Wonder if 1st Gen Tundra Struts will work...
Discussion in '5 Lug' started by ISUGrad05, Apr 26, 2012.
  1. Apr 26, 2012 at 4:44 PM
    ISUGrad05
    ISUGrad05 [OP] Public Servant Enemy #1
    Wichita, KS
    2012 4x4 5.7 Tundra DoubleCab
    I was looking around Monroes website and noticed that the 1st gen Tundra front struts seems very similar to 2nd gen 5 lug Tacos.
    Tundra struts:
    Body Type: SS2, Body Length: 13.120", Compressed Length: 13.620", Extended Length: 17.930", Travel Length: 4.310",
    5 lug Taco struts:
    Body Type: SS2, Body Length: 11.496", Compressed Length: 12.519", Extended Length: 16.437", Travel Length: 3.918",
    The advantage would be about 1 - 1.5 inch lift. The extra bracket on the Taco strut is to mount the brake line, which could be easily relocated.
  2. Apr 26, 2012 at 5:42 PM
    ISUGrad05
    Wichita, KS
    Here are the stats for Gen 1 Tundra 5100s
    Part Number: 24-188265
    Setting: 5100 Series (Ride Height Adjustable)
    Position: Front
    Descriptor: Front Lifted Height: 0-2"
    *Collapsed Length (IN): 13.23
    *Extended Length (IN): 18.68
    *Collapsed Length (MM): 336
    *Extended Length (MM): 474.5
    Old Part Number: F4-BE5-6929-H1
  3. Apr 26, 2012 at 6:13 PM
    ISUGrad05
    Wichita, KS
    I took some measurements of my truck and the 5 lug springs are tapered where as the tundra springs are not. Unsure of the the length of tundra springs, but the 5 lugs are about 8". It could be an issue with tundra springs hitting the upper control arm on our trucks. Anyone know the measurements of the Tundra springs? Perhaps the Tundra 5100 bilstiens and springs would work with Total Chaos UCAs. That would be a significant cost savings over Sway A Way coilovers.
  4. Apr 26, 2012 at 6:15 PM
    jhu616
    jhu616 Well-Known Member
    Tripp
    GA
    08 4x4 6-Speed TRD Off-Road
    Magnaflow Exhaust, Bilstein 5100s, Eibach Coils, Toytec AAL, Black Baja Wheels, Ipod Hookup, Diff breather
    :popcorn: Don't mind me....just curious what you find out!
  5. Apr 26, 2012 at 6:25 PM
    ISUGrad05
    Wichita, KS
    Yeah, the 1st gen 6 lug Taco and 1st gen Tundra struts are only about half inch different. 2nd gen 6 lugs are quite a bit longer.
  6. Apr 26, 2012 at 7:53 PM
    Joels98taco
    Joels98taco Well-Known Member
    joel
    chino hills
    98 5 lug tacoma
    fabtech 3" spindles, icon aal, 10" bilstein 7100 rear shocks, daystar coil spacers, AFE Pro Dry-s drop in filter, sony head unit, 2 12" pioneer subs, pioneer 6.5s all around, custom 1.25 lift shackles, custom lower ball joint brackets fabbed by me
    i dont think it would work too well since the top plates are fairly different
  7. Apr 26, 2012 at 9:40 PM
    ISUGrad05
    Wichita, KS
    The 2nd gen 6 lug Taco uses a special "top hat" style mount, but the 5 lug and 1st gen Tundra both have a flat top mount that looks the same.
  8. Apr 26, 2012 at 9:43 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    unless the top plates have the same pattern it most likely wont work
  9. Apr 26, 2012 at 9:44 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Don't do it, wont work without a shit load of work, not worth it, talk to RyanJboutin
    spring hitting UCA (which is waaay narrower ) Top plate totally diff.
    Fuck I'm getting sick just thinking about it
  10. Apr 26, 2012 at 9:58 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    thanks doug i needed the backup :rolleyes:
  11. Apr 26, 2012 at 10:00 PM
    ISUGrad05
    Wichita, KS
    Yeah, after looking at the stock uca i can see where it would hit, but I'm curious if it would clear the Total Chaos uca seeing how they clear those beefy Sway A Way 2.5 coilovers.
  12. Apr 26, 2012 at 10:04 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    ryan was running custom uniball ucas..
  13. Oct 26, 2012 at 1:39 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    What's the advantage of using Tundra 5100's on a 1st Gen? Stiffer? If the top plate is different, I assume Taco coils and top plates are used? Approximate lift of the settings?
