Woke up dead.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ThunderBunny7, Aug 4, 2011.
  1. Aug 4, 2011 at 4:21 PM
    ThunderBunny7
    ThunderBunny7 [OP] Member
    Lovettsville, VA.
    Rad Red 2007 Toyota Tacoma TRD Off Road
    AEM Brute Force Intake All Pro Off Road Front Bumper PIAA 510 Fogs OME 3" Lift Dakar Leaf Pack Total Chaos UCA
    So, I went to start my truck today and the battery was dead. Wearing my wtf look, I grabbed the jump box, hooked up, and turned the ignition. after about 5 seconds the truck turned over and I was on my way.
    Kinda.
    I'm doing about 55, my turn is coming up so I start to break and the truck jolted like it ran out of gas and turns off. No dash, engine, a/c, nadda. 1-2 seconds later it turns back on and the gauge cluster is going ape shiz and my wtf look is back. I make it to the office, grab what I needed (never turned the truck off) and headed the 5 minutes back to my house. On they way back it happened again.
    I've been home for awhile, went back out a few hours ago and the truck is dead again. I've had dead batteries before, I've had a battery disconnect while driving but nothing ever turned off like that. Any ideas? It's an 07 with 53,xxx miles.
  2. Aug 4, 2011 at 4:32 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Dave Mustaine ?
  3. Aug 4, 2011 at 4:33 PM
    Junebug McQuinn
    Junebug McQuinn Well-Known Member
    Wylie, TX
    2011 TRD Off Road Pre-Runner
    That's what I was thinking, dead alternator and dead battery combined. But sounds like it could be some sort of funky short in the system too. Whatever it is, good luck!
  4. Aug 4, 2011 at 4:37 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    could be a bad ground....
    if when your truck is running the alt is putting out 13-14v then i dont think its the alt. it sounds more like you have a bad ground
  5. Aug 4, 2011 at 4:46 PM
    TanSR5x4
    TanSR5x4 Hold my beer and watch this
    William
    Houston TX
    00 Tacoma SR5 4x4
    Deckplate mod, black KC slimlight fogs, hurculined bed, NRA sticker mod, painted rear chrome bumper black, black fender flares and front grill surround, HIDs, All-pro rear leafs and UCAs, Eibach coilovers, billys all around, flat black pro comps, 31x10.5x15 BFG KM2s
    your truck is definitely haunted
    you have angered the spirits
  6. Aug 4, 2011 at 4:55 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    bad connection on the battery terminals.
    I had this problem a lot in my 07 taco. I had to keep a wire brush in my truck at all times to clean my bat. connections every now and then
  7. Aug 4, 2011 at 4:58 PM
    Yoytoda
    Roland
    completely stock
    you can test continuity between the battery ground to where the ground points are. the resistance should be less than .5 ohms
  8. Aug 4, 2011 at 4:59 PM
    Hughesc99
    Hughesc99 Well-Known Member
    Derby, KS
    agree...bad ground or bad alternator. i had a car that the alternator went out on...did the exact thing your describing with the jolting and the gauges going crazy.
  9. Aug 4, 2011 at 5:08 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    My ground was slightly loose on my Taco, had my truck truck no start and battery go dead 3 times last weekend. Tightened the ground, no problems since. Still feel like I should get my alternator checked out.
    I'm sure the crap Walmart battery doesn't help neither...
  10. Aug 4, 2011 at 5:10 PM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    :laugh:
  11. Aug 4, 2011 at 6:02 PM
    ThunderBunny7
    Lovettsville, VA.
    hahah nice guys, thanks for the input. i'll check the ground and connections in the morning. if it's the alternator i'm gonna punch a baby.
  12. Aug 4, 2011 at 6:19 PM
    Yoytoda
    Roland
    completely stock
    really really really bad idea
    that can easily fry the rectifier/regulator doing that
  13. Aug 4, 2011 at 6:25 PM
    Cape Codder
    Cape Codder Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
    He's got a Canadian Tacoma, it's probably OK :D
    The OP Doesn't
    CC
  14. Aug 4, 2011 at 6:40 PM
    Yoytoda
    Roland
    completely stock
    Its not just about load
    The battery is more than just a voltage source. its a capacitor that levels voltage spikes and transients to ground. If they are free to move around rather than being leveled off by the battery it can fry any semiconductor in your truck.
    The battery is often the voltage source to the voltage regulator. If you disconnect the battery it could also make the regulator not regulate and it could fry everything. Alternators are capable of producing 100s of volts and without the battery to complete the circuit it could produce electricity freely without regulation.
  15. Aug 4, 2011 at 6:56 PM
    Yoytoda
    Roland
    completely stock
    capacitance is the wrong term but a battery does act as a voltage "conditioner"
    and a ground for transients
  16. Aug 4, 2011 at 7:00 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    put heavy duty battery terminals on there like marine grade with that electric grease stuff and felt pads cured all my corrison and connections problems
  17. Aug 4, 2011 at 7:07 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Our transients have the luxury of at least a dumpster....
  18. Aug 4, 2011 at 7:40 PM
    colder
    colder Well-Known Member
    MN
    2011 Access Cab TRD Sport
    had a jeep where this happened, the battery cable terminals were old, just a little too big for a new battery. the lights would flicker, it idled rough, sometimes i'd try to start and the gauges would just go crazy. i could clamp the positive terminal with a vice grip (squeezing it down for a good connection) and the truck ran normally. i replaced them and it was okay (sleeve didn't work - sizes not quite right). i'd check the connections. Good luck!
  19. Aug 4, 2011 at 7:55 PM
    Yoytoda
    Roland
    completely stock
    Im just saying the voltage regulator "senses" the load and with no load (disconnected battery) it will produce to its max
  20. Aug 4, 2011 at 8:13 PM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    This just happened to mine last week LOL. Went out one morning and it wouldn't start. Finally got it started with a battery tender. Pulled out of the driveway, and my radio/dashlights started flickering. Made it to work, and when I went to leave for home, it wouldn't start again. Got jumped off at work, and made it home. Unhooked the terminals, cleaned them off, and WHAM! started right up.
