wondering what the scan guage ign is reading in my 3rz
Discussion in '1st Gen. Tacomas (1995-2004)' started by Stout890, Dec 21, 2011.
  1. Dec 21, 2011 at 8:16 PM
    Stout890
    Stout890 [OP] Well-Known Member
    Palmdale ca
    99 prerunner sr5
    10" sub, OME881 on Bilstein's, 3" all-pro leaf springs with billies in the back, JBA UCA's, bed cover with custom LED lighting, k&n intake and DT headers, OEM E-locker in the rear. 32" BFG KO2 on steel D window wheels, suicide knob. rebuilt 3RZ w/ stage 1 cam and balance shaft delete . big 3 mod, all new suspension and body mount bushings. cat back magnaflow exhaust.
    so i gt a scan gauge for an early Christmas gift and iv been loving it.
    but i was scanning through the gauges and was noticing my IGN gauge was reading about 7-8 while in park and than went up to 20+ while driving..
    what exactly is that reading? i know my manual says its the ignition timing but i didn't think the 3rz had the variable timing advance so why the fluctuation?
  2. Dec 21, 2011 at 8:21 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    All engines change timing, used to be mechanical and vacuum, now the computer does it.
  3. Dec 21, 2011 at 8:31 PM
    Stout890
    Palmdale ca
    99 prerunner sr5
    so than whats so special about the vvti?
    or am i getting valve timing and ignition timing confused?
  4. Dec 22, 2011 at 5:35 AM
    worthywads
  5. Dec 22, 2011 at 5:41 AM
    98tacoma27
    Ben
    Not Beech Creek
    x2
    VVTi changes the cam shafts positions physically, meaning it changes when the valves open/close in relation to crank shaft rotation. Variable Ignition Timing changes when the spark is sent to the plug.
  6. Dec 28, 2011 at 7:05 AM
    Stout890
    Palmdale ca
    99 prerunner sr5
    Ok that's cool I never knew ignition timing advanced. I am an aircraft mechanic and have never heard of that, although I haven't worked on an engine since a&p school and those were simple piston powered engines with stationary timing.
