Wisconsin Tacomas
Discussion in 'Mid West' started by Thatbassguy, Dec 19, 2008.
  1. Aug 10, 2022 at 7:53 PM
    Shellshock
    Iowa
    2019 Tundra TRD PRO
  2. Aug 10, 2022 at 7:59 PM
    Thatbassguy
    Thatbassguy [OP] Derriere extraordinaire
    James
    '19 T4R, TRDORP, KDSS
    RSG sliders, Pro-Comp '05 wheels, Yakima offgrid basket
    I have blasted them off at the pay 'n' spray in the past. Works well, but maybe not the most efficient method. I'll have to see if the pressure washer my Dad gave me will be sufficient after the shindig next weekend.
    CygnusX191 likes this.
  3. Aug 11, 2022 at 7:39 AM
    Larry Dangerfield
    Larry Dangerfield JUST DO IT
    Tyler
    Northern Wisconsin
    Cement 2020 Trail Limo off-road
    Stock....for now.
  4. Aug 11, 2022 at 9:15 AM
    Sasquatch3153
    Sasquatch3153 Sassy Squatch
    Josh
    Illinois
    2010 ACLB OR
  5. Aug 11, 2022 at 10:30 AM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
  6. Aug 11, 2022 at 12:38 PM
    BEAR_KNIFE_FIGHT
    BEAR_KNIFE_FIGHT bearly famous
    Alex
    Minnesota
    2016 TRD OR 4X4 DCSB Quicksand
    A stronger/larger rack and PS pump are honestly super overlooked when going bigger/heavier. The stock tacoma rack barely has the strength to turn the wheels under force at stock size, now once you go bigger you're gonna run into problems.
    Either do a slide rack or a tundy rack, the slide rack doesn't fit on 3rd gens.
    934s don't address the fact that neither the rack nor the pump can push the wheel through shit, the tierods just add glam and maintain the "fuse" of the steering. Frankly, I think most people go to 934s for the increase in CV degree movement rather than strength.
  7. Aug 11, 2022 at 1:06 PM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    If your stock rack is struggling pushing stock tires around, sound like you need to replace it. Stock racks should have no issues pushing 33s around.
    As far as replacing it with a Tundra rack..... Good luck. That is the tightest space for components on the entire damn truck. Even stock rack replacements are a royal pita
  8. Aug 11, 2022 at 1:07 PM
    Supr4Lo
    Supr4Lo Well-Known Member
    Wisconsin
    2020 DCSB Offroad MT, Supercharged, NWF Eco-Crawler
    Have you upgraded to the tundra rack? I've seen the modifications that need to be down, but was it pretty straight forward?
    I was looking at the upgrade offering from Solo motorsports. https://solomotorsports.com/shop/pa...ta-parts/toyota-tacoma-steering-rack-upgrade/
  9. Aug 11, 2022 at 1:08 PM
    BEAR_KNIFE_FIGHT
    Alex
    Minnesota
    https://www.tacomaworld.com/threads/better-steering-solutions.734503/
    https://www.tacomaworld.com/threads/modified-tundra-rack-swap-preorder.625844/#post-21391427
  10. Aug 11, 2022 at 1:08 PM
    Supr4Lo
    Wisconsin
    Not true. Been in a few situations had a hard time turning 33's and my rack only has 21,000 miles on it.
    BEAR_KNIFE_FIGHT likes this.
  11. Aug 11, 2022 at 1:08 PM
    BEAR_KNIFE_FIGHT
    Alex
    Minnesota
    CygnusX191 and Shellshock like this.
  12. Aug 11, 2022 at 1:10 PM
    Supr4Lo
    Wisconsin
  13. Aug 11, 2022 at 1:11 PM
    BEAR_KNIFE_FIGHT
    Alex
    Minnesota
    That's just straight-up not true. The steering rack is a known weak point, even stock. As soon as you add weight [sprung OR unsprung] or need to start pushing offroad/offangle/out of the mall, it becomes more noticeable. The "bump steer" that we feel is because the pump is weak and shitty, and the steering rack is pretty small and weak at stock.
    Shellshock and Tigerian like this.
  14. Aug 11, 2022 at 1:12 PM
    BEAR_KNIFE_FIGHT
    Alex
    Minnesota
    Yep, let me know how it goes. I'm looking to do this as well, but I think I want to do heimed tie rods -- just looking for a way to seal the ends with a boot at the rack end.
    CygnusX191, Shellshock and Supr4Lo like this.
  15. Aug 11, 2022 at 1:19 PM
    Supr4Lo
    Wisconsin
    Not sure if I'll change the rack when going 35's or when the stock rack finally gives up. From the link you posted looks like another fun job laying on the floor with the plasma cutter......
    pearing and CygnusX191 like this.
  16. Aug 11, 2022 at 1:23 PM
    BEAR_KNIFE_FIGHT
    Alex
    Minnesota
    FWIW I would also look at a new pump while you can. I'm going to swap to a Howe TC while I do it.
    Also, Travis [Basikbiker] makes some racks and also had some neat plates he was designing to make it a bit easier to mark/fit the new rack in. Let me try to find a link. I know he got pretty displaced with some fires so I'm not sure if/when he's making things again.
    Honestly, the hardest part is the steering shaft, IMO.
    CygnusX191 and Supr4Lo like this.
  17. Aug 11, 2022 at 6:09 PM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Hmmm. I've never had issues and I'm off road quite a bit. And I recently replaced a factory steering rack (part of a larger deal, rack was actually in good shape, shaft and all. Was just a bitch and a half to do) on a customer's truck at work. Good times.
    If you're going to 35s, change the rack.
  18. Aug 12, 2022 at 3:59 AM
    Larry Dangerfield
    Tyler
    Northern Wisconsin
    Stock....for now.
  19. Aug 12, 2022 at 4:14 AM
    Thatbassguy
    James
    Anybody looking for a project?
    I guess you better go fishing today. ;)
    Here's the app I use. It has tides, also, so it's handy when I'm in Florida.
  20. Aug 12, 2022 at 4:22 AM
    Larry Dangerfield
    Tyler
    Northern Wisconsin
    Stock....for now.
    Heading out in like 5 minutes :D
