wont shift out of park after connecting trailer lights?
Discussion in 'Technical Chat' started by Mark S, Aug 28, 2012.
  1. Aug 28, 2012 at 6:38 AM
    Mark S
    Mark S [OP] New Member
    mark
    salem oregon
    07 tacoma
    3" lift
    07 tacoma wont shift out of park???? I have an 07 tacoma automatic, and helped a friend move a boat with an older trailer, the 7pin harness fit fine but when connected, my reverse lights would blink when turn signal was on. With harness disconnected, engine will start, blinkers wont work, and will not shift out of park as if ignition is off? hopeing it is just a fuse but they all look good. has anyone had a similar issue?
  2. Aug 28, 2012 at 6:39 AM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    sounds like just a fuse got blowed
  3. Aug 28, 2012 at 7:30 AM
    shemp
    shemp Well-Known Member
    That is 100% a fuse. I forget which one, but I've popped that one before.
    Hmm... your 7-pin plug is non-factory, isn't it? The tow harness for the factory trailer wiring protects your tail light circuit and wouldn't pop that fuse.
  4. Aug 28, 2012 at 7:32 AM
    YumaTRD
    YumaTRD The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
    Check your ECU fuse on the lower left hand side of the steering wheel. It should be behind the little cubby. I had this happen to me when i wired Aux lights to my reverse lights and overloaded the fuse.
  5. Aug 28, 2012 at 7:34 AM
    1stacoma
    1stacoma Well-Known Member
    Austin
    2012 MGM SR5 DCSB 4.0
    5100's front and rear, front 2.5" rear 2" AAL, 18% tint front and rear, color matched grill. SCS wheels 275/70/17 BFG AT KO's. DTRL toggle switch.
    Just a thought if you have to drive you can press the switch on the side of the shifter and put it into drive. To the left of the shifter there is a square box pop it out press the button and than you can shift into gear.
  6. Aug 28, 2012 at 7:46 AM
    BDJ
    BDJ Well-Known Member
    Brandon
    West Monroe
    2012 TRD OR 4x4 DBL Cab MGM
    Look in your fuse box behind your coin tray by your left leg and check the fuse that says IGn1, I think that is the one that controls the shift and all kinds of other stuff like the AC, and the air bags, and the back up camera if you have one.
  7. Aug 28, 2012 at 7:47 AM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Looks like this has been answered. Good luck.
  8. Aug 28, 2012 at 10:03 AM
    Mark S
    mark
    salem oregon
    07 tacoma
    3" lift
    Thanks to everyone , I will try when I get home today, thanks again really appreciate the help!
