Wisconsin Tacomas and bad financial advice
Discussion in 'Mid West' started by Thatbassguy, Dec 19, 2008.
  1. Jul 24, 2020 at 6:02 PM
    #4441
    ajmogen
    ajmogen Well-Known Member
    Aaron
    Wisconsin
    OR MT TACO T4R YARIS MT Corolla Hatchback MT
    Thatbassguy[OP] likes this.
  2. Jul 24, 2020 at 6:24 PM
    #4442
    BookieBob
    BookieBob Beer Drinker
    Racine,Wisconsin
    2021 Silver Sky TRD Sport 4WD MT
    Thatbassguy[OP] and CygnusX191 like this.
  3. Jul 25, 2020 at 7:16 PM
    #4443
    Cipher94
    Cipher94 Well-Known Member
    Madison, WI
    2016 TRD OR
    Hehe so apparently I've been hitting invisible objects. My plastic front under bumper thing seems loose. So does my driver's fog bezel. Hehe. Oh and I managed to peel the adheasive off part of the fender without damaging the fender. If I push with my foot it sticks flush but isn't sticky anymore. Any ideas?
    Also the light behind the Odo/ H (red H for hot) keep flickering. Loose wire maybe? So do I have to take off my dash.......
    Oh and lastly anyone local know how to remove the bumper? I'm picking up my rear at the helm bumper sometime next week and already have the wiring and pods ready. I also want to try and Jerry rig the bsm system just because I have it....
  4. Jul 25, 2020 at 7:33 PM
    #4444
    WiscoPat
    WiscoPat One does not simply purchase a Ridgeline
    Pat
    Wisconsin
    2019 TRDOR Tacoma 1995 JDM 80 Series
    Mall Rated
    Your stock bumper is comprised of 4 main components - 3 plastic composites (the end caps and center piece) and the steel hitch assembly. There are YouTube vids and other sources of removing them properly, if you'd like to sell them (assuming they're in one piece) - I ended up just ripping the plastic off and recycling, as mine was damaged beyond repair from being rear-ended.
    Otherwise, the steel assembly is connected to the frame with 8 or 10 bolts iirc. These will be reused for your ATH bumper.
    The final part of removal of the stock assembly, which for me was a pain, are two pins that are fitted into a slot on each side of the frame attachment points. You need to lift up on the assembly to break the pins free, then haul straight back. A jack, deadblow hammer, and patience were the ticket for me. Install of the new fully steel bumper is otherwise simple - just reuse the aforementioned frame bolts and wire up your lights.
  5. Jul 25, 2020 at 7:38 PM
    #4445
    Cipher94
    Madison, WI
    2016 TRD OR
    Thanks pat, I remember that hammer tip and pins. I do want to try and remove to sell them. They aren't completely trashed.
    CygnusX191 and WiscoPat[QUOTED] like this.
  6. Jul 25, 2020 at 7:41 PM
    #4446
    WiscoPat
    Pat
    Wisconsin
    Mall Rated
    For sure dude, let me know if you need anything else.
    Cipher94[QUOTED] likes this.
  7. Jul 25, 2020 at 7:43 PM
    #4447
    Cipher94
    Madison, WI
    2016 TRD OR
    Patience would be nice...
    How long did it take you..?
    I've already done the wiring! The add a fuse was easy.. idk about splitting them to be able to turn them on freely also though..
  8. Jul 25, 2020 at 7:46 PM
    #4448
    WiscoPat
    Pat
    Wisconsin
    Mall Rated
    Hm I'd say about 2 hours, and that was with a break and taking my time to make sure it was level, etc.
    CygnusX191 and Cipher94 like this.
  9. Jul 25, 2020 at 7:49 PM
    #4449
    Cipher94
    Madison, WI
    2016 TRD OR
    Wait. I have to level it?!
  10. Jul 25, 2020 at 7:53 PM
    #4450
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    The bolts should keep you level since you're using the stock hardware/bolt locations.
    I'm sure like with anything, you could overtorque one side and get it ever so slightly not level.
  11. Jul 25, 2020 at 7:56 PM
    #4451
    WiscoPat
    Pat
    Wisconsin
    Mall Rated
    By level I mean in line with the countours of the rear body panels, which are easy enough to line up - this'll make sense when you're installing.
    One of the sells for me was how the steel was shaped to mirror the body lines so well, vs being the typical chunky blocks from other fabrication shops.
    Cipher94[QUOTED] and CygnusX191 like this.
  12. Jul 25, 2020 at 8:09 PM
    #4452
    deekyn
    deekyn Well-Known Member
    Dustin
    Yellowstone
    2015 Black Tacoma TRD Off Road
    56k? I feel like I’m pretty aggressive on my tires and truck in general and my BFG KO2 ATs are rolling around at 75k with plenty of tread left including Utah wheeling, Colorado wheeling and 4 cross country road trips.
    :burnrubber:
    Thatbassguy[OP] and Cipher94 like this.
  13. Jul 25, 2020 at 8:12 PM
    #4453
    deekyn
    Dustin
    Yellowstone
    You people don’t have build threads? What’s this about ATH bumpers? I love mine!
  14. Jul 25, 2020 at 8:27 PM
    #4454
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    o_O
    Even light truck road tires max out around 75-80k... Ain't never heard of a KO2 going that far lol
    Peeing on Jeeps and Shellshock like this.
  15. Jul 25, 2020 at 8:34 PM
    #4455
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    Me either
    most of the guys I've known to run them are lucky to get to 50
    CygnusX191 likes this.
  16. Jul 25, 2020 at 8:34 PM
    #4456
    Cipher94
    Madison, WI
    2016 TRD OR
    It's not on the truck yet, aka not in my build thread. I have it somewhere though!
  17. Jul 25, 2020 at 8:38 PM
    #4457
    Shellshock
    Iowa
    I could have kept going for a while still but figured I’d gotten enough miles out of them with winter coming up
    same. Only thing I’ve had get that many is Michelin car tires
  18. Jul 25, 2020 at 11:15 PM
    #4458
    sparkystaco
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    The only lt truck tire I've seen go that far safely was the Hankook dynapro's,
    have a buddy that ran them to 75-76k before buying new and they still had plenty of tread left
  19. Jul 26, 2020 at 5:34 AM
    #4459
    Shellshock
    Iowa
    I guess I should also note, my falkens were SL load rating
    CygnusX191 and Thatbassguy[OP] like this.
  20. Jul 26, 2020 at 6:35 AM
    #4460
    Thatbassguy
    Thatbassguy [OP] Sweet or sour?
    James
    '19 T4R, TRDORP, KDSS
    RSG sliders, SOS skids, SOS bumper, wheels, tires, etc
    I took stock size KO2's off the 4runner this year in lieu of bigger tires. With 29K miles, they measured 80% of their original tread. They also wore incredibly evenly. The key was rotating every 5K.
    At that rate, I would have easily gotten over 100K out of them(safely). Although, I probably would have replaced them sooner.
