes things get lose.
    Bouncing off trees/rocks/submerged obstacles probably doesn't help :D
    Pixeltim likes this.
  11. Aug 2, 2025 at 5:03 AM
    pearing
    pearing Well-Known Member
    Wisconsin
    2015 SR5 quadcab
    Not sure how to respond…. My little princess is pampered. I cannot fathom why she is acting this way
  12. Aug 2, 2025 at 7:06 AM
    Pixeltim
    '15 Black DCLB SR5
    Right? It’s always in the shop being caressed, petted and pampered by the finest craftsman in the Washburn area!
  13. Aug 2, 2025 at 9:09 AM
    Taco-Grinder
    Dan
    Fond du Lac, WI
    He needs to take the truck out for ice-cream.
  14. Aug 2, 2025 at 10:41 AM
    taoist
    taoist taoist
    Pete
    The Baraboo Range
    18 Sport ACLB
    Hey Dan, still sleepin' in the recliner?
  15. Aug 2, 2025 at 10:44 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
  16. Aug 2, 2025 at 11:01 AM
    Taco-Grinder
    Dan
    Fond du Lac, WI
    Yup, being on my side still hurts.
    Damn thing is, we got a new mattress when I was in the hospital.
    The dog has taken over my side of the bed.
  17. Aug 2, 2025 at 11:47 AM
    McSpazatron
    McSpazatron Well-Known Member
    I think sparky also had something similar…or maybe it was loose wheel bolts that caused the same effect on the brakes.
  18. Aug 2, 2025 at 11:51 AM
    McSpazatron
    Man on a mission!
  19. Aug 2, 2025 at 12:24 PM
    McSpazatron
    Any solar geeks care to chime in on this panel? Thinking or mounting this on my roof rack permanently to keep my battery generator box charged up without relying on having to drive several hours.
    Does this “shade flux” technology solve any real problems compared to their normal mono-crystaline panel? Can a little bit of shade actually cause the regular panels to overheat and drop off charging power like they are claiming?
    Any other thoughts or advice?
    This is the shadow flux model:
    https://www.renogy.com/120w-shadowf...el/?searchid=5059675&search_query=Shadow+flux
    This is the normal model: https://www.renogy.com/renogy-16bb-...4376119&ca=486720912&pl=bing&r_u_id=151300468
  20. Aug 2, 2025 at 12:41 PM
    taoist
    taoist taoist
    Pete
    The Baraboo Range
    18 Sport ACLB
    Was 6-8 weeks before I got out of the recliner. Hang in there!
