Wondering about maintenance schedule/oil change interval...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JimLS, May 8, 2024.
  1. May 8, 2024 at 11:34 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    I am sympathetic to the crowd that believes a new-car break-in period generates high levels of wear, some of which ends up in the oil. I remember when the break-in period in certain new cars included replacing the oil at 500 miles. I saw a utuber (Motor Oil Geek) who did an oil analysis on the break-in oil on his daughters 2024 Toyota, a Corolla I believe, to show the higher levels of wear metals present in the oil. His sample was, I’m pretty sure, under 500 miles.
  2. May 8, 2024 at 11:39 PM
    Chuy
    Lakeside, CA
    Silver Taco
  3. May 9, 2024 at 12:33 AM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    seems to me if it was a problem then toyota would recommend doing it
    Pwakchop, BillF1564 and SmoothTRD like this.
  4. May 9, 2024 at 12:48 AM
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    Like every other thread on this topic, change it every 3K and drive it til the frame rusts away, or change it every 10K and drive it til the frame rusts away. Your choice.
  5. May 9, 2024 at 3:33 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    The thing is though everybody's analyst will be different depending on their individual driving style. What might be OK in one persons rig, is not the same as another. This is why 5K usually gets suggested a lot as it's usually a safe range. 3.5's can be rough on oil under the right conditions.
    NlOffRoad11 likes this.
  6. May 9, 2024 at 10:25 AM
    Chuy
    Lakeside, CA
    Silver Taco
    To me, it falls under preventive maintenance.
    NlOffRoad11 and JoshC like this.
  7. May 9, 2024 at 11:08 AM
    SmoothTRD
    SmoothTRD Well-Known Member
    If you plan on keeping your truck for more than 800k miles than I might recommend changing every 7500k miles. Otherwise 10k will do your truck just fine.
    Pwakchop likes this.
  8. May 9, 2024 at 11:31 AM
    NlOffRoad11
    NlOffRoad11 Well-Known Member
    Tyler
    2021 Cement TRDOR
    Same thing happened to me they would not change my oil ahead of the 10k interval
  9. May 9, 2024 at 11:33 AM
    MGMDesertTaco
    Say what you want, but I change it every 2500-3k. OEM filter, Valvoline full synthetic 0w-20. Noticeable improvement after every oil change.
    STEELeR43 likes this.
  10. May 9, 2024 at 11:42 AM
    SmoothTRD
  11. May 9, 2024 at 11:44 AM
    BillF1564
    BillF1564 Well-Known Member
    2021 Tacoma SR
    What sort of noticeable improvement?
    golfindia and Pwakchop like this.
  12. May 9, 2024 at 11:45 AM
    MGMDesertTaco
    Engine runs smoother, quieter and seems to rev up faster when accelerating.
  13. May 9, 2024 at 11:55 AM
    300e
    300e Well-Known Member
    Going through this now with my '23 Sport with 4200 miles. I bought the truck new in September, and the third dealer I called agreed to do change the oil now along with the tire rotation via Toyota Care. YMMV
  14. May 9, 2024 at 12:12 PM
    SmoothTRD
    Really..... hmmmm lol
    BillF1564 likes this.
  15. May 9, 2024 at 2:18 PM
    #35
    JoshC
    JoshC Well-Known Member
    2023 TRD Off-Road M/T Celestial Silver
    1999 SC 2.4L 2WD 5m/t (RIP)
    For what it's worth, I use full synthetic and change mine every 3k to 4k or 4 months, whichever comes first.
    I also got the rear axle recall, and the service guy was flustered I was at 12k miles and hadn't used any of my free oil changes. I told him I change my own oil and have done it 3 or 4 times already. I really had to talk him down from wanting to change my oil. I've never had bad experience at a Toyota dealer with oil changes (aside from slightly over filling), but I have had plenty problems with Honda dealers changing my Honda's oil like over tightened oil filters and drain plugs. Like I said, I change my own oil now that way I can keep a pulse on my truck.
    What? Am I rambling again? Oh hell, I'll shut up then.
  16. May 9, 2024 at 2:27 PM
    #36
    MGMDesertTaco
    If you want my used engine oil I can send it your way. :burp:
    SmoothTRD[QUOTED] likes this.
  17. May 9, 2024 at 2:40 PM
    #37
    BillF1564
    2021 Tacoma SR
    From an Oil change? I never heard of that. Is that even possible?
    You're fooling around? Or are you serious? I guess I should give up the Toyota Oil and buy Valvoline :)
    SmoothTRD and Pwakchop like this.
  18. May 9, 2024 at 2:50 PM
    #38
    MGMDesertTaco
    Serious, I don't baby my truck. I drive it hard and the AZ heat is rough on vehicles. Some vehicles are more noticeable than others after maintenance is done.
  19. May 9, 2024 at 3:11 PM
    #39
    sdsurfer
    sdsurfer @ODNAREM life...
    Dirk
    San Diego
    DCSB TRD 4X4
    5100s/OME 888s. Dakar leaf pack. Total Chaos UCAs. DeMello Sliders. BAMF Recessed Grille. Prinsu Cabrack and Toprack.
    So many "experts" on here that "guarantee" you're fine at 10k. Do whatever you are comfortable with and enjoy your day. I tend to lean toward the more conservative side so I do it every 5k.
  20. May 9, 2024 at 4:01 PM
    #40
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    5000 when the light comes on. At that point grease, inspect every thing, tire pressure, washer fluid, brake fluid, gear box, diff, belts etc. That's it for another 5K close the hood.
    BigCarbonFootprint likes this.
