With a 2.5 inch lift do i need upper control arms?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jake slatnick, Nov 2, 2009.
  1. Nov 2, 2009 at 8:30 PM
    jake slatnick
    jake slatnick [OP] Well-Known Member
    jake
    San Diego
    Cement TRD Pro
    285/75r16 KO2's, Baja XL 80's on CBI ditch brackets, TRD intake, opticoat pro, clear bra running the bottom sides, morimoto LEDs, all white LEDs inside, mounted shovel and axe above wheel well in the bed, linex'd the bed...
    im buying a bilstein 2.5 inch lift kit, do i need to also buy upper control arms? i am not going to be doing much if any offroading so would these have any importance because i know they are recomended.
    any advice on why i should or shouldn't get the upper control arms?
  2. Nov 2, 2009 at 8:31 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
  3. Nov 2, 2009 at 8:32 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Use the search function. Lots of threads
  4. Nov 2, 2009 at 8:35 PM
    Dellosa89
    Dellosa89 Love peace and Taco Grease
    Brian
    Murrieta CA
    07 Prerunner TRD Off Road
    Fox 2.5 Coilovers, Camburg 1.25" UCA's, Icon RR, Icon aal,EVS foam bump stops, Borla Catback, HID Headlights and fogs, Defiant light bar, 3 hella 700 hid, Satellite Radio, Sony hu with 10'' sub, custom jetski rack, TRD seat covers, secondary air filter removed.
    Your not going to need the UCAs, but at 2.5" lift, ur truck will want to feel like its floating on the road, thats from when its lifted that high ur truck will not have the same stearing geometry as it did when it was stock.
    The after market UCAs will fix any allignment issuse.
  5. Nov 2, 2009 at 8:36 PM
    Dellosa89
    Brian
    Murrieta CA
    Like he said, u will find ur answer on here
  6. Nov 2, 2009 at 8:39 PM
    jake slatnick
    jake
    San Diego
    Cement TRD Pro
    so all it does is effect my turning? its not going to wear out my tires quicker or do anything bad to my truck?
    basically why is it worth or not worth spending the 450 dollars
  7. Nov 2, 2009 at 8:40 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    It will definitely wear out the tires. If you dont want that and you want your alignment to be correct then get uca's.
    wi_taco likes this.
  8. Nov 2, 2009 at 8:42 PM
    jake slatnick
    jake
    San Diego
    Cement TRD Pro
    how much faster do you think there going to wear out?
  9. Nov 2, 2009 at 8:44 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Depends on how much you drive. The sides will wear faster though. not the whole tire.
  10. Nov 2, 2009 at 8:45 PM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2021 Jeep Rubicon
  11. Nov 2, 2009 at 9:16 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    In the time it takes to slam him, you could just say yes or no you realize.
  12. Nov 3, 2009 at 7:51 AM
    magneticnick
    magneticnick Well-Known Member
    Nick
    Orange, CA
    2010 DoubleCab TRD Sport
    None Yet
    This is new news to me, so the spacers will cause caster/camber issues huh?
    I HAVE read lots of posts about lifts on this website and I am fairly proficient when it comes to suspension and mods but I was not aware that the spacers would cause issues resulting in un-even tire wear.
    Now that I know this, I will re-consider on my purchase. (I was thinking about spacers)
    I am assuming this issues DOES NOT occour if a coil over shock is purcahsed does it??? I realize they are far more expensive but I think I would rather go that route than spacers and UCA's. Does any 2WD guys ever go with the Camburg 4" Spindles?
    Sorry for the thread jack, but I feel this question is relevent to the subject.
    Thanks!
  13. Nov 3, 2009 at 7:57 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    It's the lift itself that causes the alignment issues, not the means of providing lift. Coils vs. spacers does not matter.
    The suspension is designed to work a certain way at a certain ride height. You change the ride height, you change the suspension geometry. The lift results in the lower arms sticking out farther than the upper arms. New UCAs are physically wider than stock ones and push the top of the spindle out, which helps correct alignment issues.
    Please search.
  14. Nov 3, 2009 at 8:06 AM
    magneticnick
    Nick
    Orange, CA
    None Yet
    Ok, I am following you now. So it would be safe to say that with almost any kind of lift you have to get a UCA??? And just for my own piece of mind, this does not happen on a Ford/Chevy b/c the lower control arms have adjustment cams that you can use to pull the lower control arm in to compensate for the new geometry.
    I think I got it now.
  15. Oct 23, 2017 at 7:57 AM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Just get it, wish I did from the beginning. Ate up new tires.
  16. Oct 23, 2017 at 8:01 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Yes. At or above 2.5" of lift you SHOULD get new UCA's
    Alexely999, PackCon and boogie3478 like this.
  17. Oct 23, 2017 at 10:55 AM
    TRD Ferguson
    TRD Ferguson 1st class second guesser
    Pac Nor
    2015 DCLB 4x4 TRD Sport, 2018 4Runner SR5
    OME Lift, All Pro Bed Bars
    I did a OME Lift on my 2015 DCLB and got 2.5in of lift. Initially went without UCA's but after alignment issues had UCA's installed.YMMV
  18. Oct 23, 2017 at 10:57 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    The more important question is why are you buying a bilstein lift when you are driving a Pro??
    mattRADICAL, 757yotas and PackCon like this.
  19. Oct 23, 2017 at 11:11 AM
    ncguire
    ncguire Active Member
    Albuquerque, NM
    15 Tacoma TRD Sport DCLB
    Also what year do you have? Profile photo looks like a 3rd gen, not sure if anything in this thread even applies to your truck as this is 2nd gen section
  20. Oct 23, 2017 at 12:33 PM
    iK0NiK
    iK0NiK Insert custom title here.
    West
    Columbus, GA
    2015 DCSB V6 TRDOR 4WD
    Bil 6112/5160's etc.
    Original question/thread was from 2009.
    ncguire likes this.
