Won’t start after stalling manual transmission
Discussion in '3rd Gen. Tacomas (2016-2023)' started by deav, Mar 28, 2019.
  1. Mar 28, 2019 at 10:55 AM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    ding ding ding
    we have a winner
  2. Mar 28, 2019 at 10:57 AM
    Rob Daman
    Rob Daman The Taco Formerly Known as Hard Shell Taco
    Rob
    So Cal
    17 OR 6MT
    a lot
    That clutch pedal sensor to start sure needs to be pushed down a lot. I've noticed that when I'm not paying attention.
    I'd check that battery for sure. The battery warning light is normal when you have the ignition on.
    If it all checks out it could be that sensor.
    doublethebass and wilcam47 like this.
  3. Mar 28, 2019 at 11:00 AM
    bradshawnh
    bradshawnh ...to the rescue!
    Boston, MA
    2017 TRD OR DCSB 6MT, Tech, Inferno
    He said it is cranking so that's not the issue.
  4. Mar 28, 2019 at 11:02 AM
    bradshawnh
    Boston, MA
    That's absolutely what's happening. It adds fuel to try to raise the idle to keep you from stalling...so when it eventually does stall there is excess fuel in the combustion chamber (that's being flooded).
    Please go talk to your local Toyota master tech for details.
    Carbeurated engines are not the only ones that can flood...FFS.
  5. Mar 28, 2019 at 11:04 AM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    OP clearly stated that he can take the key out, and then put it back in and it fires right back up. It's not flooding.
  6. Mar 28, 2019 at 11:09 AM
    thesloppy1
    thesloppy1 Well-Known Member
    2016 quicksand Tacoma trd sport
    Happened to me a few times. Mainly when offroading and trying to go in reverse. That gear is extremely high. Not sure why it takes so long to restart but it is annoying.
    Junkhead likes this.
  7. Mar 28, 2019 at 11:12 AM
    ian rogers
    ian rogers Well-Known Member
    Ian
    Sf Bay Area
    69 fj40, 2019 OR manual
    Locked Sliders Roll cage H41
    I vote for a week battery
  8. Mar 28, 2019 at 11:43 AM
    rzgkane
    rzgkane Well-Known Member
    Huntington Beach, CA
    2019 Tacoma TDR Sport 4WD DCLB - Cement - Tech and Premium
    4Runner Trail wheels and Toyo Open Country ATII tires 265-70-17. Cosmetic stuff like Pro grille and OffRoad black bumper trim, vinyl delete on side, added hood graphic, OEM tube steps.
    I agree. Crank with the throttle wide open and try to clear the flood.
  9. Mar 28, 2019 at 11:49 AM
    rzgkane
    Even fuel injected engines can get loaded up in a stall situation and make a restart difficult. My kid's 2000 Tacoma does it. My 2016 Porsche does it. Holding the throttle down in some vehicles does initiate a "clear flood" function wherein fuel is cut off and only air enters the chamber in an attempt to get the mixture right enough for ignition.
    doublethebass likes this.
  10. Mar 28, 2019 at 11:58 AM
    deav
    deav [OP] Active Member
    2018 DCSB OR Manual
    I haven’t seen that. One time it started after waiting a minute but had an irregular idle for a moment.
  11. Mar 28, 2019 at 12:00 PM
    deav
    2018 DCSB OR Manual
    Thanks. Just seems odd. I’ve had several cars and manual trucks and any time they have stalled they just start back up. Zero issue. Taught my wife to drive my ranger and she stalled a bunch. Always just started again. No issue.
    wilcam47 likes this.
  12. Mar 28, 2019 at 12:01 PM
    deav
    2018 DCSB OR Manual
    Good tip. I’ll try it if it happens again.
    shakerhood likes this.
  13. Mar 28, 2019 at 12:06 PM
    deav
    2018 DCSB OR Manual
    Come on. Obviously. Even someone who never stalls on the street can have a stall on a difficult trail or slow, steep, rocky climb.
    Asking for insight on the behavior. Want my wife to get back in the seat with a MT and not being able to start after a stall will freak her out and make her not want to drive it. Don’t want that. Just want to know how to handle the situation when it arises.
  14. Mar 28, 2019 at 12:07 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Get an AT, solved!
    (Sorry, had to get you MTers back! :boink: )
    Skydvrr, nd4spdbh and tonered like this.
  15. Mar 28, 2019 at 12:08 PM
    #35
    deav
    2018 DCSB OR Manual
    Thanks. It’s at least good to hear it happens to others. It’s just very strange to me. Never seen it on another vehicle.
    NickleCityTaco and wilcam47 like this.
  16. Mar 28, 2019 at 12:09 PM
    #36
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    I've driven a co-workers 3rd gen MT a dozen times now and I will admit that I stalled it the first time I went to take off (cranked right back up though)...what I quickly learned is that these trucks like to be revved when taking off, a low RPM or light throttle take off is not ideal, in my experience.
    CygnusX191 likes this.
  17. Mar 28, 2019 at 12:09 PM
    #37
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    We are a hard bunch.
  18. Mar 28, 2019 at 12:10 PM
    #38
    snowshovel
    snowshovel Active Member
    did you hear anything when you tried to crank the engine after stall? This happened to me when I just got my Taco. Finally I figured out the reason. I put a new floor mat that has no hole to hook the position and it got moved to the bottom of the clutch. When I tried to quickly start the engine after stall, I tended not to push the clutch hard enough. It seems Tacoma's clutch likes to be pushed all the way down into the carpet to have the engine start that is strange. Maybe this is the reason, esp, if you heard nothing when you cranked it.
  19. Mar 28, 2019 at 12:11 PM
    #39
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    There are switches a both ends of the pedal travel. But if I am not mistaken, if the pedal is not completely pushed, the engine won't even crank.
  20. Mar 28, 2019 at 12:13 PM
    #40
    ferntr33
    ferntr33 Well-Known Member
    That’s weird. Wouldn’t think it’s a safety thing. Were you moving? Maybe it sees you are not stopped and Toyota thinks is unsafe to restart a moving vehicle?
