Wont go into closed loop
Discussion in '1st Gen. Tacomas (1995-2004)' started by JMaberry, Jul 7, 2013.
  1. Jul 7, 2013 at 5:06 PM
    JMaberry
    JMaberry [OP] Well-Known Member
    Jack
    Salt Lake City, Utah
    01 3.4L TRD SR5 Extended Cab
    Spectre Intake, custom exhuast, ultragauge, bedlined bumpers and grill, ARE shell, jvc headunit, bottle opener in bed, satoshi, hella 500ffs behind grill
    According to my ultragauge, my truck always stays in open loop and never reaches closed loop. However, other than the indicator on the display, there don't seem to be any other effects. I am averaging 20 mpg and as far as I can tell there is no lack of power and the check engine light is not on. Any idea what could be keeping it from getting into closed loop? or if it doesn't seem to be having any negative effects, should I not worry about it?
  2. Jul 7, 2013 at 5:11 PM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    They are suppose to run in a closed loop... You may not have any negative effects (that you notice). How many miles on the truck? A open loop could be caused by many things... o2 sensors, vacuum leaks, bad plugs/wires.. When was the last time you checked these?
  3. Jul 7, 2013 at 6:28 PM
    JMaberry
    Jack
    It has about 163,000 on it. I bought it around march with 155,000, and I haven't checked any of those myself yet. I'm not all that mechanically inclined, kinda learning all this stuff as I go.
  4. Jul 8, 2013 at 6:52 AM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    when I'm on the throttle heavy, my UG shows that I'm in open loop, but when under normal driving (moderate throttle) it is closed. No adverse affects that I've noticed, but I'm sure its due to my o2 going bad..
  5. Jul 8, 2013 at 7:10 AM
    BamaToy1997
    Bill
    Navarre, FL
    When you go heavy into the throttle you will typically go into an open loop. Closed loop operation is typically for light throttle or idle condition. Lack of going into closed loop can be, as mentioned, due to not getting the correct feedback from several sensors, including O2 sensors, MAF sensor, air intake temp sensor (Part of the MAF sensor assembly usually) as well as the ECT sensor.
  6. Jul 8, 2013 at 11:10 AM
    JMaberry
    Jack
    I typically go pretty light on the throttle for the sake of mpgs. If its not going into closed loop at all, what should I check first?
  7. Jul 8, 2013 at 1:45 PM
    BamaToy1997
    Bill
    Navarre, FL
    I would suggest looking at hooking up a scan tool to look at the data. See if something looks out of place.
  8. Jul 9, 2013 at 7:23 PM
    JMaberry
    Jack
    used my ultragauge to check for any codes, and it turned up P0128. Its been showing that same code as long as I've had the truck, and my temperature gauge on the dash is also not functioning. I had it checked out by a mechanic a while ago, and was told that it was only showing that code because the gauge on the dash wasn't working, so at that point I just left it alone. Now I'm wondering if maybe that has something to do with the open/closed loop issue?
  9. Jul 9, 2013 at 8:23 PM
    smuook
    smuook Daily Driver "Plus"
    Smuook
    Loganville, GA
    2004 DC V6 PreRunner
    Billy 5100, Satoshi, MBW Wheels, All Pro Front Bumper with 3x PIAA 530, LED dash lighting, other stuff too much to list
    DTC No. P0128
    DTC Detection Condition:
    (a) Cold start
    (b) After engine is warmed up
    (c) Engine coolant temp. < 75C (167F)
    Trouble area:
    Thermostat
    Cooling system
    Engine coolant temp. sensor
    ECM
    If your engine isn't (or doesn't think it is) warming up, I don't think it will go closed loop.
  10. Jul 9, 2013 at 8:40 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    The code is not because the gauge is malfunctioning... not exactly.
    The gauge is possibly malfunctioning because of a faulty sending unit.
    This seems to be confirmed by the code.
    What does the UG indicate your temperature to be? A disconnected or bad sending unit could be the problem... or someone may have installed a 155 degree thermostat.
    Quite often, when a vehicle has overheating problems, the owners will install a "cooler" thermostat thinking it will help (and it won't). People will also install cooler thermostats out of ignorance, thinking that cooler is better. It's not. An engine is most efficient when it's running on the edge of meltdown.
  11. Jul 9, 2013 at 9:13 PM
    JMaberry
    Jack
    Makes sense I suppose...tomorrow I'll check the temperature through the ultragauge and see if it jumps around like the gauge on the dash
  12. Jul 9, 2013 at 11:43 PM
    VooDooTrip
    VooDooTrip Defector
    Gilbert, AZ
    01' BSP S/C S-Runner
    S/C, URD fuel Upgrade, 2.2 Pulley, URD crank pulley, Truetrax locker, custom exhaust, plx, scangauge, D/P mod, amsoil drop in, 18x9.5 stern hyperblacks, ACA projectors, Grillcraft blackmesh, Performance Products valance, R/C Tails, B&M Short shifter, QA1 Coilovers all the way around, upgraded strut rod bars with heim joints, poly bushings everywhere lol, 1st model Streetacos bolt on four link!
    You sir, have the ultimate Split second tuning truck...
  13. Jul 10, 2013 at 7:53 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Mine will maintain closed loop under some pretty heavy acceleration.
    Checking it out tonight on the way home climbing some hills, I had to hammer down enough to downshift AND get the engine to 3k before it went to OL.
    On the bottom end, I haven't thought to look at idle, but it'll remain in CL on decel until it drops below 1900 at zero throttle. From there, "it depends".
    If I'm just off the gas but slowing gradually (level or a slight decline), it'll stay in CL until 1500 when it drops into OL. If it's down a steep hill, then the engine braking kicks in and it drops into OL at 1900, but if any throttle is applied, it immediately goes back into closed loop.
