Witch way dose my bottom leafspring go?
Discussion in 'Suspension' started by dirty TaTer, Jun 28, 2011.
  1. Jun 28, 2011 at 4:47 PM
    dirty TaTer
    dirty TaTer [OP] Ruts are the enemy
    Kevin
    Pasco Florida
    96 2.7 3rz taco
    Doorman OEM rear leaf packs, dynomax thrush glasspack, and cool milk crates in the back B)
    I purchased a set of doorman springs and a friend of mine said the bottom leaf was upsidedown. It is the thicker one on the bottom rear. The leaf is bending towards the ground. I understand that there are many typs of leaf packs but my friend thinks ALL leafsprings bend the same way. Please clear this up!
  2. Jun 28, 2011 at 4:48 PM
    CopDoctor
    CopDoctor Well-Known Member
    Trinidad, CO
    2018 Quicksand TRD Off-Road
    the bottom spring is the overload spring. it usually looks flat if not a little bent downwards (due to it being old and worn out)
  3. Jun 28, 2011 at 4:49 PM
    jandrews
    '09 FourDubDee TRD OR
    What he said.
    You can see my frowning overload leaf in this photo:
  4. Jun 28, 2011 at 4:55 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    If the pack has an overload leaf, then the bottom leaf sounds like it is correct. The overload leaf is not a supporting leaf in the pack. Otherwise your truck would ride like a buckboard wagon.
  5. Jun 28, 2011 at 5:04 PM
    dirty TaTer
    Kevin
    Pasco Florida
    96 2.7 3rz taco
    Thanks. Real quick, my new leafsprings are sagging after only a monty. Any particular reason for this (they are almost riding the overload).
  6. Jun 28, 2011 at 5:10 PM
    CopDoctor
    Trinidad, CO
    bad springs? call dan (two posts up)..he'll hook you up.
