Wisconsin Tacomas and bad financial advice
Discussion in 'Mid West' started by Thatbassguy, Dec 19, 2008.
  1. Aug 25, 2022 at 5:25 AM
    truckalter
    truckalter Well-Known Member Vendor
    Luke
    Waynesville, NC
    Thanks! We appreciate the support!
  2. Aug 25, 2022 at 5:35 AM
    Shellshock
    Iowa
    Not always OEM but usually aftermarket you can
  3. Aug 25, 2022 at 5:48 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    I still have to get it done. I was in the process of getting all the sound deadening ordered and together to do the door while I have it open and work my way around the interior.
    That and being busy and being hot asf out hasn't helped. Got some things to do this weekend. Might try giving it a go but I got a few things going on already.
  4. Aug 25, 2022 at 6:02 AM
    Taco-Grinder
    Dan
    Fond du Lac, WI
    We were having the same problem with our 2011 Rav4 rear passenger door. The fob would not unlock the door. This was last April. So I did what everyone does, an internet search. I was about to tackle the problem and it started working. That was back in June. It's been working fine since. :notsure:
  5. Aug 25, 2022 at 6:14 AM
    Pixeltim
    Pixeltim Misunderstood member
    77 square miles surrounded by reality.
    '15 Black DCLB SR5
    Tires, Softopper, fully armored, winch, many pinstripes.
    Procrastination has often saved my ass too!
  6. Aug 25, 2022 at 6:27 AM
    Thatbassguy
    Thatbassguy [OP] Sweet or sour?
    James
    '19 T4R, TRDORP, KDSS
    RSG sliders, SOS skids, SOS bumper, wheels, tires, etc
    I found some threads where people have just replaced the motor. It's like $6 VS like $180 for the assembly (approximately, I didn't shop around much).
    Let me know if you get around to it. I suppose there are probably some YouTube videos I could check out in the meantime.
    I could have done an internet search. But, why bother, when I can just ask you guys? :D
  7. Aug 25, 2022 at 6:37 AM
    Taco-Grinder
    Dan
    Fond du Lac, WI
    :thumbsup:
  8. Aug 25, 2022 at 7:04 AM
    Pixeltim
    '15 Black DCLB SR5
    It can't be all that hard. Just need to confirm it's the motor instead of some obscure electronic part that is failing
    CygnusX191 likes this.
  9. Aug 25, 2022 at 8:46 AM
    Pixeltim
    '15 Black DCLB SR5
    This thread might be helpful:
    https://www.tacomaworld.com/threads/tonneau-favorites.776013/
  10. Aug 25, 2022 at 11:12 AM
    doyle563
    doyle563 Well-Known Member
    Jack
    Waukesha, WI
    2016 White Access Cab TRD Off Road
    Anyone have a recommendation for brake pads and rotors? Mine are due to be replaced at 120k miles.
    Thatbassguy[OP] and CygnusX191 like this.
  11. Aug 25, 2022 at 1:07 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    Big brake kits if you have the coin and plan on doing things that need beefier brakes to stop from falling off the mountain / crashing at the end of the race track. Stoptech, BBK, Wilwood, etc. Be prepared to :spending:
    4Runner big brake swap is the cheap option. I'm 2nd gen so I don't know all the 3rd gen specifics but search around, they are popular threads.
    If you want to stay the same size and just replace parts I think the hot setup used to be Stoptech cryo rotors. Pads: OEM or ceramic if you don't want lots of dust; Hawk/EBC semi-metallic if you want more bite and dust. Beyond that, choosing brake pads types/brands is like asking what your preferred flavor of motor oil is so I'm gonna leave that alone...
    Someone feel free to correct me if I'm wrong.
  12. Aug 25, 2022 at 1:30 PM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Look for the friction number/coefficient. You want 33% or 1/3 "stopping power".
    For heavy off roading, bias closer to 40.
    EBC Greenstuff (and their other products) are kickass. Powerstop has become a big player recently. Nothing wrong with OEM either.
    Get dual disk rotors (like you have). If possible, get your stuff as a kit from the same manufacturer.
    Always recommend a brake bleed and fluid replacement too. Since you're an Off Road, you can use your ATRAC booster for a one man bleed job.
  13. Aug 25, 2022 at 6:10 PM
    Camerasandcoffee
    Camerasandcoffee 900hp short of 1000hp
    Jonathan
    Racine WI.
    2019 Trd Sport
    Relentless Fab hybrid bumper, 2.5” Dobinsons IMS lift, RCI skids and sliders, block heater. Painted FJ Steelies. Was trying to keep it stock, now slowly building for the Wisconsin trails.
    So every once in awhile something comes across the radar that makes you question everything you think you knew.
    This is not that thing.
    I present the Bripe, or Brew-pipe.
    Question is: Is this the ultimate in overland coffee making for the kool kids? Or just a crack addict coffee maker?
    I will leave it to you to decide.
    https://youtu.be/tltBHjmIUJ0
  14. Aug 25, 2022 at 7:48 PM
    wi_taco
    Adam
    SE Wisconsin
    I watched that whole thing. I share in your confusion on what this is. Generally that means it’s a gimmick and utter rubbish. I’ll stick with my Aeropress for now.
  15. Aug 25, 2022 at 8:01 PM
    Realoldfatguy
    Realoldfatguy Well-Known Member
    Bob
    Iowa
    2017 DCSB TRD OR MT QUICKSAND
    RokBlokz Rally Flaps Toyota running boards
    This does seem weird. Shows on Amazon for $100 but other places $25.
    I’ll stick with my higher volume French press.
    Stanley Adventure All-in-One, Boil + Brewer French Press Coffee Maker - 32oz BPA Free Campfire Coffee Pot Heats up Tea or Soup - Great for Camping and Travel – Dishwasher Safe, https://www.amazon.com/dp/B07L6MLC6J
  16. Aug 25, 2022 at 8:03 PM
    doyle563
    Jack
    Waukesha, WI
    Thanks guys! Just ordered EBC Greenstuff pads and OE premium rotors from Summit. I'm not familiar with using ATRAC or crawl control to bleed the brakes, would you mind posting a link? searchbar isn't finding it for me
    CygnusX191[QUOTED] likes this.
  17. Aug 25, 2022 at 8:32 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    I only made it to him sitting on that log touting his crack pipe while looking uncomfortable (not sure what was up with the log) and realized that the way he was dressed, he's never been any closer to the woods than the back deck of his "friends" house.
    Realoldfatguy, wi_taco and CygnusX191 like this.
  18. Aug 25, 2022 at 9:18 PM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    It's not using the systems it's the fact that your 8-track relies on your electronically boosted brake booster.
    https://www.tacomaworld.com/threads...road-mt-brake-bleeding-override-issue.610046/
    Post #5
  19. Aug 26, 2022 at 6:48 AM
    BookieBob
    BookieBob Beer Drinker
    Racine,Wisconsin
    2021 Silver Sky TRD Sport 4WD MT
    I can see trying to explain this to the Illinois State Trooper on my way to work after he pulls me over for doing 100mph!
  20. Aug 26, 2022 at 7:14 AM
    Pixeltim
    '15 Black DCLB SR5
    Wait, your Tacoma can do 100?
