wont start code reads crank positioning sensor
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacofred, Mar 20, 2010.
  1. Mar 20, 2010 at 5:06 PM
    tacofred
    tacofred [OP] Member
    fred
    salt lake city
    08 tacoma
    3inlift,uni chip,trd seatcover,volant cold air with sweepermagniflowexhaust
    where is my crank positioning sensor located code reads crankpositiong sensor b?
  2. Mar 20, 2010 at 5:17 PM
    biggdog747
    biggdog747 Well-Known Member
    MI
    taco
    whats the code number P? and what engine?
  3. Mar 20, 2010 at 5:29 PM
    tacofred
    fred
    salt lake city
    08 tacoma
    4.0 truck start when warm out went to autozone and did a scan said crank posintion sensor b malfunction
  4. Mar 20, 2010 at 5:56 PM
    biggdog747
    MI
    taco
    ill try posting this pic dont know if it will work cause its direct from TIS. its on the drivers side of the block.
  5. Mar 20, 2010 at 5:57 PM
    biggdog747
    MI
    taco
    nope pic didnt work.
  6. Mar 20, 2010 at 6:01 PM
    biggdog747
    MI
    taco
    P0335
    Crankshaft Position Sensor "A" Circuit
    - Open or short in CKP sensor circuit
    - CKP sensor
    - Sensor plate (CKP sensor plate)
    - ECM
    P0016
    Crankshaft Position - Camshaft Position Correlation (Bank 1 Sensor A)
    - Mechanical system (Timing chain has jumped tooth or chain stretched)
    - Oil Control valve camshaft timing gear assembly
    - ECM
    these are the only two crank codes so i dont know which one you have
