Wizzard005's 2012 Retro Fit Build ( DONT ) Pictures.....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Wizzard005, Dec 5, 2011.
  1. Dec 5, 2011 at 2:03 PM
    Wizzard005
    Wizzard005 [OP] Well-Known Member
    Greg
    Sacramento, CA
    Stock
    Aloha all,
    ** sorry for the typo in the title ** DONT should be Done ;)
    Well after two days my retro fit is done! What a pain in the butt it was! I was planing on taking many pictures, but then got very lazy. Here are some of what i did take. Let me know what you all think..
    Direct Link to Full Sized Pictures: http://wizzard005.smugmug.com/2012-Toyota-Tacoma
    These are the pictures with my crappy cam
    Now Pictures with my DSLR :)
    Last but not least!
  2. Dec 5, 2011 at 2:05 PM
    Large
    Large Red
    Sick.. And way sick 2012.
  3. Dec 5, 2011 at 2:10 PM
    SoJersey
    SoJersey Man.As.Prescribed
    Brandon
    08302
    '12 DC Offroad
    Pelfrey Armor Baja Designs Lights 6112/Camburg/Dakar Suspension ARE Z-Series More coming soon...
    what kit are you guys using for this? i'm interested in doing this for mine!
  4. Dec 5, 2011 at 2:11 PM
    SoJersey
    Brandon
    08302
    '12 DC Offroad
  5. Dec 5, 2011 at 2:13 PM
    Wizzard005
    Greg
    Sacramento, CA
    Stock
    The Kit was the Mini D2S. To be honest I really wasn't impressed with this kit. The alignment bolt I could not use because the hid housing with like 5% off (not level light output) There was no way to fix that besides taking the alignment bolt out... Other then that, no directions for some reason, but i didn't run into any problems. Everything worked first time.
    I did do a few test fits to make sure everything fit because i mounted everything.
    The lights are a pain in the butt to take out with the bumper on, i tired to take it off but gave up after spending like an hour taking screws out...
    I also dont understand why these 55watt hids need their own relays?? The amp is the same as the stock bulbs, with no relays in the way it would have made a very clean(er) install.
    For the price of the kit, i guess it was fair, however if they sold a kit with no replays and more of a plug n play setup for more money i would have gone that rout.
    All and all i am happy.
  6. Dec 5, 2011 at 2:14 PM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN GEORGIA
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    i was curious as well i noticed in the last group buy for trs almost everyone bought the d2s mini instead of the H1's this confused me.
  7. Dec 5, 2011 at 2:16 PM
    Wizzard005
    Greg
    Sacramento, CA
    Stock
    orig I ordered the better kit, however I was UN-willing to cut the housing apart that much, so the Mini was a better fit for me...
  8. Dec 5, 2011 at 2:18 PM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    dude your runnning a 55 watt ballast with mini d2's!
    thats not good the mini both of them the d2s and the H1 are both an open design which means that massive amounts of heat will be escaping through the middle of the projector as well as their plastic parts being heated to death.
    which one of the trs guy's set you up with this or did you source your parts elsewhere?
    edit: are you getting any smoking in the housing or any visible vapor discharge of any kind?
  9. Dec 5, 2011 at 2:22 PM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    i was referring to the mini H1 they mount in the exact same way and are literally twice the projector. the cost is the same and everything. the only thing that is not so great is you have to run rebased bulbs by trs which imo are fine but your not going to be able to run a phillips d2s oem bulb with out modification.
  10. Dec 5, 2011 at 2:34 PM
    Wizzard005
    Greg
    Sacramento, CA
    Stock
    No smoke maybe i have the 35 watt. Andrew from the company said it will be fine
  11. Dec 5, 2011 at 2:34 PM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    either way man i would keep a very close eye on things as i know first hand that the minis are not really supposed to be run with 55 watt ballast.
    i was going to get the H1 from bjorn but i had wanted to run 55 watt's this time around and both he and andrew at trs confirmed that while you obviously could run that high a wattage with them it will produce problems down the road no doubt about it.
  12. Dec 5, 2011 at 2:37 PM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    yeah 35 watt is ok thats no problem at all but, 55 watts is a no go brother trust me on this. i was looking into the mini's recently myself and i was told and more importantly shown first hand why it would spell disaster down the road lol.
  13. Dec 5, 2011 at 2:39 PM
    Wizzard005
    Greg
    Sacramento, CA
    Stock
    Will keep my eye on it. I will check to see what ones they are when i get home least the ballists are easy to change :)
  14. Dec 5, 2011 at 2:49 PM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    trs marks there ballast with 3five for the 35 watters and 5five obviously for the 55 watt ballast lol.
    if andrew told you it was ok to run 55 watts in the minis he messed up no doubt like i said i just went through this myself a little over a month ago.
    i know that you probably used your factory housings for this so i just didn't want you to run into problems if you could just swap out the ballast now before you actually damage anything. those factory housings are very expensive for what they are the older style 2nd gen headlights are well over 400 dollars a set.
    btw one more quick question how long have you run the lights? meaning if you where to run the lights for around an hour or so in the drive way and let them heat up i have a good feeling that if they are the 55 watt ballast they will begin to smoke look closely. shit my 55 watt fx-r and my ls 460 set-up smoked a tiny bit. and they are sealed units.
  15. Dec 5, 2011 at 2:58 PM
    Wizzard005
    Greg
    Sacramento, CA
    Stock
    I just got off of the phone with andrew he sai the setup i have is corect
  16. Dec 5, 2011 at 3:34 PM
    beaver_scott
    beaver_scott Well-Known Member
    scott
    renton, wa
    2015 inferno trd pro
    vent shades, tinted windows, clear bra, pop n lock tail gate lock, anytime fog light mod.
    huh, i was told that the hid lights burn at a cooler temp than a halogen bulb. was i misinformed? i run the 35watt in my d2 mini retrofit and i notice when my car frosts overnight my headlights dont defrost as well as they did when i had halogen bulbs.....due to less heat?
  17. Dec 5, 2011 at 3:39 PM
    MBTaco21
    MBTaco21 Well-Known Member
    so sick! bhlm in the future?
  18. Dec 5, 2011 at 3:45 PM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    due to it being focused by the optic in your projector the bulb it self is hot very hot.
    with 55 watts heat is alway's something one should keep an eye on when choosing components and projectors. i hope the op can easily swap this out for the correct wattage if he does in fact have the 5five's.
  19. Dec 5, 2011 at 3:45 PM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    meaning you have 35 watt ballast?
  20. Dec 6, 2011 at 12:25 AM
    Wizzard005
    Greg
    Sacramento, CA
    Stock
    See attached, this is what i have, well not sure about the relay, but i have this setup.
    Again, talked to Andrew, he assures me its all correct, I am sorry for saying 55 watt what it is really 50 watt..
    Hope this clears everything up
