wont go into 4 wheel lo,lights flashing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tr1957, Nov 28, 2023.
  1. Nov 28, 2023 at 2:41 PM
    tr1957
    tr1957 [OP] Well-Known Member
    Alabama
    2011 regular cab 4x4
    I tried going into 4 wheel lo , didn't happen, dash lights flashing.
    It will go into 4 wheel high and out of 4 wheel high .
    Once I go into 4 wheel low I have to turn off the engine and back on to get it to go back to 4 wheel high. I'm guessing the problem is the transfer case actuator.
    Any ideas?
    Thanks
    SethM likes this.
  2. Nov 28, 2023 at 3:19 PM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
  3. Nov 28, 2023 at 6:13 PM
    SethM
    SethM Well-Known Member
    Seth
    Los Angeles ca
    2011 mgm tacoma trd sport 4x4
    3" toytec lift 285/75/17" tires
    Yes most likely front differential actuator.
  4. Nov 28, 2023 at 7:06 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Check your limit switch voltages as outlined in the thread @GilbertOz posted above and post your results so we can see which actuator or wiring needs to be checked further, anything else is just a guess.
    TnShooter likes this.
  5. Nov 28, 2023 at 7:16 PM
    tr1957
    Alabama
    Thanks for the info ,I will check voltages and reply
  6. Nov 28, 2023 at 7:35 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    When it's stuck, I seem to get mine in 4Lo by turning the steering wheel a little to the left or right while in neutral. It might line everything up so gears aren't pinching each other. I also had all my driveline fluids replaced and it works a ton better after that. I also test 4Lo and rear locker it about once a month in the school parking lot while driving straight. I think it keeps it working.
  7. Nov 28, 2023 at 7:48 PM
    SethM
    Seth
    Los Angeles ca
    Also check your 2 breather hoses front and rear actuators.
    winkel likes this.
  8. Nov 28, 2023 at 7:59 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Turning the wheels left and right wont help. Neither will checking the breathers.
    If turning the wheels helps. Its either a coincidence or you have a different problem.
    4 Low is all done inside the transfer case.
    As posted, check the voltages in the link above.
    SethM likes this.
  9. Nov 29, 2023 at 7:45 AM
    tr1957
    Alabama
    well after working the controls and driving everything is working again.
    The truck has been setting with minimal driving for the last few years so it may have just needed some exercise to get it going again.
    Thanks everyone
    Dm93, TXpro4X4 and gkomo like this.
  10. Nov 29, 2023 at 8:15 AM
    SethM
    Seth
    Los Angeles ca
    Most likely has moisture or rust on electrical connections
  11. Nov 29, 2023 at 8:25 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Still wouldn't be a bad idea to check the vent hoses on the actuators.
    winkel likes this.
  12. Nov 29, 2023 at 4:10 PM
    tr1957
    Alabama
    will do ,thanks
