Won't idle
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RRMCNATT, Aug 1, 2021.
  1. Aug 1, 2021 at 8:23 PM
    RRMCNATT
    RRMCNATT [OP] New Member
    Randy
    2005 Tacoma
    New engine in 2013
    Just replaced a temperature sensor on a 2005 Tacoma 2.7l got all back together but now will not idle
  2. Aug 1, 2021 at 8:24 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    What temperature sensor? Check all the connections, namely the MAF sensor and connector itself.
  3. Aug 1, 2021 at 8:28 PM
    RRMCNATT
    Randy
    2005 Tacoma
    New engine in 2013
    It has a temperature sensor under the intake manifold so had to take off the throttle body put all back together and now it will not idle
  4. Aug 1, 2021 at 8:37 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Do you have access to a scan tool?
    And have you got a check engine light?
    A lot of scan tools show live data.
    I’d take a look at the new sensor data.
    Beats pulling it all a part again.
  5. Aug 1, 2021 at 10:10 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Can you keep it running with the accelerator?
    Did you clean the throttle body?
    Otherwise double check all your work and as @TnShooter said if you have a scanner look at codes and scan data.
    TnShooter likes this.
  6. Aug 1, 2021 at 10:29 PM
    Waasheem
    Waasheem
    2007 xrunner
    Scan tool, write down any error codes, hit clear error codes, try to see if there’s any improvement with idle.
    If no, dig into what the codes are telling you. Maybe something isn’t plugged in good.
