Wisconsin Tacomas and bad financial advice
Discussion in 'Mid West' started by Thatbassguy, Dec 19, 2008.
  1. Dec 27, 2022 at 2:14 PM
    LarryDangerfield
    LarryDangerfield One Larry a day keeps the money away ™ Moderator
    Tyler
    Northern Wisconsin
    Black 2020 Nightshade Edition 4Runner
    Oh there will be some mods all right
    You are correct! The last 2 nature pics are from there :)
    CygnusX191 likes this.
  2. Dec 27, 2022 at 2:15 PM
    pearing
    pearing Well-Known Member
    Wisconsin
    2015 SR5 quadcab
    Made some changes today. Front is complete-3" lift and the truck sits flat now! The rear is also done-didn't get a picture... but I did take a picture of the thread certs I used to mount the overflow tank mount on the frame. Alignment Friday morning. I will get some pictures of the stance soon...
  3. Dec 27, 2022 at 2:26 PM
    Shellshock
    Iowa
    depends. sometimes the wiring is there (Toyota sometimes just uses the same harness instead of making a diff one). otherwise you gotta run some wires which still isn't that hard.
  4. Dec 27, 2022 at 4:49 PM
    WiscoPat
    WiscoPat One does not simply purchase a Ridgeline
    Pat
    Wisconsin
    2019 TRDOR Tacoma 1995 JDM 80 Series
    Mall Rated
    Teal coil gang!
    I bet you're chomping at the bit to get out and play.
  5. Dec 27, 2022 at 5:00 PM
    pearing
    Wisconsin
    2015 SR5 quadcab
    Yessssss... Truck doesn't handle very well at the moment as the TC UCA's have messed up the alignment pretty badly. Friday that gets fixed and then I can start figuring out settings for the rear shocks. Front too I guess. Looking forward to an improved ride on washboard.
  6. Dec 27, 2022 at 5:21 PM
    pearing
    Wisconsin
    2015 SR5 quadcab
    Lots of depends... If the factory harness is there, pretty easy. I would suggest seeing about purchasing the factory mount as well. You can make something is my guess, or maybe some light manufacturers provide a mount but my experience has been that they like to see something there already. Cutting the hole is probably done best with a hole saw. If you have to wire your own, well... It will take a couple of days is my guess and I would start looking in TC if anyone has done this before and written it up. I have not. Wiring will be straight forward, but you will need a relay and wires going into the cab for a switch as well as a power source. You will want to make a decision as to whether they will be tied to low beam lights or independent and wire appropriately. Fun project.
  7. Dec 27, 2022 at 5:28 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    If you don't have wiring let me know I have an aftermarket wiring kit complete with directions.
  8. Dec 27, 2022 at 5:50 PM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Hard
    Easy
  9. Dec 27, 2022 at 7:14 PM
    WiscoTaco4x4
    WiscoTaco4x4 Well-Known Member
    Brady
    2015 SR5 ACLB 4x4
    I was just kinda curious idk if I would do it because it probably would be more asthetic than anything because I am starting to get knit picky with little things on my truck and one of them is that there isn’t fog lights.
    sparkystaco and CygnusX191 like this.
  10. Dec 27, 2022 at 7:51 PM
    sparkystaco
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    I noticed on my truck the fogs did a lot to fill in between the headlights and the truck especially after I upgraded to 50w lites on my aftermarket bumper.
  11. Dec 27, 2022 at 8:31 PM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    Dropped a note inquiring on the status of my bumper order. The reply is that it should be in the batch that's anticipated to finish later this week.
  12. Dec 27, 2022 at 10:07 PM
    Stoney Ranger
    Stoney Ranger Pizza Cutters, Baby... and Lockers? Pffft
    Dave
    Driftless Area
    '18 Nauti Blue 4Runner SR5
    Full Armor-F/R Bprs Winch-ALF-Stickers
    Lookin' good. Can't wait for March to get here.
  13. Dec 28, 2022 at 8:49 AM
    Shellshock
    Iowa
  14. Dec 28, 2022 at 9:38 AM
    pearing
    Wisconsin
    2015 SR5 quadcab
    Balmy 28 degrees today. CR-V due for an oil change... Life in northern Wisconsin.
  15. Dec 28, 2022 at 9:41 AM
    Taco-Grinder
    Dan
    Fond du Lac, WI
    Looks real nice. Should help with your, bounce this, bounce that, style of driving.
    That Teal color sure is pretty.
  16. Dec 28, 2022 at 9:41 AM
    pearing
    Wisconsin
    2015 SR5 quadcab
    So, as promised the new stance. She has settled a bit-dang those TC uniballs are stiff! Played hell aligning them yesterday. Like it -much more level. Also an image of the rear installation. Used thread certs on both sides for the tanks.
  17. Dec 28, 2022 at 10:08 AM
    pearing
    Wisconsin
    2015 SR5 quadcab
  18. Dec 28, 2022 at 10:09 AM
    Thatbassguy
    Thatbassguy [OP] Sweet or sour?
    James
    '19 T4R, TRDORP, KDSS
    RSG sliders, SOS skids, SOS bumper, wheels, tires, etc
    Nice! I get to put a new driveshaft in my boy's Element tomorrow. :bananadead:
    At least it will be "warm".
  19. Dec 28, 2022 at 10:19 AM
    Shellshock
    Iowa
    It’s at least warm enough here for things to melt a bit. Parked outside to thaw out the truck. Might try and get it washed before it gets below freezing again.
  20. Dec 28, 2022 at 10:27 AM
    Supr4Lo
    Supr4Lo Well-Known Member
    Surprise, AZ
    2020 DCSB Offroad MT, Supercharged, NWF Eco-Crawler, 4.88's Locked F&R on 37's
    Changing diff oil in the front and while looking things over I found a small puncture on the passenger inner CV boot. Yay!! Looking forward to that job....
  21. Dec 28, 2022 at 10:27 AM
    Taco-Grinder
    Dan
    Fond du Lac, WI
    I took my truck to Kwik Trip today for a wash. Truck was black again.
    Someone from the store had to come out and reset the wash. The Jeep in front of me screwed things up.
