Won't go into Reverse, 1st, 3rd or 5th
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Carson, Jun 21, 2011.
  1. Jun 21, 2011 at 10:30 PM
    Carson
    Carson [OP] Well-Known Member
    Carson
    Modesto, California
    05 TRD Sport 4x4 SR5 V6
    Garage Fabbed +2 LT, FOA 2.5 RR w/ Comp Adj, 35 XMTs on Level 8s, 50T Spring Under w/ 13" Shackles, Elite Front Bumper, AP Rear, Retrofitted, Wicked Flow, Custom Roof Rack, Custom Sliders, Custom Scratches, 12" JL and an Audiopipe amp.
    Well today i drove to Arizona from california, about 500 miles. The whole trip was great. I stop at the gas station about 25 miles from my destination and everything is still, great. I begin to head towards my destination, which is my uncle's house out in the desert. I have to drive on some dirt roads to get there, anyway, its all fine and i pull up to their house and park. A couple hours later i get in my truck and i can't get the transmission into reverse, 1st , 3rd or 5th. It kinda goes half way and grinds a whole bunch if i try to let out the clutch. In addition, moving the stick around in neutral doesn't feel right. After several attempts i am finally able to get it, so i drive it around a bit and stop, it does the same thing, so i have to continue to struggle with it... I did hit some dips pretty hard on the dirt road, so maybe the transmissions just loose? The truck has 116k. Any help is appreciated! I'm going to take a good look at it tomorrow. Thanks
    Update: I removed the URD SS this morning hoping that was the problem. It wasn't. Oil has been checked and is fine. 2nd 4th and 6th work fine. 1, 3, 5 worked on and off this morning, i havn't been able to get reverse to work at all this morning...
    Update: Went to a transshop and they quoted me 1200 bucks, i was like yeah right. I went to toyota and they found parts of the urd ss that were not allowing the truck to shift. Anyway cost me 110$ for the "inspection fee." Anyway gotta give props to Anderson Toyota of Havasu, AZ. They could of charged me out the ass. I knew i should of looked into the trans with a flashlight haha. Anyway its all good now except i just blew my serpentine belt off, :\
    Thanks for the help!!!
  2. Jun 21, 2011 at 10:38 PM
    transplant
    transplant resident know-nothing
    theo
    Crestline, Ca
    89 sr5, 99 OR, 11sport, 14 offroad
    uhh.. ever replaced the clutch? it prolly no workie.
    however.. in your transmission those gears you listed are usually at the top of the gearbox. no oil.. no workie. if a synchro was going out.. you would have had some warning im guessing.. and it would be from one gear position to the other... but uhh..
    you ever replaced that clutch?
  3. Jun 21, 2011 at 10:42 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    could have something to do with the URD short shifter! jus' sayin'
  4. Jun 21, 2011 at 10:42 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    x2
    and I doubt the clutch has already been replaced at only 116k.
  5. Jun 21, 2011 at 10:43 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    x2
    sounds like a clutch or maybe fluid to me
    Edit: Didn't realize you have the SS. That would be the first thing to check.
  6. Jun 21, 2011 at 10:45 PM
    Carson
    Carson
    Modesto, California
    I am not sure if the clutch has been replaced, i bought it with 96k... I'm going to check the oil tomorrow. Thanks
    Didn't think of that, thanks for reminding me about that! Ill pull my console tomorrow. Thanks
    Yeah, i'm not sure.
  7. Jun 21, 2011 at 10:47 PM
    Carson
    Carson
    Modesto, California
    Shit, hope its not the clutch...
    Will check the ss tomorrow! Thanks
  8. Jun 21, 2011 at 11:17 PM
    landphil
    landphil Wishin' I was Fishin'
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    If 2nd, 4th, and 6th work fine, it's not the clutch, sounds like a shift mechanism issue, and the short shifter is the first place I'd look. I't not the first time I've heard of one of them causing trouble.
  9. Jun 21, 2011 at 11:25 PM
    transplant
    theo
    Crestline, Ca
    im retarded and you are correct.. this is what happens when you learn how to read in california.
    i vote a class action suit.
  10. Jun 22, 2011 at 6:40 AM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    03 F250 CCSB
    Gibson stainless headers, custom free-flow Y-pipe, Magnaflow muffler, 285/75R16 KBro2's
  11. Jun 22, 2011 at 2:00 PM
    Carson
    Carson
    Modesto, California
    Thanks for the help everybody.
  12. Jun 22, 2011 at 2:19 PM
    anethema
    anethema Well-Known Member
    J
    Dawson Creek,BC
    08 TRD OR Access cab 4x4
    ARB Bumper,OEM Roof rack modded for access cab, Allpro Rock Sliders,Icon Adjustable coilovers,More Tie Downs in bed, Firestone Airbags in rear,Block heater
    Sounds like something blocking your shifter from moving up. You probably broke a syncro and the pieces of plastic are floating around.
    No matter how you slice it, you need to drop the tranny.
    If still in warranty remove any evidence of short shifter and bring it in,you should be covered. GL.
    EDIT: Sorry 05 wont have warranty most likely. If you're comfy with it, drop the tranny and find out what went wrong. Else its about time for the mechanic and some green.
  13. Jun 22, 2011 at 2:39 PM
    Carson
    Carson
    Modesto, California
    Yeah, i don't have a warranty and i don't have a dolly or anything to hold the transmission, time to fork out the money... thanks
  14. Jun 22, 2011 at 3:36 PM
    Gigi515
    Gigi515 Active Member
    Western MA
    2008 Tacoma 4x4
  15. Jun 22, 2011 at 4:04 PM
    Gigi515
    Western MA
    2008 Tacoma 4x4
  16. Jun 22, 2011 at 4:07 PM
    Carson
    Carson
    Modesto, California
  17. Jun 22, 2011 at 4:20 PM
    sechsgang
    sechsgang Well-Known Member
    06 DC TRD OR 4WD 6spd
  18. Jun 22, 2011 at 4:50 PM
    Carson
    Carson
    Modesto, California
    Anybody know how to access the linkage?
  19. Jun 22, 2011 at 5:12 PM
    Gigi515
    Western MA
    2008 Tacoma 4x4
  20. Jun 22, 2011 at 5:57 PM
    Carson
    Carson
    Modesto, California
