With clear coat peeling, do you still wash it?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by UTVolyaker, Aug 20, 2018.
  1. Aug 20, 2018 at 12:26 PM
    UTVolyaker
    UTVolyaker [OP] Well-Known Member
    Central Virginia
    So my 2007 red tacoma is bubbling and peeling the clear coat as I have found out is a common problem with trucks in this year. Question now being, do I still wash it, as it looks like the bubbles would peel off if I even washed it off with the garden hose.
    Thanks for any suggestions. Love this truck as it only has 125,000 miles on it with no problems, so this clear coat peeling is really frustrating.
    george101 likes this.
  2. Aug 20, 2018 at 12:31 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    First the clear coat,then the paint then rust. If the paint is still good why not have it clear coated again.
    Sooner than later.
  3. Aug 20, 2018 at 12:34 PM
    Clearwater Bill
    Billy
    Largo Florida
    Doesn't matter. It's gonna peel regardless.
    If you want to keep whatever is there 'clean' in terms of dirt/pollen/bird droppings, etc., wash away.
    Feel free to use a 'touch' car wash too, if you wish. You're not going to hurt anything now.
    Eventually you'll have to decide if you want a proper repaint, a budget repaint or a bedliner/Monstaliner finish.
    In the meantime, keep in mind that 'flat' is the current hot look in hot rods and show cars. 'Cause w/no clear, you be flat. :D
    Running Board Man likes this.
  4. Aug 20, 2018 at 12:41 PM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    I would still wash it and even use a sealer (synthetic wax) just don’t polish it.
    I would handwash only no autowashes of any kind (that goes for all vehicles really). I also would hand apply a sealer like Jet Seal. It will help prevent future oxidation from being so bad and will help stop that process.
  5. Aug 20, 2018 at 1:10 PM
    PackCon
    Connor
    No it doesn’t.
    Autowashes use harsh soaps that strip my high quality products off my truck. It also dehydrates rubbers and plastics like none other.
    You can keep paint, rubber, and trim looking like new for a couple decades if you use quality protective products. Those autowashes just strip everything off leaving a vehicle unprotected to anything it comes in contact with.
    My vehicles will remain handwash only.
    And no one needs to wash their vehicle every day. That makes me cringe too.
  6. Aug 20, 2018 at 1:17 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Buy a can of clear and spray it yourself
  7. Aug 20, 2018 at 1:21 PM
    PackCon
    Connor
    OP you can do this. I mean its not really going to make it look worse...
    Or bed line it. But thats still costly.
    I’m an avid detailer. If my Tacoma ever got damage where it was up to me and my pocketbook to repaint I’d go bedliner for the lower maint.
  8. Aug 20, 2018 at 4:47 PM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Vinyl wrap
    MFTAF13 likes this.
  9. Aug 20, 2018 at 5:14 PM
    Pigpen
    Dan
    Northwest Montana
    Wait, you guys wash your trucks?
    desertrunner24 and b_r_o like this.
  10. Aug 20, 2018 at 7:01 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    :rofl: i was thinking the same thing. I'm doing good if i wash it twice a year now since my paint went to shat
