Wishful Thinking?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MuddyJackson, Sep 11, 2017.
  1. Sep 11, 2017 at 2:36 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Also if you're needing tools and have none, and aren't sure what you're aiming to do or if you'll stick with doing work yourself - just go to a Harbor Freight and get those hand tools you need. A breaker bar, ratchet, set of extensions and metric sockets you'll need are probably under $40 or $50. Can buy one tool a day and use a 20% off coupon every time and save some money.
    If you want something more brand recognizable, I'd check out Husky or Craftsman. Also don't buy a big kit with 80 tools or more, most of the stuff in them you'll not ever use and it's just a lot of cheap filler tools.
    You should look for a 3/8 ratchet set with metric sockets. It'll come with a case of some kind and be only what you need and nothing you don't. Also easily portable because it's a small size set, so you can toss it in the truck to have on hand for emergencies or something. Metric combination wrenches (HF has some with ratcheting heads).
    Really don't need a ton of stuff.
    Also check online (eBay) for OEM filters. I buy mine in a case of 10 and they're under $4 a piece in that quantity.
  2. Sep 11, 2017 at 2:39 PM
    MuddyJackson
    MuddyJackson [OP] Well-Known Member
    Eva
    Billings, Montana
    2006 Toyota Tacoma Base 4x4 6 speed
    Really appreciate this.
  3. Sep 11, 2017 at 2:39 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    From my point of view, it better to accumulate tools slowly. Don't buy one of those big sets cause they'll probably have pieces you don't need or will ever use.
    MuddyJackson[OP] likes this.
  4. Sep 11, 2017 at 2:41 PM
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
    My $0.02 on this but as others have already posted here start off with basic maintenance, here are the top 12 basic's on things such as:
    1.) changing the oil & how to check the oil level
    2.) changing the oil filter
    3.) changing the engine filter
    4.) changing the cabin filter
    5.) learn how to replace spark plugs & gaping spark plugs
    6.) learn how to check tire pressure & change a tire as well & become familiar on how to use your jack & lower your spare tire, etc.
    7.) learn how to replace wipers & add window washer fluid as well
    8.) learn how to replace all the light bulbs
    9.) learn how to check and refill your brake fluid
    10.) learn how to check and add engine coolant
    11.) learn about your tacoma's engine size (4.0 V6 or 2.7 4 cyl.) and battery group type/voltage & cc amperage, engine belt inspection, etc.
    12.) read & become familiar with your tacoma's owners manual!
    After becoming familiar with these basic steps and tools required, you'll be able to handle other jobs such as replacing brakes, etc. so be confident.
    Just keep in mind, take your time, don't rush and give yourself plenty of time to work around and always ask questions if needed.
    You can do it!
    Good Luck!
    frankiejr, SC2SC and MuddyJackson[OP] like this.
  5. Sep 11, 2017 at 2:43 PM
    81shark
    81shark Well-Known Member
    2006 Base Access CP1
    youtube is the best... it'll show how to milk a elephant if you want... but seriously, you tube is great for seeing how to do something.. even if the person is doing things right. haha. ie, don't use a mallet to knock out a broken lug stud.. press it out with a clamp if at all possible
  6. Sep 11, 2017 at 2:43 PM
    T4RFTMFW
    One day you'll want an impact driver also to help speed up bolt removal/install.
    Same deal.. I wouldn't get any electric tool from HF but I would recommend a basic set like Ryobi from Home Depot or Amazon or whatever you prefer. They won't be top tier quality, but they'll work great for your use and won't be cheap junk.
  7. Sep 11, 2017 at 2:44 PM
    TexasWhiteIce
    Texas
    If it has nipples it can be milked...
  8. Sep 11, 2017 at 2:49 PM
    Pigpen
    Northwest Montana
    Access cab toolbox/ dog bed with seats and headrests deleted, waterproof TRD seat covers, yellow wire mod, diff breather relocated to tail light, engine block heater, Leer topper with Yakima tracks and rack, Yakima rack on cab, Ride Rite with Daystar cradles, CBI hidden front hitch, wired for winch front and rear Warn quick connect, Warn x8000i on external carrier, sway bar delete, trailer plug relocated to bumper, Pelfreybilt IFS and Mid skids, ECGS front diff bushing, ARB CKMA12 compressor, 255/85/16 Backcountrry MT 3 load E tires on stock steel rims, Up2NoGood heated mirror kit, Husky X-act Contour front floor liners, Northstar AGM 24F battery, Pelfreybilt bolt on sliders with kickout and top plates, TRD Pro headlights, Depo smoked tail lights, Energy suspension body mount bushing kit, OME Dakar leaf packs with AAL, Billstein B110 rear shocks, OME 90021 front shocks with 885 coils, SPC LR UCAs, Up2NoGood 2wd low range mod, 4 Wheel Campers Grandby slide in camper
    I have nipples :anonymous:
  9. Sep 11, 2017 at 2:54 PM
    PerazziMx14
    PerazziMx14 I'm fat but identify as skinny, I'm Trans-slender
    Close to 39.9609243°N, -77.5763777°W
    If you wanna be cool your going to need some PBR pounders, cutoff t-shirt and Molly Hatchet 8 track.
  10. Sep 11, 2017 at 3:22 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    If it's broken just use the hammer.
  11. Sep 11, 2017 at 3:29 PM
    MuddyJackson
    Eva
    Billings, Montana
    Or in the case of my mechanic friend, a saw... he sawed off like 6 parts on day off my Honda and was like, there, your rattling noise is gone.
    tcjacado and Bebop[QUOTED] like this.
  12. Sep 11, 2017 at 3:30 PM
    sioux
    sioux Well-Known Member
    Northern Minnesota
    2012 DCSB SR5 4x4
    I keep this one in my truck: https://www.amazon.com/dp/B00EFL1FT0/_encoding=UTF8?coliid=I30B8GCINSZH3L&colid=3IX1GC30EM3R1
  13. Sep 11, 2017 at 3:32 PM
    sioux
    Northern Minnesota
    2012 DCSB SR5 4x4
    I actually have the HF Chicago Electric cordless impact gun. I've used it for two years for multiple vehicles with no issues. (primarily lug nut removal)
  14. Sep 11, 2017 at 3:33 PM
    T4RFTMFW
    I might have a manual you can have, actually.
    I don't have my truck anymore, and no locals wanted it. It's either in my garage or in the trash last month.
    @MuddyJackson
  15. Sep 11, 2017 at 3:36 PM
    #35
    T4RFTMFW
    A 1/2 inch? I'm talking a standard type setup. Not one with a dedicated impact chuck. One with a QCD chuck that uses a 1/4" or 3/8" adapter.
    By the time you buy a HF Hercules impact, and a spare battery you're spending the same money as a DeWalt model that comes with the second battery included. The build quality and battery quality are not at all comparable despite the price being so.
  16. Sep 11, 2017 at 3:38 PM
    #36
    sioux
    Northern Minnesota
    2012 DCSB SR5 4x4
    This is the one I have. I think I paid like $89 or something?
  17. Sep 11, 2017 at 3:41 PM
    #37
    T4RFTMFW
    Yeah, that's more than I'd have her use (and a dedicated impact with that chuck).
    I'm thinking this with a set of $5 adapters to use sockets with, otherwise it's a bit driver. Much more versatile.
    http://www.homedepot.com/p/Ryobi-18-Volt-ONE-Lithium-Ion-Impact-Driver-Kit-P881/203466912
    Only negative is it won't take off lug nuts. But, thats what the $8 breaker bar is for. I'd rather someone learn with hand tools, since power tools tend to fuck a lot more things up in a lot less time! :D
  18. Sep 11, 2017 at 3:51 PM
    #38
    T4RFTMFW
    Even better to get the combo kit with the matching drill.
    But a bit down the road, IMO.
  19. Sep 11, 2017 at 3:56 PM
    #39
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Aint that the truth!
    OP, as others have stated Harbor freight is the way to go. I've tackled a couple big jobs on my truck, and 90% of my tools are from harbor freight, even the floor jack and jack stands.
  20. Sep 11, 2017 at 3:57 PM
    #40
    T4RFTMFW
    If they're local, anyway.
    If it's a 20 minute drive and Home Depot or Lowe's is 5, then buy their house brand.
    All have lifetime warranties. You probably won't need them, but if you do, it's not worth driving an hour for a $7 socket.
    tcjacado and MuddyJackson[OP] like this.
