Wonder What Replacement Alternator to Get?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Reece08, Jan 15, 2025.
  1. Jan 20, 2025 at 9:33 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    When you took it off reverse, did idle go to normal?
    You may be ok. Drive it about 20 miles and see if the idle has returned to normal. Some Toyotas act funny that way when disconnecting the battery. It resets some defaults. It would happen to my daughter’s 07 Corolla.
  2. Jan 20, 2025 at 3:24 PM
    Reece08
    Reece08 [OP] Member
    Reece
    2008 Tacoma 4.0 Prerunner
    You were right Dm, didn’t end up needing the battery either but I was overdue for a new one anyway so I kept it. I cleaned up my throttle body and MAF which were both super dirty and now I have a nice idle. New alternator is doing good too so I think everything is fixed now. It definitely must have reset my idle when I disconnected the battery, and it was idling rough because my MAF was so dirty and it hadn’t re learned how to accommodate that yet lol.
    Chuy likes this.
  3. Jan 28, 2025 at 1:57 PM
    timelesstaco
    timelesstaco Well-Known Member
    Dan
    2013 toyota tacoma. Regular cab manual. 1985 toyota 4runner s45
    3" toytec big boss suspension lift. toytec 1" bodylift. 33" nitto trail grapplers. 16 inch raceline raptors. sterling equipment double single roll bar.
    PowerBastards 220 amp high output and wiring kit!
    https://www.powerbastards.com/proddetail.asp?prod=11354-220-HD2-1
