Won’t start after stalling manual transmission
Discussion in '3rd Gen. Tacomas (2016-2023)' started by deav, Mar 28, 2019.
  1. Dec 5, 2021 at 2:33 PM
    #101
    BigCarbonFootprint
    BigCarbonFootprint Well-Known Member
    Andy
    2019 TRD Off Road
    King Racing 3” lift
    ^^^ THIS IS THE CORRECT ANSWER ^^^
    It is a designed and programmed safety feature. If the ECU or BCM (body control module) detects either an engine stall or airbag deployment, the fuel pump is automatically switched off. This is to prevent potential fuel leakage - and therefore a fire - in the event of a crash.
    The proper way to reset it is simply to turn the ignition to Lock / Off and then restart it. You cannot directly re-crank it.
    FYI - for those opining it is “flooding” in the time it takes to stall, Long Term and Short Term fuel trims do NOT work that way. Fuel trims are controlled and ONLY controlled by the O2 sensors in the exhaust.
    Furthermore, the design purpose of “clear flood mode” - cranking with the gas pedal fully depressed - is so that certain diagnostic functions can be performed (compression test, hooking up an oscilloscope to get a crank/cam- shaft correlation waveform without the engine running such as when a sensor is thought to be defective)
    These trucks are most definitely NOT flooding out when inadvertently stalled.
  2. Dec 5, 2021 at 3:19 PM
    #102
    05Taco18Taco
    05Taco18Taco New Member
    Kristen
    Colorado
    2018 Tacoma TRD Sport 6 spd manual
    Thank you for the info. Just interesting that this is the only MT vehicle that I have ever owned that does this. I also have a 6 speed 2015 Mustang that doesn't do this if I stall out. I know that's like comparing apples to oranges but I just find it weird. Oh well!
  3. Dec 5, 2021 at 3:25 PM
    #103
    BigCarbonFootprint
    Andy
    2019 TRD Off Road
    King Racing 3” lift
    I am happy to help. Each manufacturer is slightly different.
    I have owned several manual transmission Ford Mustangs. In contrast to Toyota, Ford uses an “Inertia Switch” to detect impact crashes and disable the fuel pump. It is literally a simple accelerometer that detects instantaneous changes in speed - like going from 40 MPH to zero in a crash.
    This is why drivers experience different operating characteristics. Stalling an MT Mustang will never trip the Inertia Switch.
    05Taco18Taco likes this.
  4. Dec 5, 2021 at 3:50 PM
    #104
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    I stalled a customers tacoma once. It started back up thank god. It was a 2017 5mt SR too
  5. Dec 28, 2022 at 9:27 AM
    #105
    Alexbar10
    Alexbar10 Well-Known Member
    Alex
    2020 black tacoma TRD PRO MT
    I figured I pitch in. My 2020 trd pro does this. Sometimes you're lazy when getting over a hill or trying to creep on a steep surface or something and you stall. It's very annoying that you can't just turn it back on sometimes. I can crank it for like 5 seconds and nothing. Eventually it turns on and the engine runs really weird. Wish this wasn't an issue, can be very annoying.
    Also I don't care how good you are at driving stick, everyone still stalls every now and then. Either that or you're burning your clutch trying to rev it out.
    doublethebass, Junkhead and wilcam47 like this.
