Wobble/vibration? (45 - 55 mph only)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Truckinkoots, Feb 15, 2025.
  1. Feb 15, 2025 at 4:04 PM
    Truckinkoots
    Truckinkoots [OP] Member
    2011 Tacoma TRD Off-Road
    2011 TRD OR V6 Auto. Currently running 265/70/16 winters on original steel wheels.
    Between 45 and 55 mph the truck has a distinct vibration that almost feels more like an up and down wobble. No noise associated with it other than it making the whole truck shake/wobble (more of an up down shake/wobble than a side to side wobble).
    Doesn't matter if I'm coasting, cruising or accelerating. But always happens between those speeds. Once Im over 55mph the wobble goes away. I don't feel it shake/wobble below 45mph.
    I was wondering if it was the carrier bearing having play in it, but it doesn't wiggle around very much and looks to be in good shape. Greased the U joints on the drive shaft this past summer and haven't driven it that much since then.
    Has anyone else has experienced this type of wobble/shaking at these speeds?
  2. Feb 15, 2025 at 4:18 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Does it do it in 4th gear at those speeds?
  3. Feb 15, 2025 at 4:35 PM
    Truckinkoots
    Yea, doesn't seem to matter which gear I'm in.
  4. Feb 15, 2025 at 4:37 PM
    TnShooter
    Deogee
    STOCK
    Does it do it in 4WD?
    TXpro4X4 likes this.
  5. Feb 15, 2025 at 4:46 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Rotate the tires and see if anything changes
  6. Feb 15, 2025 at 5:01 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    I don't think he has 4x4
  7. Feb 15, 2025 at 5:04 PM
    TnShooter
    Deogee
    STOCK
    I guess it could be a PreRunner with OR package?
    But I was just guessing it was a 4x4 based off TRD OR.
    TXpro4X4[QUOTED] likes this.
  8. Feb 15, 2025 at 5:07 PM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    do you have another set of non winter tires?
    Truckinkoots[OP] likes this.
  9. Feb 15, 2025 at 5:21 PM
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    Yhea a locker but no 4x4
    Might be balancing :notsure:
    TnShooter[QUOTED] likes this.
  10. Feb 15, 2025 at 5:54 PM
    Truckinkoots
    Thanks for all the input, everyone!
    To follow up:
    - yes it's a 4x4. I haven't noticed it in 4x4 but I'm usually not going more than 45 mph with 4x4 engaged.
    - might try rotating the tires but I don't drive it that much so I'll probably just wait another 6 weeks until I take the winters off and I'll see if the wobble continues with my all terrains/summer wheels.
    - it could be that the winter tires/wheels need to re-balanced.
    TXpro4X4 and TnShooter like this.
  11. Feb 15, 2025 at 7:17 PM
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    Well it's not the drive line vib if it happens in 4x4
    Still wondering if balance issue?
  12. Feb 16, 2025 at 2:45 AM
    tacokarl
    tacokarl Big Blue
    Karl
    Connecticut
    2008 Pre-Runner SR5 DCLB
    Had this exact issue but from 65 to 70. Warped front rotors, it was the last thing I expected. Might be worth checking out.
  13. Feb 16, 2025 at 5:14 AM
    Mrcooperou812
    Mrcooperou812 Well-Known Member
    Las Vegas NV
    2016 DCSB OR 4WD
    I rotated tires recently and one rear came up front for the first time since it took a rock or log sideswipe, hard enough to gouge the bead rim and knock off the center cap. I never felt anything funny before.
    It suddenly had a passenger drift. I switched the driver and passenger tires and then no drift, but it developed a slight wobble around 45 mph. I then switched it with a rear tire and it again drives straight as an arrow and no wobble.
    I am having the subject tire rebalanced and keep it in the rear.
  14. Feb 16, 2025 at 7:59 AM
    Truckinkoots
    My front brakes are probably due for service later this year. If changing back to my AT tires and summer wheels doesn't fix the issue I will try swapping out the pads and rotors.
  15. Feb 16, 2025 at 8:02 AM
    02hilux
    Planet: EARTH
    Check you DS ujoints. A few years back, I had a similar situation, vibe between 50-55 ended up being a bad ujoint. Went under and shook the DS and noticed one joint with lots of play. Any speed above or below that speed has no vibe.
