Won’t start after stalling manual transmission
Discussion in '3rd Gen. Tacomas (2016-2023)' started by deav, Mar 28, 2019.
  1. Mar 28, 2019 at 12:14 PM
    #41
    thdrduck
    thdrduck Well-Known Member
    Do you have a 4 banger? I have almost 30k on mine and still kill it once in awhile but it always starts right back up. Touchy gas and clutch peddles.
  2. Mar 28, 2019 at 12:27 PM
    #42
    96carboard
    96carboard Well-Known Member
    You said two things that are entirely contradictory to each other.
    If it won't flood because its FI, why would they take the time (and expense) to write the code to cut the fuel in the event of it becoming flooded?
    Also, FI does not mean that it can't become flooded. Being flooded means that the spark plug gap is essentially soaked with liquid fuel, so the electric current that normally jumps the gap and makes a spark rather just conducts through the liquid and doesn't actually spark.
    In an FI engine, the computer can't really predict if the engine is going to stall, or if you're about to press in the clutch. It therefore continues dumping in fuel while in that last cycle until after it actually registers that the engine has stopped. That overshooting of fuel floods it.
    Spillproof, bradshawnh and rzgkane like this.
  3. Mar 28, 2019 at 12:32 PM
    #43
    96carboard
    It takes time to do that. A few seconds. That's all it takes for excess fuel to run out of harms way.
    Automotive carburetors are a bit challenging when it comes to flooding, because they usually had a little pump in them that would squirt extra fuel when you opened the throttle (this is why you used to pump the gas pedal to get such an engine running). The downside to this is that if you flooded it, then any time you would touch the throttle before it restarted (including that time when you open it wide to CLEAR the flooding), it would re-flood.
  4. Mar 28, 2019 at 12:33 PM
    #44
    96carboard
    ^^^ If you don't know what you're doing and don't care if you destroy somebody else's clutch.
  5. Mar 28, 2019 at 12:36 PM
    #45
    su.b.rat
    su.b.rat broken truck
    yes. but that just allows it to crank, and it's already cranking he says.
    2 1/2 yrs and 45k and i never had this happen, although one time i stalled and it turned over quite a bit longer before igniting than normal, but it started, just not as quickly as normal. sorry no other input, good luck and watching.
    Junkhead likes this.
  6. Mar 28, 2019 at 12:38 PM
    #46
    96carboard
    I think that's what he's actually talking about.
  7. Mar 28, 2019 at 12:39 PM
    #47
    su.b.rat
    yes i see that, and i could have been more clear that i wasn't cranking as long as he was saying in the OP.
  8. Mar 28, 2019 at 12:41 PM
    #48
    96carboard
    He didn't actually say how long he cranked it for before giving up. I bet that you cranked it for longer.
  9. Mar 28, 2019 at 12:44 PM
    #49
    su.b.rat
    "It just cranks and cranks and doesn’t fire." -- OP
    nothing like that ever happened to me using those terms. as long as we're being literal.
  10. Mar 28, 2019 at 12:45 PM
    #50
    96carboard
    "Cranks and cranks". So we're talking 2 revolutions? About 3 seconds?
  11. Mar 28, 2019 at 12:46 PM
    #51
    su.b.rat
    guy! it's almost Friday grab a beer or a dozen.
    Shellshock, CygnusX191 and wilcam47 like this.
  12. Mar 28, 2019 at 12:49 PM
    #52
    96carboard
    I'm not trying to be argumentative here. I'm just trying to point out that OP did NOT indicate how long he cranked it for. "Cranks and cranks" is NOT a unit of time. It can take 20-ish seconds of cranking to get going again, which probably feels like a minute and 20 seconds when you're actually doing it.
    Isn't the typical "it won't start" instruction something like "stop cranking at 10 seconds and let the starter cool down for 10 minutes before trying again"?
  13. Mar 28, 2019 at 12:51 PM
    #53
    su.b.rat
    i appreciate that but i'm ok without a specific unit of time and this is becoming silly.
  14. Mar 28, 2019 at 12:51 PM
    #54
    fiftyxp
    fiftyxp Well-Known Member
    2017 trd offroad 4x4
    cranks and cranks makes me think its not starting
  15. Mar 28, 2019 at 12:52 PM
    #55
    Ez2Tan
    Ez2Tan Well-Known Member
    2017 Quicksand Tacoma OR
    I've had this happen to me a 2-3 times when I lazily stall the truck. It wont restart immediately and I usually just turn the key to the full off position and then try again. That usually does the trick for me.
  16. Mar 28, 2019 at 12:52 PM
    #56
    96carboard
    Yeah, for however long he's willing to hold the key in the start position, which he didn't indicate.
  17. Mar 28, 2019 at 12:54 PM
    #57
    fiftyxp
    I guess its sounds like he cranked it for enough time to know it wasnt going to start...
    You arent gonna keep cranking it for a minute? most times a vehicle hasnt started you crank it a few seconds, try again, try again, try again. well damn i guess it isnt starting....
  18. Mar 28, 2019 at 12:56 PM
    #58
    96carboard
    Why is everyone here having such a hard time getting the point?
    OP DID NOT SAY HOW LONG HE CRANKED IT FOR.
  19. Mar 28, 2019 at 12:57 PM
    #59
    fiftyxp
    but who cares? he said it didnt start...
  20. Mar 28, 2019 at 12:57 PM
    #60
    JimmyRigged88
    JimmyRigged88 Well-Known Member
    WA
    2020 JLUR
    I've had this happen once. I hopped in the truck, started her up and then realized I forgot my wallet. I hopped out to go grab it not realizing she was in gear with the ebrake on and killed her. She would not restart, cranked and cranked but the engine didn't even try to start. Right as panic was setting in I pulled the key out and tried again and it started like normal.
    It's not the battery, it was cranking great. It wasn't flooded, I tried flooring the throttle and it didn't help. I've stalled it other times and was able to start right back up. I assumed it was some safety feature maybe because it was during warm up but who knows.
