Won't idle after battery disconnect
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tinkerz, Jan 20, 2015.
  1. Jan 20, 2015 at 2:41 PM
    tinkerz
    tinkerz [OP] New Member
    01 with 3.4 won't idle after sitting for a day with the battery disconnected. I tried driving it for several miles to see if the ecu would relearn programming.
    It did not help.
  2. Jan 20, 2015 at 3:01 PM
    WeberSarge
    WeberSarge Well-Known Member
    Kevin
    Ohio, Illinois
    '08 SR5 TRD 4X4 Quad Cab , '77 FJ40
    Stock for now...
    Probably get better luck asking this in the 1st Gen trucks section ....
    Sarge
  3. Jan 20, 2015 at 3:03 PM
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    it may take more than several miles to reset
  4. Jan 20, 2015 at 3:13 PM
    1MK
    1MK Desert Explorer
    Southern California
    Sometimes a dirty throttle body in combination of resetting the ECM will cause a low/no idle situation.
  5. Jan 21, 2015 at 9:08 AM
    tinkerz
    problem resolved. Per instruction from a mechanic friend I disconnected battery again,both pos and neg. Then shorted both leads together for a few seconds. Reconnected battery and started truck. It stumbled on idle for afew seconds and quit. Restarted truck and idle resumed as normal. Thanks to all who responded to this thread even though it should have been posted in 1st gen.
