Wobble under braking, wtf?
Discussion in 'Technical Chat' started by Tillers_Rule, Jan 19, 2016.
  1. Jan 19, 2016 at 2:05 PM
    Tillers_Rule
    Tillers_Rule [OP] ......................
    Jeff
    San Diego
    4x4 Sport, debadged
    Icon coil overs up front, Total Chaos UCA, Icon remote reservoir in the back with Deaver 11 pack leafs. Sunroof, Hella 500's behind grill.
    So,
    I did some research on this and the general consensus for causes of wobble under braking are warped brake rotors.
    Anyway, I had the problem arise at about 90,000 miles, or so. At 100,000 miles I replaced the brake rotors, brake pads and bled the brakes. Also had new tires installed and an alignment performed. Truck was fine and the wobble went away. Over the past several months wobble had returned, now it's at the point where it almost seems dangerous. It's especially noticeable when going downhill and more weight is over the front.
    I've checked the wheel bearings and tie rods and don't think they are to blame.
    I'm now thinking maybe the rotors I threw on are junk and warped already. I went with Duralast, lifetime warranty from Autozone. The warranty seems pretty worthless if the same thing is going to happen in another few thousand miles.
    My questions are:
    Any ideas on what is causing my issue?
    Any suggestions on better brake rotors?
    I'd like to avoid spending money on needless parts, but also would like to resolve the issue.
    Thanks
  2. Jan 21, 2016 at 10:15 AM
    kubatcha
    kubatcha Well-Known Member
    I had the same issue but I bought toyota brake rotors and pads. I have not had any issues arise so far.
  3. Jan 21, 2016 at 10:24 AM
    zeekevin
    zeekevin Well-Known Member
    San Diego
    Long time no see Jeff. It's probably the cheap ass rotors that's causing your vibration under braking. I would get some quality rotors that can handle the heat and not wrap
  4. Jan 22, 2016 at 10:27 PM
    pofarm
    pofarm Well-Known Member
    Greg
    SW MO
    1996 Taco
    Also check that the brake pads are releasing completely. If one or both are dragging they can overheat and warp the rotors. I've used duralast rotors several times without issues.
    Other things that could also cause wobbling, although to a lesser extent, would be worn bearings, tie rod ends, ball joints, or control arm bushings.
  5. Jan 23, 2016 at 3:22 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Make sure your wheels aren't too tight. Over torqued lug nuts can cause premature warpage on the rotors.
    I torque all my lugs at 100ft lbs. Been doing that for 15 years on all vehicles.
    If you're not using a torque wrench to tighten your lugs, you may want to consider buying one and using it each time.
  6. Jan 25, 2016 at 7:43 PM
    Tillers_Rule
    Jeff
    San Diego
    4x4 Sport, debadged
    Thanks for the replies. I was thinking it's probably the rotors but just sucks since I just replaced them! Must be my professional level driving where the off the shelf stuff just can't hang:cool:
    Lugnuts are always tightened with torque wrench to factory specs, as are all other bolts.
  7. Jan 25, 2016 at 7:49 PM
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    Bpv? Maybe your front brakes are doing to much of the braking. Causeing the rotors to warp.
  8. Jan 25, 2016 at 7:53 PM
    GrayTacoma
    GrayTacoma Well-Known Member
    Andy
    Huntingtown, MD
    2011 TRD off road
    PIAA ion yellow fogs stay on all time,aux reverse lights, aux lights, camper with rack, cb, air bags, on board air, aux fuse box, aux batt, CAI, etc.............
    ^^^^^This^^^^^^
  9. Jan 25, 2016 at 8:10 PM
    jokker1978
    jokker1978 Well-Known Member
    southeast texas
    2012 TRD sport 4dr 4x4 white
    But rotors with a life time warranty. I was in a bind and all the parts store had in stock at the time had a 1 year warranty. They lasted about 3 months.
    I brought them back and bought the good ones. Problems solved.
  10. Feb 8, 2016 at 6:33 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    I bet you did not put in NEW slider pins that the pads slide on... That happened to me.... the caliper are sticking on one side of the rotor and not the other... that will cause a wobble....... Remove the old ones and replace, and lube those pins... no more wobble, I bet..
    Good luck
  11. Feb 8, 2016 at 6:48 PM
    sawed off
    sawed off Well-Known Member
    Randy
    Idaho
    Prerunner 2wd 2.7 SR5
    Junk Chinese rotors, Have the old ones turned if you still have them and there still in spec.
  12. Feb 8, 2016 at 6:54 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Yep! Much better to pay the bit extra and get OEM ones or cut the old ones of they are still in spec.
  13. Feb 8, 2016 at 7:01 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    I wouldnt waste time or money on getting them turned...if they are warped it will come back in no time...I tried getting a set of rotors turned and it was good for a month then the warp was back...I just broke down and got some new rotors, pads etc..lube the pins and make sure your caliper isnt binding..
  14. Feb 8, 2016 at 7:04 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Cut them on them while on the vehicle, most newer vehicles that's what your suppose to do
  15. Feb 15, 2016 at 8:08 AM
    nyg052003
    nyg052003 Nyg052003
    Charleston, SC
    04 Tacoma TRD Offroad SR5 4x4
    So if i go through a parts store, which ones aren't junk chinese lol? Is it Toyota's brand only that aren't.
    I'm getting a wobble under hard braking more so and just called a shop that I deal with. Guy told me yes about the toyotas he recommends changing the rotors vs turning them.
    I was going to check Rock auto as well and compare prices but i certainly won't buy cheap and have to pay labor again to put better ones on.
  16. Feb 15, 2016 at 8:09 AM
    nyg052003
    nyg052003 Nyg052003
    Charleston, SC
    so what did you end up doing?
    I have the same situation now
  17. Feb 15, 2016 at 8:57 AM
    sawed off
    Randy
    Idaho
    Yes good rotors are expensive. We all want walmart pricing and that's what we get. Always best to machine OEM rotor when possible. Good shops turn rotors, slam bam shops install rotors. Very time consuming to properly turn rotors.
  18. Feb 15, 2016 at 9:03 AM
    nyg052003
    nyg052003 Nyg052003
    Charleston, SC
    I'm not sure I get what you are saying okay if I go to the parts store which ones should I go with as far as what they will offer me what should I look for ect. or should I just get the Toyota ones or what I mean I am all for comparing prices and that's what I do but I want to get a good one. And not sure if you are saying that a good shop well you said always good to machine OEM ones. I'm guessing by by saying machining I'm guessing you're saying to have them turned? excuse the speech to text lol
  19. Feb 15, 2016 at 9:37 AM
    sawed off
    Randy
    Idaho
    Yes if the shop can turn them you will be better off. Call around and find shop that will. As long as rotor is not passed limits you can have your original ones turned. If new ones are needed then you will have to see whats available, I have never priced Toyota ones but I did for a buick 2 years ago and they were 200 bucks each from dealer. I know ouch!
  20. Feb 15, 2016 at 9:41 AM
    nyg052003
    nyg052003 Nyg052003
    Charleston, SC
    Dang!!!
    I guess they will be able to look at them to see whether they are even warped or not or they have to take them off first? Tires need rotating probably this week or next week so that's when I'm going to let them inspect
    If they can't tell whether they are warped then what or how will they be able to justify turning them lol but I'm sure they have a process for that
