wobble from the rear end on acceleration
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OH9, Mar 12, 2011.
  1. Mar 12, 2011 at 8:20 AM
    OH9
    OH9 [OP] Member
    Colorado
    09 dbl cab auto stock
    Going to the shop again today to see what is the problem. Truck wobbles while acceleration and vibrates between 15-25 goes away then returns while braking through the brake pedal with a bad shake. Has anyone had this problem? My truck is a 09 tacoma d-cab trd sport. Thank you
  2. Mar 12, 2011 at 6:30 PM
    Gene563
    Gene563 Well-Known Member
    Eugene
    Lanoka Harbor, NJ
    08 Double Cab, LB, TRD Sport
    TRD catback exhaust, Undercover hard tonneau, Vent visors, Husky liners, customized seat covers, front license plate bracket, rear suspension TSB, Eibach springs w 5100s@0, & General Grabber AT2 (265.70.17).
    ...lugnuts?
  3. Mar 12, 2011 at 10:11 PM
    MrFastLayne
    MrFastLayne Mr SGA
    Layne
    Lincoln Ca,
    07 Tacoma 4x4 SR5 V6 Off Road
    Lift,Winch,Shell,Light Bar,Siren,Radio's
    U joints / Drive line?
  4. Mar 13, 2011 at 1:19 AM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    Who will get it right?
    Bent axle.. only because I just helped a guy change out his and the jeep wobbled.
    But.. also a guy noticed that all his u joint bolts were loose on the forum here somewhere.
    Only time I had that problem was when I forgot to tighten up the hub on my VW.
