Wish I never lifted my truck. All sorts of noises and weirdness. Help?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jason12085, Jul 19, 2025 at 12:11 PM.
  1. Jul 19, 2025 at 12:11 PM
    Jason12085
    Jason12085 [OP] Well-Known Member
    2013 MGM Access cab
    2013 Tacoma. I have an Eibach Pro lift that lifted the front 2.0ish inches. OME upper control arms and the ECGS bushing.
    Have had it installed for a couple years now and wish I never did it.
    The truck now steers very inconsistently. Going from normal to really stiff.
    Had to replace one wheel bearing already.
    At slow speeds it started making a clunking noise if you hit a bump with the wheel turned.
    I brought it to the shop multiple times and they said they couldn't find anything. This has magically disappeared a couple weeks ago. Calm before the storm?
    The abs no longer works.
    It's a nightmare.
    I guess one thing positive that came from it. I never in my driving life wore a seat belt. I trust this thing is going to catastrophically grenade at some point so every time I get in it, I now wear my seat belt.
    wilcam47 likes this.
  2. Jul 19, 2025 at 12:34 PM
    Javman
    Javman Well-Known Member
    I keep my stock Tacoma SR plain Jane. Those lift kits is asking for potential problems or issues. I know that Toyota recommends a lift be no more than 1.5" or so due to tranny, drive shaft considerations.
    I think you should sell ur rig to a young buyer that is looking for a lifted rig then buy yourself another non-lifted rig.
    Now you know.
  3. Jul 19, 2025 at 12:35 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Don’t feel bad, many have fell into this pit. Sometimes you have to step in dog poop to understand it stinks.
  4. Jul 19, 2025 at 12:39 PM
    Clearwater Bill
    Billy
    Largo Florida
    So return it to stock.
    Your steering sounds like an intermediate shaft issue. Related more to corrosion than lift.
    Search will find quick cheap test and how to fix DIY if that's what it is.
  5. Jul 19, 2025 at 12:51 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    In my nearly 20yrs of owning lifted Tacomas never have I had headaches like that. Sounds unrelated to the lift IMO. Most of my Tacomas have been mid or Long travel and 35-37in tires and daily drive down the road just fine, granted I'm not putting like 20k miles a year on them but wheel bearings have not been an issue, nor steering unless I'm beating on them on the trail.
    If you really dont like your truck lifted, return it to stock. Nothing you've done sounds irreversible. In fact you could probably find someone that wants theirs lifted and willing to swap components with you.
    RockinU and OldSchlPunk like this.
  6. Jul 19, 2025 at 12:57 PM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    Wheel bearings go bad in stock trucks too. As a matter of fact, a guy that I recently helped with installing his lift, found out the week before that both of his wheel bearings were bad.
    Why doesn't the ABS work? If you don't know, how can you blame the lift?
    As previously mentioned, if you don't like the lift, return to stock.
    Plenty of people have lifts (me included) with no problems.
    wilcam47 and RockinU like this.
  7. Jul 19, 2025 at 12:58 PM
    OldSchlPunk
    Rich
    East Central Wisco
    :rolleyes:
    RockinU likes this.
  8. Jul 19, 2025 at 1:01 PM
    Jason12085
    2013 MGM Access cab
    I did a search and couldn't really find anything about how to test it. I have sprayed it with deep creep a few times and it has helped some. Less so now.
    I only drive like 10k miles a year. I've been off road in the thing maybe once.
    I don't need a truck and will probably just trade it in.
    Stressing me out bad.
  9. Jul 19, 2025 at 1:02 PM
    OldSchlPunk
    Rich
    East Central Wisco
    Oh, and the clunk could be body mounts by the radiator support, or maybe the lower shock bolt. Again, both of those problems exist on stock trucks.
    Jason12085[OP] likes this.
  10. Jul 19, 2025 at 1:05 PM
    Jason12085
    2013 MGM Access cab
    Thanks for giving me some options to at.
    I guess I was wrong with my assumption that Tacomas were reliable.
  11. Jul 19, 2025 at 1:06 PM
    OldSchlPunk
    Rich
    East Central Wisco
    Try a Chevy or Nissan and get back to us.
  12. Jul 19, 2025 at 1:10 PM
    Jason12085
    2013 MGM Access cab
    Lol. At least a Chevy would be cheaper to fix, no?
    I've had better luck with Subaru's I've owned. Just hate that just about all of them are CVT now.
  13. Jul 19, 2025 at 1:11 PM
    Clearwater Bill
    Billy
    Largo Florida
    Lube is the test. Replace it.
    Well, just be sure your next vehicle will be eternally perfect, or the stress will return.
    But hey, seatbelt use is wise.
    RockinU, winkel and OldSchlPunk like this.
  14. Jul 19, 2025 at 1:17 PM
    OldSchlPunk
    Rich
    East Central Wisco
    If you're fixing it constantly, is it really cheaper?
    edit: I haven't heard that GM's shop rates are any lower than Toyota's
    RockinU likes this.
  15. Jul 19, 2025 at 1:18 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    It's always been my opinion that if you're going to start modding your vehicle, you'd better know how to wrench on stuff.
    As far as the ABS goes, have you crawled under the truck to have a look at your speed sensor wires, etc?
    RockinU and 2015WhiteOR like this.
  16. Jul 19, 2025 at 3:33 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Reminds me of when I see (hear) someone drive by on huge swamper tires in the city. Unless the driver is deaf, they surely can't be enjoying the howl/noise as they go to pick up their groceries.
    A stock truck is the baseline that the brilliant engineers at Toyota put a lot of time into figuring out. Every deviation from baseline is going to result in some side effect that has to be dealt with.
  17. Jul 19, 2025 at 3:43 PM
    RockinU
    RockinU Well-Known Member
    Texas
    Yeah…maybe a Camry is more your style
  18. Jul 19, 2025 at 4:17 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Sorry to hear your having issues. In the 18 years i've had my 07 just done general maintenence. Had my lift system on for 4 years now... had it professionally installed. Have yet to hear a noise up front or a squeak in back. Truck rides/handles awesome... way better than stock and seems to get better as it breaks in. Keep everything clean, lubricated, greased and rust proof. :thumbsup: Have you retorqued and had a fresh alighnment lately?
  19. Jul 19, 2025 at 4:41 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    2.0 lift isnt much. Most likely not cause of your problems.
  20. Jul 19, 2025 at 7:17 PM
    tacomavan
    tacomavan Well-Known Member
    Oregon
    clunking noise during a turn over a bump is probably just your tire hitting your cab mount, whats your wheel/tire combo/offset?
