With 1.75" up front...do I go 265/75/16 or 285/75/16??
Discussion in 'Wheels & Tires' started by Dakota 08, May 14, 2011.
1.75 setting up front...do I go 265/75/16 or 285/75/16
Poll closed Jun 13, 2011.
  1. 265/75/16
    29 vote(s)
    82.9%
  2. 285/75/16
    6 vote(s)
    17.1%
  1. May 14, 2011 at 12:49 PM
    Dakota 08
    Dakota 08 [OP] Well-Known Member
    Portland
    08 Dbl Cab
    Will be installing billy's at 1.75 with a 1.5 AAL in rear and will be using stock 16" wheels. What tire size should I go with. I don't mind doing a little trimming, I just don't want to be completely stuffing my wheel wells. I would like to have some articulation.
    If I decide to go the smaller route, will I regret it if I ever want to go up to the 2.5" setting??
    Was planning on going with the DuraTracs.
  2. May 14, 2011 at 12:51 PM
    paidfor
    paidfor Well-Known Member
    Austin, TX
    2013 TRD OR 4x4
    Hidden GPS tracking system. Backflip cover, weather techs, bed mat, tailgate lock, OME 885 springs, blistein shocks, 2.5 in AAL/
    265-75-16. 285's will not fit without trimming.
  3. May 14, 2011 at 1:04 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Pacific Northwest
    2018 OR DCSB 4x4
    One thing to consider, 285's will kill your MPG's.
  4. May 14, 2011 at 1:07 PM
    JonnyBb
    JonnyBb I have to return some videotapes
    Arkansas
    2010 TRD Sport DC LB 4x4
    Work in progress, but installed so far; 265/70/17 Duratracs, Spidertrax, OME885X coils with OME lean spacer, OME N140S and N182 shocks, Wheeler's 1.5" 3 Leaf Progressive AAL (kept the overload), LR UCAs. TP14 spacers
    especially considering those 285s only come in E range
    also depends on your definition of a "little" trimming.
  5. May 14, 2011 at 1:20 PM
    KalamaKid
    KalamaKid Well-Known Member
    Socialist Republic of Oregon
    same shit as everyone else
    They'll fit! Just take off the mud flaps, take out a pocket knife and cut some of the inside of your bumber out that would touch the tire. (you'll never notice whats cut out from looking at it) then find a plasma cutter and chop off your cab mount! Sounds like a lot but its completely worth it. Your MPG's will drop a little too
  6. May 14, 2011 at 1:20 PM
    BulletToothTony
    BulletToothTony Im only a dick 90% of the time
    You can call me Susan if it makes you happy.
    265's the 285's won't fit unless you trim big time but then you won have any articulation like you want to, just do 265's alot guys have them with 2.5 up front and it still looks great IMO.
  7. May 14, 2011 at 2:00 PM
    Largefarva
    Largefarva Well-Known Member
    Fox Lake, IL
    '08 Double Cab TRD Off Road 4x4
    I see you said you're planning on using your stock wheels. From what I was told, you won't be able to fit 285's using the stock wheels because they will hit your UCA's. Just something to consider before you make your decision.
  8. May 14, 2011 at 2:56 PM
    Buzzoff
    Buzzoff Don't go ninja'in nobody don't need ninja'in
    The Nickel/5th Ward
    09 Tacoma DC TRD Speedway Blue
    Blacked out windows, 5100's@1.75", KMC XD Hoss795 16x8
    1.75 with 265/75/16 duratracs are what I'm running. I rub at full lock. Should be picks in my gallery if you want to see what it looks like
    Sorry checked my gallery and must have erased them
  9. May 14, 2011 at 3:04 PM
    JonnyBb
    Arkansas
    100% true, my neighbor has a 3" lift and his 285s on stock wheels definitely rub on his UCAs
  10. May 14, 2011 at 5:54 PM
    Cogge89
    Cogge89 Well-Known Member
    Justin
    Saint John, NB
    09 Tacoma TRD Sport
    Pioneer AVH-P4100DVD, Kicker ZX400.1 Amp, Kicker CVT 10" Sub. Light Racing UCAs, Front OME Shocks with 885x Coils, Rear OME Shocks with Dakar Leaf Pack, Engine Cover Paint Job, 265/70/17 Duratracs.
    Strange that yours rubs, I'm running 1.75" with 265/70/17 duratracs, with mud flaps on, and zero rubbing
  11. May 15, 2011 at 8:19 AM
    JonnyBb
    Arkansas
    could be that the sidewalls on the 265/75/16s are 1/2" taller than the 265/70/17s
  12. May 16, 2011 at 4:15 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Huh? Diameter is what matters, and those two tires are within 0.05" of each other....
  13. May 16, 2011 at 4:31 PM
    Airun
    Airun Well-Known Member
    Aaron
    Show Me State
    TRD sport, DCLB, 4wd
    Debadged, custom emblem, Husky liners, custom bedrail Yak Trak setup with load bars, , BakFlip Fibermax, OME 3" lift with LightRacing UCAs
    I'm running 265 DTs with 1.75" billies and DC2s only minor plastic trimming. Check pics
