Wisconsin Tacomas and bad financial advice
Discussion in 'Mid West' started by Thatbassguy, Dec 19, 2008.
  1. Sep 14, 2025 at 6:26 PM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    No but I look at pictures of that at work too.
    That's at the Trollhaugen Ski Resort.
  2. Sep 14, 2025 at 6:27 PM
    pearing
    pearing Well-Known Member
    Wisconsin
    2015 SR5 quadcab
    Some more images from today. I really liked that place. Very different from Tigerton. Tigerton is like Moab (not all obviously) in that it is "slick" rock and fairly low consequence. Iron Range? Lots of "put on your big boy pants" and the rock is Hard, sharp and unforgiving. Liked it a lot.
  3. Sep 14, 2025 at 6:41 PM
    ssd2k2
    ssd2k2 Well-Known Member
    Keith
    Minnesota
    2019 Tacoma TRD Sport M/T
    Low consequence is what I enjoy, especially since my truck is also my daily driver, lol. So next time y'all go to Tigerton I'd join for that.
    If I had an old Jeep that I could beat to hell I think Iron Range would appeal to me more.
  4. Sep 14, 2025 at 6:49 PM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    There's plenty of 'low consequence' sharp turns on steep grades that'll keep your knuckles white and your sphincter tight.
    sparkystaco and ssd2k2 like this.
  5. Sep 14, 2025 at 6:52 PM
    Thatbassguy
    Thatbassguy [OP] Sweet or sour?
    James
    '19 T4R, TRDORP, KDSS
    RSG sliders, SOS skids, SOS bumper, wheels, tires, etc
    Seems like "big boy pants" = "I can afford to break my truck" in this scenario.
    I'm still interested in checking it out sometime, though.
  6. Sep 14, 2025 at 6:56 PM
    pearing
    Wisconsin
    2015 SR5 quadcab
  7. Sep 14, 2025 at 6:58 PM
    ssd2k2
    Keith
    Minnesota
    I'm fine with that, it's large sharp rocks I don't like and deep water too.
    Being in tight trees or near steep edges don't bother me much.
    It's funny because I hate rock gardens when mountain biking as well
  8. Sep 14, 2025 at 6:59 PM
    pearing
    Wisconsin
    2015 SR5 quadcab
    No... There are going to be consequences; but, go slow and use a spotter. Or put on 40's and a LS.
    sparkystaco and bkhlrTaco's like this.
  9. Sep 14, 2025 at 7:01 PM
    pearing
    Wisconsin
    2015 SR5 quadcab
    Yes. Those to. Had at least one switch back today that was a multi point turn on a steep descent.
  10. Sep 14, 2025 at 7:03 PM
    Thatbassguy
    James
    What consequences? If you're talking body damage, then that would fall into the "I can afford to break my truck" category.
    Why an LS? There are easier ways to get more power.
    Although, power has yet to be an issue for anything I've wanted to do.
  11. Sep 14, 2025 at 7:19 PM
    ssd2k2
    Keith
    Minnesota
    Being a manual transmission driver I find I want lower gear ratios than more power, 1st lo doesn't feel slow enough sometimes.
    Burning out my clutch is always on my mind off roading especially going in reverse to get out of something.
    But that is an expensive fix either with a new transmission, I believe the 4th gen has better gear ratios and fits without modification. Or re gearing my diffs.
  12. Sep 14, 2025 at 7:23 PM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    In the AT, I've been using S mode in 4lo and setting it to not go above 3rd.
    Edit: I don't know the specifics behind what it's doing in S (that might require reading the owners manual) but the truck acts like my riding mower with the hydrostatic drive....the transmission will do the work of slowing down without braking.
  13. Sep 14, 2025 at 7:54 PM
    Thatbassguy
    James
    Toyota doesn't give us a great crawl gear. I think that's why dual transfer cases are such a nice upgrade for manual transmission tacos in particular. If money were no object, I'd add one to the 4Runner. Otherwise, a regear is a good option.
    S mode limits the top gear to whatever you select. Plus. I believe it makes the transmission engine brake more, as you said.
    I usually do 4lo and S1 on more complicated obstacles and steep descents. Otherwise, I use 4lo and S3 a lot, same as you mentioned.
    sparkystaco and ssd2k2[QUOTED] like this.
  14. Sep 14, 2025 at 8:03 PM
    ssd2k2
    Keith
    Minnesota
    Here is the guy that upgraded transmissions. About $4k.
    Regear would probably cost the same.
    A Marlin taco box would be awesome but even more money
    https://www.tacomaworld.com/threads/swapping-the-rc62f-manual-transmission-for-the-rc60f.849671/
  15. Sep 14, 2025 at 8:06 PM
    Pixeltim
    Pixeltim Misunderstood member
    77 square miles surrounded by reality.
    '15 Black DCLB SR5
    Tires, Softopper, fully armored, winch, many pinstripes.
    I thought it would be bigger.
