Wisconsin Tacomas and bad financial advice
Discussion in 'Mid West' started by Thatbassguy, Dec 19, 2008.
  1. Nov 11, 2020 at 7:01 AM
    #5481
    Supr4Lo
    Supr4Lo Well-Known Member
    Surprise, AZ
    2020 DCSB Offroad MT, Supercharged, NWF Eco-Crawler, 4.88's Locked F&R on 37's
    My rivets did not come out so easy. I first cut the heads off then tried using my big air hammer to knock them out, which didn't work for any but 1. I bought the drill bits (1/4" and 1/2") with my HH order and ended up using them to drill into the rivet then knocking them out. If you need to do it this way don't drill all the way through the rivet just far enough that you are about the same depth as the frame is thick, then they knocked out easy. I did this install twice now, once on my 2018 that I saved the OEM hangers and then reinstalled them when I traded for my 2020. On my 2020 I cut the OEM hangers off (didn't plan on ever using them again) to make it easier to get to the bottom rivets. Didn't find it necessary to remove the leaf springs to do the job but it would have made it a little easier. It's not a hard job for 1 person, took me about 4 hours my first time an about 3 hours my second time.
    Another tip once you remove the stock hangers clean and paint the area if the frame needs it. I also put fluid film on the frame and hangers before installing to help mitigate rust.
    ARoman83[QUOTED] and CygnusX191 like this.
  2. Nov 11, 2020 at 7:13 AM
    #5482
    yoopersteeze
    yoopersteeze Fake it til you make it
    WI
    2017 Magnetic Gray Metallic Tacoma TRD OR MT
    Thank you to all veterans for your service and sacrifice! :oldglory:
  3. Nov 11, 2020 at 9:18 AM
    #5483
    WiscoPat
    WiscoPat One does not simply purchase a Ridgeline
    Pat
    Wisconsin
    2019 TRDOR Tacoma 1995 JDM 80 Series
    Mall Rated
    Yep that's one of the few downsides to living in WI, the absolute hell vehicles go through due to winter road treatments. I've been through two winters and haven't had that extensive of rust, thankfully. The most significant area so far was on the front of the LCAs.
    Worst case scenario, I'll just have to keep making pipeline trips to build up coats of mud - that'll do the trick, I'm sure.
  4. Nov 11, 2020 at 9:59 AM
    #5484
    Shellshock
    Iowa
    Thats the strategy i rely on. A protective coating of dirt
  5. Nov 11, 2020 at 10:01 AM
    #5485
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    I know a few people down here who have a protective coating of Tennessee clay that gets refreshed every year.
  6. Nov 11, 2020 at 10:07 AM
    #5486
    Sasquatch3153
    Sasquatch3153 Sassy Squatch
    Josh
    Illinois
    2010 ACLB OR
    :anonymous:
  7. Nov 11, 2020 at 10:19 AM
    #5487
    Thatbassguy
    Thatbassguy [OP] Sweet or sour?
    James
    '19 T4R, TRDORP, KDSS
    RSG sliders, SOS skids, SOS bumper, wheels, tires, etc
    This strategy seems to be backfiring on my sliders. I have top plates, and there is rust forming in the corners underneath where the tube meets the plate. :(
    I'll clean it up as good as possible and repaint it. If it happens again, I might just remove the plates.:notsure:
    CygnusX191[QUOTED] likes this.
  8. Nov 11, 2020 at 10:41 AM
    #5488
    Adventure4x4
    Adventure4x4 Well-Known Member
    Adam
    San Antonio, TX
    2013 TRD off road MT
    My rust prevention is a separate vehicle haha
  9. Nov 11, 2020 at 11:07 AM
    #5489
    ARoman83
    ARoman83 Well-Known Member
    Alex
    Wisco
    '15 TRD OR DCSB PreRunner
    Only legal stuff
    Thanks for the input fellas! I think It shouldn't be too bad, I have taken my rear apart several times recently, so I may go that route and clean up that area before winter comes!
    CygnusX191 and Supr4Lo[QUOTED] like this.
  10. Nov 11, 2020 at 11:10 AM
    #5490
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    And then WD-40 it before it snows
  11. Nov 11, 2020 at 12:24 PM
    #5491
    Sasquatch3153
    Josh
    Illinois
    2010 ACLB OR
    Same :D
  12. Nov 11, 2020 at 1:20 PM
    #5492
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Yeah yeah yeah
    Sasquatch3153[QUOTED] likes this.
  13. Nov 11, 2020 at 1:34 PM
    #5493
    Camerasandcoffee
    Camerasandcoffee 900hp short of 1000hp
    Jonathan
    Racine WI.
    2019 Trd Sport
    Relentless Fab hybrid bumper, 2.5” Dobinsons IMS lift, RCI skids and sliders, block heater. Painted FJ Steelies. Was trying to keep it stock, now slowly building for the Wisconsin trails.
    I’m trying out this PB blaster corrosion stop. Seems to stay pretty sticky and doesn’t wash off easily.
    I’ve only had it on one winter so far and it seems to be holding up well.
    I recently gave the truck a good pressure washing underneath and it didn’t wash off.
    Granted I was using the 40deg nozzle from a distance as to not push water into anything sensitive.
  14. Nov 11, 2020 at 1:50 PM
    #5494
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Recoat every year I would think for best results
    Thatbassguy[OP] likes this.
  15. Nov 11, 2020 at 2:14 PM
    #5495
    Camerasandcoffee
    Jonathan
    Racine WI.
    2019 Trd Sport
    thats what I’m thinking as well. I touched up a few spots a few weeks back in preparation for the winter salt ahead
  16. Nov 11, 2020 at 2:30 PM
    #5496
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    I plan on WD-40 before any snowstorms this year
  17. Nov 11, 2020 at 2:38 PM
    #5497
    Shellshock
    Iowa
    I plan on staying home :rofl:
  18. Nov 11, 2020 at 2:52 PM
    #5498
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    DoT life
    GQ7227 likes this.
  19. Nov 11, 2020 at 7:12 PM
    #5499
    Camerasandcoffee
    Jonathan
    Racine WI.
    2019 Trd Sport
    Finally got around to putting some video together.
    I definitely need to work on my vlogging and putting together a narrative via video.
    https://youtu.be/lqPLu0PKN3o
  20. Nov 11, 2020 at 7:49 PM
    #5500
    Thatbassguy
    James
    Nice!!
    CygnusX191 likes this.
