won't start: battery okay, one loud click
Discussion in '1st Gen. Tacomas (1995-2004)' started by lindsey, Nov 21, 2010.
  1. Jan 23, 2022 at 8:23 PM
    #41
    JudoJohn
    JudoJohn Well-Known Member
    St. Louis
    96 Tacoma 2WD 5 speed
    If it shows 12.9V, the battery is not OK. Get the battery load tested.
    wilcam47 likes this.
  2. Jan 23, 2022 at 8:34 PM
    #42
    908tacoma
    908tacoma Well-Known Member
    New Jersey
    2018 MGM
    OME, SPC, TRD
    Back from the dead thread
  3. Jan 23, 2022 at 10:08 PM
    #43
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    If the contacts inside are not installed flat it can give the same symptoms of worn out contacts. If you have the starter off, just take the back off and check the contacts. When you install the big cable to the outside of the starter, if you tighten the nut too much it can rotate the contact inside too. The stud that the cable gets installed onto is part of the contact, so that's why it can rotate.
    JudoJohn likes this.
