Wish me luck...frame replacement at 60k
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gtrotter07, Sep 18, 2019.
  1. Oct 31, 2019 at 4:16 PM
    #61
    Yotabilly
    Yotabilly Well-Known Member
    The Bluegrass
    2013 4cyl,5spd.4x4 Reg Cab
    UWS low profile toolbox, tint, rainguards, color matched grill surround 265/75r16 Goodyear Duratracs Ultra-Guage XB fogs, Weathertech Floor Liners, OME 884s, 2"AAL, Bilstein 5100s, FJ Trail Team wheels, Matt123 skid plate, 30" light bar, Rigid Duallys, Bed extender
    I read the letter and it mentioned nothing about being the first owner so I assume you’re covered.
    cedarpangolin[QUOTED] likes this.
  2. Oct 31, 2019 at 4:28 PM
    #62
    Yotabilly
    The Bluegrass
    My situation is that my truck is a 2013 with 22,000 miles. I am in the car wash and detail business so it stays pretty clean although I have played in the snow a bit, but mostly in deep and fresh snow and I got a dolly and pressure washer and washed the under body pretty good afterward each time.
    I want this truck to last a couple decades because by the time my grandkid(s) are old enough to drive (if I have any) I want to teach them to drive a manual in it, if mine is not the only one left by then. I want to keep this truck for the rest of my life if possible. It’s already kind of a novelty being a regular cab, manual transmission Taco. It surely will be in the future.
    So my plan is to get under it soon with a wire brush and rust prohibiting paint then take it to a dealer and have their undercoating sprayed on it (within two years) since it’s necessary to retain the 12 year from DOP warranty. Or would it be smarter to just let it rust for two years, let them spray over the rust and hope it gets rusty enough for them to replace it in six years?
  3. Oct 31, 2019 at 5:18 PM
    #63
    gtrotter07
    gtrotter07 [OP] Well-Known Member
    2007 Tacoma reg cab 4x4 on 37's; 2021 TRD Offroad, 6 speed
    37's,lockers, bumpers, bobbed etc.
    Personally, I wouldn't let Toyota spray my frame. From the pictures I've seen, the crc treatment does nothing but compound and accelerate the rusting problem. Just fluid film it, which is what I plan to do when I get mine back from the dealer.
    Silentshredr likes this.
  4. Oct 31, 2019 at 5:20 PM
    #64
    cedarpangolin
    cedarpangolin So country I bleed cedar sap.
    Christian
    2015 Tacoma Access Cab 4x4 2.7L
    1.5" wheel spacers, 2.5 front and 1" rear leveling kit, AFE Dry drop in filter, Thrush Glasspack Cherry Bomb exhaust, Falken Wildpeak AT3W tires Soon to be: bully aluminum side steps, plastidip emblems
    what about the big red lines in the notice where it says clearly that CRC application is REQUIRED to qualify for the replacement program? Telling people not to get that done is making it a hella lot harder if not impossible for them to get a frame replacement later on. Who cares if the CRC makes the rust worse, it will rust out faster and get a replacement sooner.
  5. Oct 31, 2019 at 5:24 PM
    #65
    gtrotter07
    What if the crc causes it to rust, but not fail before the time is up? Then he has also shot himself in the foot. Since he sounds like he keeps things nice and drives the truck very little, it would probably behoove him to take the care of his frame into his own hands so to speak.
    69L46Vert likes this.
  6. Oct 31, 2019 at 5:50 PM
    #66
    Yotabilly
    The Bluegrass
    I decided I’m going to do this. Remove the visible rust. Paint with Por-15. Then Fluid Film inside the frame and out. Then let Toyota coat it. Then FF yearly.9489A790-A6B2-4E54-AE31-FE549E580954.jpg
  7. Oct 31, 2019 at 6:02 PM
    #67
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Toyota will probably pressure wash off your fluid film before they apply there coating.
  8. Nov 1, 2019 at 2:25 AM
    #68
    Yotabilly
    The Bluegrass
    OK.I’ll do the FF after the coating
    PzTank and 74cam like this.
  9. Nov 1, 2019 at 6:20 AM
    #69
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    I got the letter yesterday. I’m the second owner bought it in 2017.
    AND IT’S NOT A RECALL. It’s a service campaign.
    Yotabilly likes this.
  10. Nov 1, 2019 at 8:18 AM
    #70
    TacoBreaker
    TacoBreaker Well-Known Member
    08 Rust Bucket
    OME 885, 5100s
    Based of the settlement of a class action lawsuit. So remember you’re not a customer at this point but a class member. I’d highly recommend skimming through the settle and reading the relief section so you don’t end up in the SOL boat with me.
  11. Nov 1, 2019 at 8:25 AM
    #71
    PzTank
    Above the Notches
    I think it’s different. Folks eligible for actual frame replacement are members of the class action lawsuit.
    With the Service Bulletin letter, Toyota is attempting (solely based on my opinion) to limit frame replacements in the future by mandating compliance with the SB now. All the folks not doing the SB recommendations within the timeframe are going to be excluded if their frames rot out.
    I am not part of the class action lawsuit with my 2015.
    Sorry you’re in that situation btw. The lesson I’m walking away with is:
    1) In my own inspection, if any ‘assistance’ is needed, it will be as natural looking as possible; and
    2) Admit NOTHING to NO ONE if action in 1 is necessary..
  12. Nov 1, 2019 at 9:15 AM
    #72
    TacoBreaker
    08 Rust Bucket
    OME 885, 5100s
    Ah, you’re right. My 08 was in the original 05-10 range or whatever it was. Either way, the evaluation procedures are gonna be the same so you’re points are spot on. Worst of it my first use was end of April so I could have let it have another Ohio winter before being looked at. I do wonder if compressed air would leave any evidence on a soft spot. But absolutely no shiny spots.
  13. Nov 1, 2019 at 10:26 AM
    #73
    69L46Vert
    69L46Vert Well-Known Member
    Rick
    Maine
    2007 Regular Cab 4x4
    This would be my advice too. It may not be just the frame that rusts but the body too. My frame is new but there's a lot of crusty mess on other parts. Heck, even my brake caliper piston rusted through. Preserving it now while things are relatively solid seems like the way to go.
  14. Nov 7, 2019 at 10:52 AM
    #74
    gtrotter07
    I just got my truck back. I've put a 100 miles on it so far, and am satisfied. No out of pocket costs what so ever, and no upsell on stuff not needed. I have to applaud Uebelhor Toyota in Jasper, Indiana. I got to see what the cost was...$10,660. Glad I wasn't paying that bill!
    69L46Vert and Muddinfun like this.
  15. Nov 7, 2019 at 10:58 AM
    #75
    69L46Vert
    Rick
    Maine
    That's awesome gtrotter! Here's hoping you get many more years out of it. My frame was replaced too and they did a great job.
    HONY BADGER likes this.
  16. Nov 7, 2019 at 11:17 AM
    #76
    TacoBreaker
    08 Rust Bucket
    OME 885, 5100s
    Nice, congrats.
  17. Nov 7, 2019 at 1:56 PM
    #77
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    How do you only have 63k miles on an 11 yr old truck?
  18. Nov 7, 2019 at 2:09 PM
    #78
    69L46Vert
    Rick
    Maine
    I saved the paperwork from Toyota and the list of replaced parts just goes on and on. Surprised they gave it new lower control arms with new ball joints. Rear leafs, just about every brake line and what seems like hundreds of new clips and fasteners. Pages of part numbers. Toyota did right by me.
    I had heard here and there the cost was at least 10k and could be a lot higher. Dealer that that did mine had multiple stacks of frames and a big backlot full of trucks waiting for new frames. Tundras, Sequoias but mostly Tacomas. They must be making a ton of money changing them out. They had mine for about six weeks.
  19. Nov 7, 2019 at 2:44 PM
    #79
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    Got mine back an hour ago. Just got home. No headlights and no fog lights. Out into the driveway in the rain I go to see if I can unfuck it. F Toyota and their frames and F Towne Toyota.
    whatstcp likes this.
  20. Nov 7, 2019 at 2:47 PM
    #80
    tacom08
    tacom08 Well-Known Member
    Isaac
    Simpsonville, SC
    08 DCSB 2WD Rugged Trail Edition
    Flowmaster Super 10, K&N CAI, bumpers, LED taillights
    Mine is Feb 2008, good to know if it ever happens.
