Witness marks on bolts, taking it in for first oil change
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jesse H, Jun 17, 2023.
  1. Jun 18, 2023 at 9:32 AM
    #61
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    You could mark the drain plug, but what happens when the marks line up exactly even though they actually changed it? A hidden camera is about the only real solution. Even then, to what lengths are you going to go through just to prove they actually did an oil change? An oil change which they do dozens of per day and it's literally a nothing job for them to do.
    WilliamJames likes this.
  2. Jun 18, 2023 at 4:12 PM
    #62
    shark56
    shark56 Well-Known Member
    Wow. Some of you guys have a hard time with reading comprehension...
    Op, if I was in your position, and I have been before, since you already know how to change it yourself, I would continue doing that. To many chances of some knucklehead at the dealership screwing up. Plenty of threads on here of issues with dealer oil changes.
    Just document your supply purchase and note when you had it done. In addition to noting it I also write date, milage, and amount of oil with a sharpie on the bottom of the hood. If you can't do the tire rotation then I would go to a tire shop.
    Even if you marked the skid plate bolts or even the Oil canister, what would you do if you found out they didn't do the job correctly or at all?
    Peace of mind if you do it yourself. Plush you know you didn't over torque the Canister, drain plug, screws or bolts.
  3. Jun 18, 2023 at 4:28 PM
    #63
    4Stents
    4Stents Roost or be Roosted
    Appleton Wisconsin
    2013 White Tacoma SR5 , w/peeling paint.
    Frame recall done
    My PTSD and Reflux is in full swing reading this post.
    Malvolio likes this.
  4. Jun 18, 2023 at 4:46 PM
    #64
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
  5. Jun 18, 2023 at 10:19 PM
    #65
    PoolFixer
    PoolFixer Well-Known Member
    22 MGM AC SR5 V6 2WD
    OEM TRD headlights, bed lights
    Did it list a Toyota dealer high school apprentice oil change newb rookie tech spec? That trumps all others.
  6. Jun 19, 2023 at 5:20 AM
    #66
    Bluridge120
    Bluridge120 Well-Known Member
    EM85
    22 TRDOR DCSB AT CSM
    You could paint the existing filter yellow and then know if it was replaced. Sharpie trick can be replicated without actually changing the filter element. I guess I don't understand someone who cares enough to want to get it right then decides to take it to a dealer with an 18 yo kid in the express lane slamming 100 ft pds torque on the plastic filter housing even if they actually do change it. How do you trust but verify proper torque? Or does that not matter as long as it was changed?
  7. Jun 19, 2023 at 5:30 AM
    #67
    rndsommer40
    rndsommer40 Well-Known Member
    Ralph
    2022 TRD OffRd DCSB
    I dont trust the dealers. I marked my tires for my first service. Said they rotated them. They didn't. Then I guestioned them about the oil. The service manager asked me to bring the car back in and I just changed dealerships after leaving a bad Google review. I told the new service advisor that I check everything and expect it done right. I got the freebies out of the way and won't ever go to the dealer unless it's a warranty repair.
  8. Jun 19, 2023 at 5:57 PM
    #68
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    If you distrust the dealer thus much, why not change it yourself?
    hiPSI likes this.
  9. Jun 19, 2023 at 6:05 PM
    #69
    Redfive11
    Redfive11 Well-Known Member
    La Mirada, CA
    2012 PreRunner
    FOX 2.5 EXTENDED TRAVEL w RESI /DSC CAMBURG UCA PELFREYBILT HYBRID FRONT BUMPER
    Have you not read through the thread?
  10. Jun 21, 2023 at 12:13 AM
    #70
    Sandthemall
    Sandthemall Well-Known Member
    Sandamal
    2023 TRD OR MT
    With my 2020 Tacoma, I did my first oil change (1,000 miles) at the dealer. I told them ‘I know it’s an early one…but I’ll pay for it’. They did it…and I paid. I checked the dipstick level and felt the oil before and after to verify. When I brought it in for the first free maintenance at 5k, I noticed on the service sheet that they did not change the oil. I confirmed this with the owners manual/service schedule. So I purchased a Toyota oil filter element and took the truck to Jiffy Lube. And I know Jiffy Lube occasionally screws things up…but you just have to be vigilant. Next time I went in @ 10k miles, I asked the dealer if the oil would be changed and they confirmed it.
    I go to a reputable Toyota dealer so at some point, I gotta just trust them. But with my new 2023 Tacoma, I’m not taking chances…just going to do it myself with some dealer appointments thrown in until after the 2 year complimentary program when I (hopefully) find a good independent Toyota service center.
    pop.tremuloides likes this.
  11. Jun 21, 2023 at 8:54 AM
    #71
    pop.tremuloides
    pop.tremuloides Well-Known Member
    Colorado
    2019 TRD OR DCSB
    DBACK HD, Armor, SP9100, lights...etc
    After one oil change on my 2019 OR, I decided to do it myself. Dealership admitted that they did not do ANY fluid changes as they were in a rush. I marked things prior (This has happened previously on other vehicles) and had a not so pleasant discussion with the place we purchased from.
    I know what goes in my Truck! I know I did it correctly! An oil change/filters/brake fluid are easy things for me as I do it all the time on our other vehicles. If you CAN do it, you should...then you know what goes in your vehicle and you also know it is done correctly!
  12. Jun 21, 2023 at 10:47 AM
    #72
    GBourne
    GBourne Just a regular guy
    Grant
    Surprise, AZ.
    23 Ram 1500 Classic
    Dumped the Tacoma, that's all it needed.
    There are too many posts about someone doing their own oil change and finding no filter in the housing from a dealership change.
    so, you can mark whatever you like and climb under and check everything you want, but unless you do it yourself, you’ll never know if it was done correctly until after it’s too late.
    you are going to the dealership. If they mess up and it’s found down the road, you have documentation.
    neither change it yourself, or let the dealer do their job to whatever capacity that they do it and be done with it.
  13. Jun 21, 2023 at 12:57 PM
    #73
    pltommyo
    pltommyo Well-Known Member
    Tom
    2016 Gray Tacoma TRD Offroad
    SSO hybrid bumper, Warn winch, RCI skid trilogy, RRW sliders, everything in the cheap/free mods thread, and of course the frame recall work.
    If you do not trust them to do the work, it is not worth the pittance saved on paying a reputable place to do it, or do it yourself.
  14. Jun 21, 2023 at 1:13 PM
    #74
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    Just ask for the old filter back; problem solved.
    Make up some BS about your wife's boyfriend's step-uncle being a contact at Blackstone Labs, and he's gonna do an in depth oil analysis using the old filter to determine once and for all if its supposed to be 3k, 5k, or 10k oil change intervals.
  15. Jun 21, 2023 at 7:04 PM
    #75
    PoolFixer
    It's a time vs cost issue. Retired guys can change their oil any time. I already have a ton of things to do on my two days off before I even think about doing something fun. I payed a lot of money for a new truck. Part of the enjoyment of owning a new vehicle is not having to worry about maintenance for a while, I'll let the dealer do it. I'm damn sure going to check their work after, it's not a big deal.
  16. Jun 21, 2023 at 7:06 PM
    #76
    Zuba Gooding Jr
    Zuba Gooding Jr Well-Known Member
    translation you dont trust anyone
    trust and confirm lol
  17. Jun 21, 2023 at 7:11 PM
    #77
    PoolFixer
    He does'nt trust the newb tech trainee at the dealer to do a proper oil change, I don't blame him.
  18. Jun 21, 2023 at 7:44 PM
    #78
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Yet, that high school noob does a better job than most owners, as evidenced by all the posts where the owners fucked up their own oil changes by doing it themselves.
    You guys assume that everyone posting can wrench on their own.
    Newsflash: not many can wrench on their own without fucking things up.
    My dealer, when it's time for a fluid change, sends me pics, license plate shown, of him and what he does. Zero problems, zero questions. I check the oil, I slide underneath to check for leaks and I move on.
    You guys who think you are better that that high school kid should take a hard look in the mirror and admit you shouldn't ever wrench on your truck because it will be worse than when you started.
  19. Jun 21, 2023 at 7:56 PM
    #79
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    It’s the way the industry is going. By the end of next year the lube guys at the dealership I currently work at will be required to make a video of the mpi and work to be emailed to the customer showing what was checked and done.
  20. Jun 22, 2023 at 4:25 AM
    #80
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    You can also update your Toyota profile on line. It’s nice to have it listed in one place.
