Wonky Ride Height Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gozer the Gozerian, Jun 19, 2009.
  1. Jun 19, 2009 at 12:55 PM
    Gozer the Gozerian
    Gozer the Gozerian [OP] Member
    Portland, OR
    2010 V6 Access Cab 4x4 Off-Road (Mag Grey)
    Hey, I'm still pretty noob-ish (to trucks in general), so forgive me if this is common sense knowledge. Also, I did try searching, but didn't find an answer. That said, if you'd like to answer my question by linking me to another thread, please do.
    Here's my issue: I'm saving for my lift/tire upgrade and wanted to check my ride height so get a sense of how much lift I'll need front vs. rear. Parked on a flat surface and measured from the ground to the bottom of the fender, aligned with the center of the wheel hub. I found that my front right and left were pretty close to each other, though not exact (at about 34 and 3/4 inches). However, my rear right and left were an inch different (left at 37", right at 38"). I should mention that it's an access cab, non-TRD, with the TSB springs added, and a canopy on. I reparked and remeasured a couple of times but always the same result. Why would this happen? Knowing that the truck is not symmetrically built, and the fuel tank is on the left, made me think that might be the reason. But then again, I only had a quarter tank...
    Now here's the strange part: I got home and parked in my sloped driveway (nose uphill) and, out of curiosity, measured again. This time the left was an inch higher than the right. Opposite of before. Any ideas on what's going on here???
    Thanks.
  2. Jun 19, 2009 at 1:25 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Tacoma Lean maybe? I would do a search on it. Good luck!
  3. Jun 19, 2009 at 1:26 PM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    that is the first time "wonky" has been used on the site :laugh:
  4. Jun 19, 2009 at 1:27 PM
    Gozer the Gozerian
    Portland, OR
    Thanks. I thought the infamous lean referred to the factory rake, but maybe I'm mixed up on that. I can understand a left lean with a full tank, but 1/4 tank? I'll have to measure again on empty and at full for comparison.
    Still really unsure why the difference flipped when I parked on a slope...
  5. Jun 19, 2009 at 2:58 PM
    TicTacOma
    TicTacOma UnderWater Monopoly Champion
    Anastatia Beaverhausen
    Columbia,SC
    I'm Thinking...Oh Yeah...An FJ
    It's all in my head at the moment...
    Wonky? Ain't that the guy with the "EverLastingGobStopper"?
  6. Jun 19, 2009 at 3:07 PM
    Gozer the Gozerian
    Portland, OR
    No no no. You're thinking of the leader of a German midget clown gang with too much carotene.
