Wisconsin Tacomas and bad financial advice
Discussion in 'Mid West' started by Thatbassguy, Dec 19, 2008.
  1. Jan 8, 2023 at 3:43 PM
    WiscoPat
    WiscoPat One does not simply purchase a Ridgeline
    Pat
    Wisconsin
    2019 TRDOR Tacoma 1995 JDM 80 Series
    Mall Rated
    So, as I've mentioned I've been gathering up a more comprehensive tool set and organization for said tools. I figured this will be a lifelong hobby turned passion, so might as well dive in.
    Finally got my toolbox in today and have started playing around with configuration - it'll be good to put these things and more to use very soon. I thought some of you may appreciate this:
    Sockets/bits are all Tekton, ratchets/extensions are Koken, and pliers/picks are NWS with Sonic foam/branding.
  2. Jan 8, 2023 at 3:48 PM
    Thatbassguy
    Thatbassguy [OP] Sweet or sour?
    James
    '19 T4R, TRDORP, KDSS
    RSG sliders, SOS skids, SOS bumper, wheels, tires, etc
    There's something about a well organized tool drawer that makes me feel warm and fuzzy. Looks great!
  3. Jan 8, 2023 at 3:52 PM
    WiscoPat
    Pat
    Wisconsin
    Mall Rated
    Same man, same - thanks! Knowing where things are and getting to them easily is huge.
  4. Jan 8, 2023 at 3:58 PM
    Thatbassguy
    James
    Definitely! It can make such a difference working on a project. Saves time and frustration.
  5. Jan 8, 2023 at 4:04 PM
    pearing
    pearing Well-Known Member
    Wisconsin
    2015 SR5 quadcab
    I agree.
  6. Jan 8, 2023 at 4:19 PM
    Taco-Grinder
    Dan
    Fond du Lac, WI
    I was in Sheboygan today. My family did our Christmas at my brother's house.
    Lots of venison in the yard.
  7. Jan 8, 2023 at 4:22 PM
    pearing
    Wisconsin
    2015 SR5 quadcab
    That is definitely the OCD kicking in... Looks FANTASTIC! There was a time in my life when my tool box(es) looked like that...
  8. Jan 8, 2023 at 4:23 PM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    That's nice. Way better than my work stuff. Of course, I have no shop space for anything even half this size lol.
    We're all hoping the old guy retires so we gain a bay back and can get some breathing room
  9. Jan 8, 2023 at 4:34 PM
    rubbersidedown
    rubbersidedown Well known voider of warranties
    Dean
    WI
    2020 Tacoma TRD OR Long Boi Voodoo Blue
    Looks great! I wish I could be that organized. I still have some tools on a cart from when I did my suspension upgrade. Had to use a couple yesterday for an oil change on the truck and they got put away afterwards. And I keep tripping on that damn sway bar I took off. :der:
  10. Jan 8, 2023 at 4:35 PM
    Taco-Grinder
    Dan
    Fond du Lac, WI
    How the ride without Sway bar?
  11. Jan 8, 2023 at 4:40 PM
    rubbersidedown
    Dean
    WI
    Familiar with this... I have bad allergies to poultry and shellfish and a milder allergy to lentils (beans). My daughter has been vegetarian for about 2 years and eats a LOT of lentils for protein. I'd feel bad for my wife who does the majority of the cooking, but she actually enjoys cooking. She's damn good at it too. She's pretty great and I'm pretty lucky.
  12. Jan 8, 2023 at 4:55 PM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    Is the 10mm socket missing yet?
  13. Jan 8, 2023 at 5:01 PM
    rubbersidedown
    Dean
    WI
    I've been meaning to find some time to post more of a review of the Ironman4x4 FCP so far, but I still feel like things are settling in, even after over 1000 miles on it. For one thing, my "Taco Lean" is a good inch now. I wonder if that might be less with the sway bar in place. I really haven't missed it otherwise. I can take a freeway exit loop at good speed and not really notice much more roll than I remember with it in, before the suspension upgrade. I really want to see how it's different off pavement.
    One thing I have noticed (not sway bar related) is a "change" when I get over 65mph. Calling it a vibration would probably not be right, but it's more of a change in sound and feel. It may be that I need another alignment tweak. I got the lifetime alignment deal, so that is an option. One piece I didn't install that came with the suspension kit was a "driveline spacer kit." It's basically spacers and new bolts for the rear driveshaft mount. Put it in yesterday when I was under there doing an oil change. We'll see if it changes anything. Doesn't change the angle much.
    Aztec120, CygnusX191, wi_taco and 3 others like this.
  14. Jan 8, 2023 at 5:11 PM
    OldSchlPunk
    Rich
    East Central Wisco
    People say the spacers are needed, not sure I understand why. The u-joints aren't even close to being maxxed out and unless I'm missing something, it shouldn't matter if one driveshaft is at one angle and the other at another.
  15. Jan 8, 2023 at 5:17 PM
    pearing
    Wisconsin
    2015 SR5 quadcab
    Has to do with the angle that happens as the axle "wraps" under load. When you lift the truck, this angle changes and by lowering the carrier, it reduces the difference during that load when the pinion angle changes.
  16. Jan 8, 2023 at 6:07 PM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    It helps. Also you have a long boi.... You'll always have *some* noise/vibes at 65+
    The straighter the angle, the less wear, and thus less noise and vibration.
    LarryDangerfield likes this.
  17. Jan 8, 2023 at 7:55 PM
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    Not necessarily correct about a straighter angle. With a CV joint at the carrier bearing, it’s all about having the pinion at the correct angle relative to the face of the CV. Ideally pointed a couple degrees below the face of the CV at the carrier bearing so that with spring wrap under drive load, it points directly at the CV.
  18. Jan 8, 2023 at 8:06 PM
    LarryDangerfield
    LarryDangerfield One Larry a day keeps the money away ™ Moderator
    Tyler
    Northern Wisconsin
    Black 2020 Nightshade Edition 4Runner
    Oh there will be some mods all right
    Sharing my good deed and most important life rule only to encourage others to also do good and to provide an example of there still being good in this world, no pat on the back is necessary.
    I live by treat others how you would like to be treated, and as you know I've been trying to sell the tires that came on my Tacoma. Well, a guy contacted me asking about them saying he was really interested. I replied back to arrange a time to meet. He then cancelled and said we'd have to find a new date because his wife had an appointment. I replied back trying to arrange a new day and he went silent. I was about to chalk it up to another person flaking out when he replied that his wife's brain tumor got worse and due to rapidly changing circumstances surrounding that he would no longer be able to purchase them as he would be putting all his money towards temporary housing so he would have somewhere to stay while his wife recieved treatment in Minnesota. He thanked me for holding them as long as I did and said he didn't want me missing out on a sale and to sell them to someone else. I decided immediately that he could have them for free and I would hold them as long as necessary. Spread love people!
  19. Jan 8, 2023 at 8:26 PM
    OldSchlPunk
    Rich
    East Central Wisco
    I'd like to throw some money towards mounting. Is there some way we can work this out?
  20. Jan 8, 2023 at 8:33 PM
    JTacoma4life
    JTacoma4life Well-Known Member
    2017 Tacoma TRD Sport
    Blazing Blue Pearl. Debadged. Gloss black tailgate inserts. Thinking about Katzkin Leather
    Im on board too! Let’s help this guy out a bit, at least allow him safe travels and a way to take care of the ones he loves.
