wondering about TRD
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KaitlinTacoma84, Nov 16, 2017.
  1. Nov 17, 2017 at 4:57 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    SRQ_TACO16 likes this.
  2. Nov 17, 2017 at 6:20 AM
    Chase8059
    Chase8059 Kinda Well-Known
    Chase
    ESVA
    2015 DCSB TRD Sport | Super White : 2008 Lexus IS 350
    OME 887, JBA UCAs, 1.5 AAL, Fox 2.0 RR w CD adj., SCS SR8s Gunmetal, Falken AT3/W 265/70r17
    How did the 5100s hurt you? If you pair them with a good coil they are a very good lift option. If you are you using them to "preload" your factory coils I can sort of see where your coming from. The ride will be a bit stiff up front.
  3. Nov 17, 2017 at 7:06 AM
    Ralmoho
    Ralmoho Well-Known Member
    Ralph
    Florence Ky
    2010 MGM Tacoma SR5 Base
    Ivan Stewarts
    Steve,thanks for the clear explanation...to a newer member it's helpful.TW has a language of its own and it takes awhile to navigate some of the threads.Sometimes it's like listening to a couple of Railroad guys conversing... I love trains...
  4. Nov 17, 2017 at 7:16 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    so many options depending on budget. hit up marie over @HeadStrong Off-Road she can school ya a bit,
    Front options
    spacers, no, dont do that
    5100's with stock coils, set on a setting above zero. will give you a little lift but preload your coils a bit, may hinder ride quality, although many do it and like it
    5100's with new lift coils, many heights offered. OME 884 2", 885 2.5" , 887 3". if you get into the ~2.5" lift, you will likely want new upper control arms to get your alignment back, keep it at 2" or so, you should be fine with OEM UCAs.
    Rear
    Single add a leaf, not bad, I did this for a while, gets you about 2" I think. May need new rear shocks as well
    progressive AAL, its a 3 leaf AAL pack, better ride than single AAL
    New leaf pack, like OME Dakar of Allpro pack. Great ride, more load carrying without squat
    HeadStrong Off-Road likes this.
  5. Nov 17, 2017 at 1:35 PM
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    Thank you so much @Sub_Par :broccoli::dancingbacon::bananadance::taco:
  6. Nov 17, 2017 at 1:36 PM
    HeadStrong Off-Road
    You too @JimboAnz !!! :D:D:D
    JimboAnz[QUOTED] likes this.
  7. Nov 18, 2017 at 12:00 AM
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    I did use the 5100's with oem coils. But, raising the coil mounts to get lift... in any situation would cause preload, right? Seriously asking.
    I ended uo going with longer struts, longer springs that are wider in diameter, thicker metal, and 275 over, with more coils.
  8. Nov 18, 2017 at 5:33 AM
    Pigpen
    Dan
    Northwest Montana
    I went from 5100s with stock coils set at the 1.75" setting to 5100s with 885 coils. The 885s yielded the same lift with a softer ride. In retrospect, it wasn't a justifiable improvement for the money. That is , of course, for MY uses.
  9. Nov 18, 2017 at 6:49 AM
    Chase8059
    Chase
    ESVA
    When you raise the coil seat on the 5100s to a setting other than 0, you are preloading the coil.
  10. Nov 18, 2017 at 7:04 AM
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    new 5100's on all 4 corners here.......
    $200 labor install on fronts......set on 3rd ring for approx 2" level lift.....
    looks good/rides great......all I wanted !
