wondering why i get 13 mpg?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by stefro92, Feb 8, 2012.
  1. Feb 8, 2012 at 9:19 AM
    #41
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    Geeze, I got 18.4 mpg last tank of gas and thats with a 3" lift and 33" MTs, but ive been steady in the 16.5 to 17.5 mpg range.
  2. Feb 8, 2012 at 9:26 AM
    #42
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    My (2010 DC AUTO V-6 4WD 5' bed) truck has 265/75-16 tires, so now the speedometer is correct vs. the smaller /70 tires it came with that had it read too fast. I 'lost' about 1 mpg with the 1" taller tires in my MPG checks.
    NOW: If City only: 14.5-15.5 mpg now. Around town: pretty close to 16 mpg. 50/50 hwy and town stop and goes: closer to 17 mpg. Pure hwy. driving: 18-19 mpg.
    Air pressure in tires on the high side makes a big difference I noticed. My Hankook ATMs (a 42 psi max tire) do well at 38 psi on my truck.
    No change after I added a bottle of Techron, no change after new spark plugs installed at 30,000 miles either.
    I do see better mileage when I put a new air filter in. So, after a lot of off roading, replace it!
    I also HATE that the eco-nazis make us dilute good gasoline with 10%ethynol. In Baja, my mileage is always best using PEMEX (Mexican) gasoline (no eco crap in it)!
    JOIN FUELLY.COM and have your mileage post automatically here (see mine below)...
  3. Feb 8, 2012 at 10:02 AM
    #43
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    If I am not mistaken, the standard tire sizes for 6-lug tacos are:
    245/75/16 (steelies)
    265/70/16 (TRD offroad)
    265/65/17 (TRD sport)
  4. Feb 8, 2012 at 10:07 AM
    #44
    David K
    That is correct... I have the OFF ROAD which came with BFG Rugged Trails 265/70-16. I replaced those crappy tires at 20,000 miles with Hankook Dynapro ATMs 265/75-16... as I said above (/70 to /75)
  5. Feb 8, 2012 at 10:34 AM
    #45
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    But that doesn't correct your speedo, you are now going faster than you think you are. Standard tire sizes are all around 660 revs per mile, you are now at about 637. You are now going 3.5% faster than your speedo says.
    But, that means you are getting 3.5% better actual mileage than your calculations might say.:)
  6. Feb 8, 2012 at 10:50 AM
    #46
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    IMO what type of tires you are running and at what PSI is like 80%. Next, would be a good quality shock absorber.
    When it's time, I'll probably install stock sized BF GOODRICH COMMERCIAL T/A Radials (all I can say is they are SUPERB) and test the PSI up to 50 PSI!
    images_a756745ed1d5613b605d972d838d68fed2a388b5.jpgimages_f0ca3d6d5332d18c074d302a46247e1c7a122d46.jpg
  7. Feb 8, 2012 at 11:02 AM
    #47
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Or try these![​IMG]SUPER SWAMPERS!
  8. Feb 8, 2012 at 11:07 AM
    #48
    pa blaster
    pa blaster Well-Known Member
    Scott
    central pa
    2024 GMC Canyon AT4X AEV
    i have same as you 33's 3'' susp. lift =13mpg .......... on the 21st it' will be 6'' susp 35x12.50x17 pro-comp m/ts 4.56gears trd cai & catback what do u think it will be then?????
  9. Feb 8, 2012 at 11:31 AM
    #49
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    3" suspension, 33" Nitto all terrains, and my last tank was 358 miles with about 80% highway cruising around 80.. figured it out to be around 18.9 MPG..
    This current tank, im at 342 miles and the low fuel light isnt even close to coming on.. gonna be my best tank yet. miles are split almost 50/50 city/highway.. not sure how or why this tank is so good.. lol but lovin it.
  10. Feb 8, 2012 at 11:45 AM
    #50
    BenWA
    BenWA Well-Known Member
    Boston burbs
    '06 Double Cab TRD Off Road 4X4
    ^^ This. OP, you said you have 60K, well that's a pretty big service interval where all of the things Stubbs mentioned above should get a good cleaning. Carbon and other crap builds up in those parts and tricks the computer into wasting fuel.
    Having said that, I used to get around 18.5 mpg when my truck was in the first couple years of its life. My average nowadays is down around 15.5 mpg. :(
  11. Feb 8, 2012 at 11:57 AM
    #51
    David K
    I used a GPS to see the difference.
    The truck's speedometer gives a number based on the rolling tires. A GPS gives a number based on your actual speed.
    The truck, with stock 265/70-16 tires was doing a true 65 mph while the speedometer indicated it was doing 68 mph. Toyota knows this, as do most here on TW.
    With a 1" taller tire (265/75-16) My speedometer and GPS are reading the SAME mph!
    Now, not as scientific, but my observations have been the odometer is also slowed down to a more correct reading. Before the new tires I always got 16 point something miles per gallon (around town)... now it is 15 point something (around town). I don't know how the speedometer and odometer could not be related... I mean one is measuring time to cover a distance and the other measures just the distance.
  12. Feb 8, 2012 at 12:01 PM
    #52
    ruggedT
    ruggedT The Sticker Guy
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    I average 16. Its all about driving habits, weight kept in the vehicle, tire pressure. Intakes/exhaust doesn't necessarily increase anything. I tested less mpg w/ a k&n cold air.
    I used to calculate with a gps, now I do so with a calibrated Ultragauge. Speedo is way off so its no good for #'s
  13. Feb 8, 2012 at 12:02 PM
    #53
    rondog
    rondog Well-Known Member
    Ronnie
    Escondido/San Diego
    im getting 13 in the city with a heavy foot and bigger tires than stock
  14. Feb 8, 2012 at 12:47 PM
    #54
    WV150
    WV150 Well-Known Member
    South Carolina
    Trifecta Tonneau Cover
    Blaming it on the West Virginia hills is a correct statement.I lived in West Virginia until a couple years ago and now live in upstate South Carolina.I can get 3 to 4 more MPGs in South Carolina than in West Virginia.I also have a Prius and the MPGs drop around 8 to 10 MPGs in West Virginia.The hills and the colder weather makes a big difference.I also have to question if there is different winter gas mixtures for different parts of the country.
  15. Feb 8, 2012 at 1:17 PM
    #55
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    According to puregas.org a Cenex station in Wichita has 87 that is ethanol free.
  16. Feb 8, 2012 at 2:41 PM
    #56
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    how are your math skills?
  17. Feb 8, 2012 at 2:48 PM
    #57
    KalamaKid
    KalamaKid Well-Known Member
    Oregon
    same shit as everyone else
    Well how far do you drive each trip will make a huge difference. I work 2.5 miles away all 25 MPH driving. I get about 8MPG if I never make a longer trip on that tank. If I drive on the hwy it'll jump right up to the 16-17 range. That's with 33's winch armor etc. light foot or not if you only make short trips your just guzzling fuel.
  18. Feb 8, 2012 at 5:23 PM
    #58
    MonkeyChief
    MonkeyChief Detachable member
    ACORLR
    WTB Topper Lunar Rock 6’ Leer
    all my driving is around town with very little on the freeway currently. I am getting some crap for mileage for sure but am not surprised, am actually more surprised by others numbers in the 18+...
  19. Feb 9, 2012 at 5:27 PM
    #59
    Peter559
    Peter559 Well-Known Member
    good to know I'm not alone but sucks for us... cant believe some of you guys get 18+ mpg... must be doing lots of highway to get that kind of number... i do both highway and city, about 40/60...
  20. Feb 21, 2012 at 11:36 AM
    #60
    David K
    It is pretty amazing to see the difference that all highway (or almost all) driving does to city/ town driving (with stop and goes) on the Tacoma's mileage.
    The past two weeks I have been working 20 miles from home, mostly freeway and my typical daily around town mileage of 15-16 went to 16.8 the first tank and 17.2 the next... at this moment, based on the gas gauge I am about 18+ mpg on this third tank. That helps with 'cheap' gas here now over $4/ gallon!
