Wisconsin Tacomas and bad financial advice
Discussion in 'Mid West' started by Thatbassguy, Dec 19, 2008.
  1. Nov 11, 2022 at 7:45 AM
    WiscoTaco4x4
    WiscoTaco4x4 Well-Known Member
    Brady
    2015 SR5 ACLB 4x4
  2. Nov 11, 2022 at 7:48 AM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    I bought new ones for mine at Advance Auto Parts but only because I needed them quickly. Pacific P/N PMV-C11A, Advance Auto P/N 40005. Looks like the price increased now - these will work but you will pay for it (but still less than a Toyota dealer who charge like $100 per sensor, yikes).
    Pacific makes the OEM sensors for Denso. Denso P/N is 550-0103. I believe RockAuto has them for a decent price if memory serves me right. Other companies make equivalents, just make sure you get ones that are 315MHz and not the 400MHz or whatever units because those are for 3rd gens.
    Quick edit: Also be cautious if ordering from RockAuto or anywhere else - there are two different 315MHz models available, one is for steel wheels the other is alloy/aluminum. Stem angles are different due to the shape/construction of the wheels.
  3. Nov 11, 2022 at 7:50 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    First link is a pack of 4 and the second one is just a single sensor
    sparkystaco and CygnusX191 like this.
  4. Nov 11, 2022 at 7:51 AM
    WiscoTaco4x4
    Brady
    2015 SR5 ACLB 4x4
    thanks I just ordered the wheels today so I have a couple days so I can wait thanks guys for the help
  5. Nov 11, 2022 at 10:31 AM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Triple check your wheel type and what year your truck is. In 2020 they changed the TPMS sensor module so older sensors won't work on newer trucks. Although the new trucks can self program so you don't have to pay a dealer to techstream that shit
  6. Nov 11, 2022 at 10:34 AM
    Supr4Lo
    Supr4Lo Well-Known Member
    Surprise, AZ
    2020 DCSB Offroad MT, Supercharged, NWF Eco-Crawler, 4.88's Locked F&R on 37's
    Do you mean from pre 2016? My oem TPMS sensors from my 2018 that were in my SCS wheels work fine on my 2020. But I did have to program them in With Techstream. Maybe that's the difference?
    CygnusX191[QUOTED] likes this.
  7. Nov 11, 2022 at 11:11 AM
    wi_taco
    Adam
    SE Wisconsin
    Based on @WiscoTaco4x4 's profile info they have a 2015 model just like me, which is why I mentioned the specific MHz thing. 2nd gen (i.e. up to 2015) uses 315MHz, 3rd gen (2016+) uses 433MHz.
    None of the 2nd gens to my knowledge will self-reprogram the TPMS positions, you need to have the tire shop do it or buy a TPMS tool like I did but that's way overkill.
    CORRECTION: I AM WRONG. Went back to find relevant links and it seems 3rd gen uses same frequency? Weird...I know 3rd gen TPMS don't work for 2nd gen and vice versa, but now I don't remember why if the MHz are the same. I'm missing something here...
  8. Nov 11, 2022 at 11:17 AM
    Supr4Lo
    Surprise, AZ
    Ah yes, keep forgetting he's 2nd gen. Two many conversations going on at once for my feeble mind to keep track of.
  9. Nov 11, 2022 at 11:19 AM
    wi_taco
    Adam
    SE Wisconsin
    I just edited my post as well, I'm wrong. I can't figure out or find the right links/pages but I'm wrong on the MHz stuff. Now I can't find my old notes on the subject and feels like I"m taking crazy pills.
    That being said I am absolutely 100% correct on those part numbers I shared because I'm running them right now and if they didn't work I'd have a big annoying light on my dash.
  10. Nov 11, 2022 at 11:20 AM
    Supr4Lo
    Surprise, AZ
    Could it be the range of the ID codes? Wasn't there a difference in the amount of digits or something like that?
    CygnusX191 and wi_taco[QUOTED] like this.
  11. Nov 11, 2022 at 11:27 AM
    wi_taco
    Adam
    SE Wisconsin
    That could be the case. Honestly I don't remember and I can't find the answers right now. Gonna bug me until I find it.
  12. Nov 11, 2022 at 11:46 AM
    wi_taco
    Adam
    SE Wisconsin
    OK I did some more sleuthing and I'm out of time, have to do some actual work for a change...
    Anyways all I can find is one line in an old post that says "3rd Gens won't work on 2nd Gens because of the ID#'s on the sensors are not compatible." If you search for parts on the parts.toyota.com website they are indeed different part numbers for 2nd and 3rd gen, and if you look closely the Pacific part number is different. So while they both operate on 315MHz, there is some other binary bits inside of the programming that stop them from working across generations.
    A bit bizarre given they both have the same functionality, but like most other things in the world it was probably done so Toyota could earn a few extra bucks for service or something like that.
    CygnusX191 likes this.
  13. Nov 11, 2022 at 1:30 PM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Nothing to do with earning extra bucks, and everything to do with having tighter encryption for less interference, wider programming capability (newer vehicles you can actually set your preferred baseline pressure, like when it's cold and such) and keeping things congressionally compliant.
    wi_taco[QUOTED] likes this.
  14. Nov 11, 2022 at 2:09 PM
    Tim v
    Tim v Well-Known Member
    Tim
    SE. Wisconsin
    2014 White Tacoma access cab
    Just came from HF Badland's 12k synthetic rope 412.00 sitting under the table damaged box Wakesha
    I looked at 4xInnovations for sliders but 35.00 to pick them up? Got SOS delivered for 800 to my door 2014 ac, was told they will fit a dc(S)b
  15. Nov 11, 2022 at 3:07 PM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    ACLB and DCSB use the same frames, so yes they will fit
  16. Nov 11, 2022 at 3:19 PM
    Tim v
    Tim
    SE. Wisconsin
    Just put that out there so everyone will know
  17. Nov 11, 2022 at 3:27 PM
    WiscoTaco4x4
    Brady
    2015 SR5 ACLB 4x4
    I actually havent bought any TPMS Sensors yet because I just got back from school and the gym. We are going to mount the tires and rims and do all of that in my auto class. There is a tire changer and balancer. I am assuming that we have TPMS tool because our shop has almost anything you can think of but then again Im not 100%
  18. Nov 11, 2022 at 4:38 PM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Double check. Nothing like ruining the inner bead of a tire because it was mounted and un mounted and remounted 5 times in a day
    wi_taco likes this.
  19. Nov 11, 2022 at 4:50 PM
    pearing
    pearing Well-Known Member
    Wisconsin
    2015 SR5 quadcab
  20. Nov 11, 2022 at 5:16 PM
    wi_taco
    Adam
    SE Wisconsin
    Just gonna leave this here… :anonymous:
