With Bilstein 5100s installed, What is the biggest tire size I can get away with ??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by VdubVr6, Nov 18, 2013.
  1. Nov 18, 2013 at 8:17 PM
    VdubVr6
    VdubVr6 [OP] Well-Known Member
    :rimshot:
    alittle rubbing is ok.
  2. Nov 19, 2013 at 11:20 AM
    VdubVr6
    thinking on either BFG A/T or BGF Mud Terrain
  3. Nov 19, 2013 at 1:50 PM
    Raceline08
    Raceline08 Well-Known Member
    Brett
    Santa Rosa, ca
    Silver 08 DBC SB 4x4 TRD Offroad
    front Billies, 885x coils, taco lean spacer, TC UCA'S, Magnaflow 22" OME Dakars, Billy 110 rear's, B.A.M.F CMC, custom made E-locker guard
    .........well..... It depends on what your set up is or what you want to achieve. Are you wanting just replacement 5100's with the stock coils? Lift coils? Setting the 5100's up to achieve lift? Need more info. There are a lot of options with 5100's etc etc or just a strut/coil combo anyways.
    Thanks,
    Brett
  4. Nov 19, 2013 at 1:52 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Without changing your geometry 5100's and lifts make zero difference in what tires you can fit.
    This question has been asked a million times since 2004 when these trucks came out. I suggest you do some research by searching.
    Oh and I'd say with 5100's you could run 325/85/16's :D
  5. Nov 19, 2013 at 4:04 PM
    jdubber
    jdubber Well-Known Member
    So Cal
    Silver 2013 OR DC
    I installed 5100's in the front and back. I set the front at 1.75 and put 275/70r17's on aftermarket Pro Comp wheels. I had to remove the mud flaps and some plastic from inside the fender.
    Pro Comp 7032- 17x9
    Backspace=4.75
    Max Load =2200 Lbs
    Finish=Flat Black
    Hub Centric = NO
    Offset = -6mm
  6. Nov 19, 2013 at 7:01 PM
    VdubVr6
    Im just replacing the strut and using stock springs.
    Using stock 16" wheels
    I have stock rugged trails ( 265/65/16 ) tires on truck now.
    I just see some guys with bilstein 5100 setup running same size tires as stock... but not sure why they'd run same size after lifting truck.
  7. Nov 19, 2013 at 7:13 PM
    VdubVr6
  8. Nov 19, 2013 at 7:26 PM
    VdubVr6
    plan on setting 5100's to 1.75" in front.
    would I be able to swing 275/75/16 bgf nud terrains without cutting / trimming anything ?
  9. Nov 19, 2013 at 8:02 PM
    Rogerwh0
    Rogerwh0 Member
    Eastern Utah
    2002 SAS Tacoma,,, 2014 TRD
    I just put 5100's on my 14 double cab. I set them all the way up. 2.5 I think, I put in toyo mt 285's on stock rims. I did have to put a 1.25 wheel spacer on the front to keep them from rubbing the upper control arms. No rubbing other than the mudflap on the bumper. I took those off in less than 2 min. Looks perfect
