Wobbly wombat driveshaft
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sandman614, Feb 4, 2016.
  1. Feb 4, 2016 at 8:54 AM
    Sandman614
    Sandman614 [OP] Ex-Snarky TWSS elf, Travis #hotsavannahdotcom
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Any driveline experts in here? I just got my truck back from Toyota for the frame replacement. Before I took it in it would do this on very hard acceleration, now it does it pulling out of a stop light. The carrier bearing is offset, one side 1.25" to mounts and the other side 2" to mounts. Idk which side was down before but Toyota installed it with the 1.25" side down. I just flipped it and it's better but like I said it did this before just not as bad. I probably need to get an angle finder.. 160k miles.
    https://youtu.be/s_e5_PYiWEE
  2. Feb 4, 2016 at 3:15 PM
    Blacktaco2042
    Blacktaco2042 Well-Known Member
    wisconsin
    supercharger/trd cat back 3inch lift 265/75/16 duratracs bumper guard led bar
    i work at the dealer and when you get a new frame they replace the leaf springs and some are softer then others and that will cause the pinion angle to change on accel and cause a vib
  3. Feb 4, 2016 at 3:36 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Thanks for your input. Same leaf pack as my truck is lifted and requested that the new pack was put in the bed. I will be rebuilding my leaf pack with the new one.
    Blacktaco2042[QUOTED] likes this.
  4. Feb 4, 2016 at 9:21 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    It looks like the differential has an oil leak also. Kind of odd that it is coming from the top... Maybe they spilled the oil when filling...
  5. Feb 4, 2016 at 9:25 PM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    Did you check the u-joints? It could be the carrier bearing, but my truck does not have one so I have not had to deal with issues from one yet
    TacoMitch93 likes this.
  6. Feb 4, 2016 at 10:01 PM
    Taco2Taco79
    Taco2Taco79 Active Member
    The Green State
    2015 TRD Sport MGM DCSB
    Bilstein 6112/5160 ..275/65/18 DuraTracs on MB KO rims...NFab Bars...WetOkoles
    At 45secs it looks like ur drive shaft is hittin the frame
  7. Feb 4, 2016 at 10:27 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Yea that's from the fitting that ECGS put in for the locker. I have the air line disconnected and a cap over it. That's another issue..oil in the air tank.
    It's hitting all kinds of stuff lol.
  8. Feb 5, 2016 at 9:39 AM
    K.Ray
    K.Ray Well-Known Member
    East TN
    2016 Toyota Tacoma TRD Off-Road, 6sp Manual, Quicksand
    None
    I had this problem after frame recall. For me, it was caused by the goons that did the install. They had the rear axle dog-legged to one side. The alignment shop loosened the u-bolts and pushed it back into spec. Smooth now that everything is aligned.
  9. Feb 5, 2016 at 9:46 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    2nd gen? How did they even? The spring pins/bolt lines up the axle to the springs.
  10. Feb 8, 2016 at 9:03 AM
    K.Ray
    East TN
    None
    Your guess is as good as mine. I was watching when they did it. Thing just popped right back into place. Must have not been seated well or something. Techs probably just rushing through the job.
