Wisconsin Tacomas and bad financial advice
Discussion in 'Mid West' started by Thatbassguy, Dec 19, 2008.
  1. Sep 3, 2025 at 3:55 AM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    I use my eyes.
    I don't know how close I am but it drives smooth.
    CygnusX191[QUOTED] likes this.
  2. Sep 3, 2025 at 4:32 AM
    pearing
    pearing Well-Known Member
    Wisconsin
    2015 SR5 quadcab
    As any good ASSMAN should!
  3. Sep 3, 2025 at 4:50 AM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Close enough then lol
    bkhlrTaco's[QUOTED] likes this.
  4. Sep 3, 2025 at 5:16 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    I spent about 6hours under the truck, one day, understanding how everything moved. Caster. Camber. Toe.
    Not as tricky as it seems, once you know what moves what.
    Now I have to raise the perch on my front shocks so I'll probably need to adjust camber and toe after.
  5. Sep 3, 2025 at 5:22 AM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    This is one area where actual classes can really open up the eyes of the shop gurus who have "always done it that way" lol
    The fact that you took initiative to learn the movements and results of said movements puts you in front of 90% of tire shop techs
    Why are you raising your shock perch?
  6. Sep 3, 2025 at 5:28 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    The new bumper weighs about the same as the hidden receiver but the extra weight of having the winch on, full time, brings me down a 1/2".
    I'm on setting 4 of 6.
    CygnusX191 likes this.
  7. Sep 3, 2025 at 6:30 AM
    Pixeltim
    Pixeltim Misunderstood member
    77 square miles surrounded by reality.
    '15 Black DCLB SR5
    Tires, Softopper, fully armored, winch, many pinstripes.
    It'll ride better with the extra couple pounds!
  8. Sep 3, 2025 at 6:36 AM
    Taco-Grinder
    Dan
    Fond du Lac, WI
    If, you still have a sway bar, remove it.
  9. Sep 3, 2025 at 6:40 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Ya it rides better but with that extra rake I get a slight nose dive when braking.
    :smack:
    I got rid of that a couple years ago.
    Still got it if you want it. lol
  10. Sep 3, 2025 at 6:53 AM
    OldSchlPunk
    OldSchlPunk I'm not sick, but I'm not well
    Rich
    East Central Wisco
    '17 AC OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    Pat's got another convert.
  11. Sep 3, 2025 at 6:57 AM
    Taco-Grinder
    Dan
    Fond du Lac, WI
    I'm running out of room for old Tacoma parts.
    Flatbed and 35's next.:bowdown:
  12. Sep 3, 2025 at 8:36 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    How much longer before you can build a complete truck from old parts? :D
  13. Sep 3, 2025 at 8:45 AM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Welcome to lifted life. With your caster move forward to fit larger tires. You're always going to have a bit of nose dive when braking. And the higher you go, the more pronounced that will be.
    The way I see it, the lower you can go without rubbing the better. Generally A good rule when off-roading to keep your center of gravity low
