WIX products
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tammikm, Mar 19, 2012.
  1. Mar 19, 2012 at 1:48 PM
    tammikm
    tammikm [OP] Well-Known Member
    canada
    06 DC 4x4 SR5 AUTO
    n/a
    anyone here use a WIX oil filter(51348), local parts store claims as good as mobil 1,
  2. Mar 19, 2012 at 2:00 PM
    speedydave
    speedydave Well-Known Member
    Dave
    Hickory, Nc
    Mustang GT
    WIX<mobil 1<toyota
  3. Mar 19, 2012 at 2:14 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    wix is quality stuff
    same as napa gold
    1348 or 1516 is a bit taller but still fits
  4. Mar 19, 2012 at 2:35 PM
    tammikm
    canada
    06 DC 4x4 SR5 AUTO
    n/a
    thanks,
    this means?
  5. Mar 19, 2012 at 2:46 PM
    angrysam
    angrysam Huh?
    Sam
    Somebody's Shit List
    2.9 Gen- Not a cunt.
    Fleshlight and an old Farrah Fawcett poster.
    I've used WIX for years without any issues. But I can get the Toyota filter for less than a WIX for my truck.
  6. Mar 19, 2012 at 2:51 PM
    steviestyles
    steviestyles The "Search" tab is your friend!!
    Colorado Springs
    07 DC 4x4 TRD Off Road
    Bone Stock
    Wix makes great filters. I use their air filters and used to use Napa Gold filters which are made by Wix. I use PureOne oil filters because they're a little cheaper than Wix/Napa Gold. Either way, use Wix without fear.
  7. Mar 19, 2012 at 5:42 PM
    S7ICKlVlAN
    S7ICKlVlAN Cpt. Bubbleguts
    Dave
    Hawaii
    2012 TRD Sport DCSB
    TRD badged | Hunting Cage | Smoked Tails | LED Everything | Slim Cubby HID bi-xenon's | Spidertrax 1.25" | BHLM | FLM | S2000 Ant | 20% Shade | PL 8521 | OME 885 | Bilstein 5100's | Toytec 2" AAL | FN 18x9" Bronze BFD's | 275/65-18 Duratrac's | Wrinkle Red Valve Covers | 3M Di-Noc Wrapped Interior | Kode MB Push Button Ignition | Relentless Sliders | URD TCAI | Mr.Marv Enclosure | Arc Audio 10" | Hybrid Audio Clarus F/R | Alpine PDX-5 | Alpine INE-S920HD
    Agreed with the above. Wix is one of the best.
  8. Mar 19, 2012 at 5:46 PM
    TurboGT
    TurboGT Stirring the pot since...
    Gabe
    Portland
    '16 Inferno DC LB 4x4
    None yet, starting over!! OME lift w/ Dakars & 885's Remote Start w/ window control
    Mathmatics talk....
    < means less than
    if you flipflop the entire thing it says
    toyota > mobil 1 > WIX
    > means greater than.... and in other words,
    Toyota is greater than Mobil 1, which is greater than WIX
    Chris4x4 also made a great post about how the Toyota filter is a tad bit superior than the other... Made me totally rethink where I buy mine from.
    You can read his post here
  9. Mar 19, 2012 at 5:48 PM
    speedydave
    Dave
    Hickory, Nc
    Mustang GT
  10. Mar 19, 2012 at 5:50 PM
    TurboGT
    Gabe
    Portland
  11. Mar 19, 2012 at 7:16 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    I use either Napa Gold (Wix) or Purolator PureOne.
  12. Mar 19, 2012 at 7:21 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I wouldn't have a problem using a Wix, which is the same as a NAPA gold, but I don't believe it's any better than the factory one, and those are reasonably priced, so I use the OEM. I don't know anything about the Mobil One filters.
  13. Mar 20, 2012 at 6:59 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    If you're running a 5K OCI, all the filters mentioned so far, including Wix, will be more than sufficient. If you buy in bulk (10 filters), the OEMs are the best price though. Only time I would put any more thought into it is if you plan on going to extended drain intervals.
  14. Mar 20, 2012 at 8:41 AM
    badger
    badger Well-Known Member
    07 SR5
    Agreed that Wix. Napa Gold are good filters, but I do believe the OEMs are a bit better. They have more filtered area in the media and even though the bypass valve in the Wix is good, the OEM is a little better IMO. As for air filters, Wix/NG is all I use
