Won't shift out of Park until I rev the engine
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HeliGav1, Nov 5, 2020.
  1. Nov 5, 2020 at 7:45 PM
    HeliGav1
    HeliGav1 [OP] Member
    HeliGav1
    SW FL
    05 Double TRD OFF RD Black & Tan
    2nd Gen 2005 4x4 - recently this problem has developed: to shift it out of Park I need to gently Reve the engine once (hit the gas pedal gently and release) and then it shifts normally. What causes this? All other vehicle functions are ok. Only this one little thing when shifting out of Park. Other transmission shifts are normal with normal engine RPMs etc. Thx in advance.
  2. Nov 5, 2020 at 8:43 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    That is a new one for me... Maybe @gearcruncher will chime in with some information.
    gearcruncher likes this.
  3. Nov 5, 2020 at 9:12 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    So you can’t move the gear selector until AFTER you rev the engine?
  4. Nov 5, 2020 at 10:48 PM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    Yeah I don't understand, need more information. The shifter is physically stuck until you tap the gas? Like how it acts when you're not touching the brake?
    SR-71A likes this.
  5. Nov 6, 2020 at 12:01 AM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    just for fun test battery voltage
  6. Nov 6, 2020 at 12:33 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    torque converter?
  7. Nov 6, 2020 at 3:58 AM
    No Shoes Nation
    No Shoes Nation Well-Known Member
    2008 Taco SR5 Access Cab 4.0 4x4
    Hmm . . . none as yet, that's why i'm here . . .
    if its as u say, maybe a mount issue causing linkage misalignment.
    possible front pump or torque converter issue
    SR-71A and CygnusX191 like this.
  8. Nov 6, 2020 at 4:40 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Turn key on to run position, put foot on brake, don't actually start engine, can you shift it into drive? You should be able to.
    SR-71A and gearcruncher like this.
  9. Nov 6, 2020 at 6:15 AM
    ICECOLDBEER
    ICECOLDBEER Well-Known Member
    2006 Tacoma 2.7L SR5
    Look underneath at the tranny. There is a linkage. Spray the shit out of it with some good oil. Just an idea.
  10. Nov 6, 2020 at 7:46 AM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    On the assumption you're shifting from P to R and nothing happens unless you rev the engine - that probably points to a pump/pressure/fluid level problem.
  11. Nov 6, 2020 at 7:50 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    This OP. Can you do this?
  12. Nov 6, 2020 at 12:03 PM
    gearcruncher
    Canadain bumper technician
    I am going with a shift lock solenoid issue as my first guess
    Increasing the engine rpm doesnt have anything to do with moving the shift linkage . Probably a loose connection causing the contacts in the shift lock mechanism to lose contact . Increasing the engine rpm shakes the truck enough to re-connect the loose wiring or you have very low battery voltage or corrosion and the solenoid in the shift lock mechanism is taking its sweet time to unlock
    Keep in mind , your engine does not need to be running to move the shifter out of park . You can turn the ignition to the " ON " position without the truck running , hit the brake pedal and you can move the shifter through all the detents .
    Can you see your brake lights come on when you hit the brakes ? This will tell us that your brake switch is functioning . The shift lock solenoid gets a signal from the brake switch when you hit the brakes .
    Another member had some issues just last week not being able to get his truck out of park and he had a lot of help . Check out the post .
    https://www.tacomaworld.com/threads/tacoma-shifter-cable-locked.692723/#post-24479252
    Jimmyh and SR-71A like this.
  13. Nov 6, 2020 at 5:14 PM
    TnShooter
    Deogee
    STOCK
    OP, hasn’t been back since 1 mins after he posted.
    I’m guessing it isn’t too big an issue yet.
    Maybe he’s like me, and waits until it “completely fails” to fix it.
    I might have known my battery was weak, and I might have waited until I got stranded before I decided to fix it. Like I said, I might have done this, but I won’t admit to it.
    Muddinfun and Jimmyh like this.
